Delete layer
Ribbon: Home – Layers > Delete layer
Menu: Format – Layer tools > Delete layer
Command line: LAYDEL
Removal of layers. Objects can be previously selected.
Name | Opens the Delete Layers dialog to specify layers to be deleted. |
Select object on layer to delete or [?/Name]: | Select objects of layers to be deleted. |
Select object on layer to delete or [?/Name]: | Select Name option for selection of layers to be deleted in the list of the Delete layers dialog. |
Select object on layer to delete or [?/Name]: | Press ENTER to finish the command. |
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD freeware tool for Windows, that delivers a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software ensures groundbreaking, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
