Infinite Lines
Infinite Lines
Lines, infinite in one or both directions, are called rays and construction lines. These lines can be used as auxiliary lines to create objects. It is recommended to create auxiliary on a separate layer, which can be frozen or made unprintable. Auxiliary lines can be edited; copied, replaced, and rotated.
Ray
Ribbon: Home, Draw – Draw > Ray Menu: Draw – Ray Toolbar: DrawCommand line: RAY
This command creates a ray – starting in a point and a semi-infinite construction line. The direction of ray is specified by the second point. The command prompt Specify through point: repeats to create several rays. Origin point is the same for all created rays.
Specify start point:
Specify start point.
Specify second point.
Specify second point of the next rayor press ENTER to finish the command.
Attention: If in response to prompt to enter the first point of line you press ENTER or SPACE, the line will be built starting from the endpoint of the last created line, polyline or arc. If arc or polyline arc segment was the last created object, the line is built tangent to arc or arc segment.
Construction Line
Ribbon: Home, Draw – Draw > Construction line Menu: Draw – Construction Line Toolbar: Draw –Command line: XL, XLINE
This command creates an infinite construction line. The direction of construction line is specified by the second point (origin point is the same for all created lines). The command prompt Specify through point: repeats to create several lines.
Hor
Creation of an infinite line through the specified point and parallel X axis.
Ver
Creation of an infinite line through the specified point and parallel Y axis.
Ang
Creation of an infinite line through the specified point with specified angle to X-axis or selected linear object.
Enter angle of xline (0) or [Reference]:
Angle – Enter angle value
Reference – select linear object. Angle will be calculated related to this object countclockwise.
Bisect
Creation of an infinite bisector line through vertex of an angle.
Offset
Creation of an infinite line parallel selected object with specified offset.
Specify offset distance [Through/]
Offset distance – distance between xline and selected object
Through – drawing xline through specified point and parallel selected linear object.
Command prompts for drawing xline through point:
Specify start point or [Hor/Ver/Ang/Bisect/Offset/]:
Command prompts for drawing xline parallel axis:
Command prompts for drawing xline with specified angle:
If you selected Reference option:
Select a line object or [?/]:
Command prompts for drawing bisector xline:
Specify angle vertex point:
Specify angle start point:
Specify angle end point:
Command prompts for xline parallel linear object:
Specify side to offset:
If Through option is selected:
Specify next point or press ESC to finish the command.
Select Hor or Ver.
Specify point.
Select Ang.
Enter angle value, press ENTER
Specify point.
Select line.
Specify point.
Select Bisect.
Specify angle vertex point.
Specify angle start point.
Specify angle end point, press ENTER.
Select Offset.
Specify offset distance for xline.
Select line.
Specify side to offset.
Select line.
Specify point for xline, press ENTER.
Info: NanoCAD is a simple, inexpensive, and yet professional, CAD app for PC, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware supports progressive, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
