Ribbon: Insert – Block > Blocks
Menu: Format – Blocks …
Command line: BLOCKS, BLOCKSCMD
The Blocks dialog box includes information on all block definitions contained in the document and on the number of their references:
Columns:
Name | List of block definitions contained in the document. |
Refs | Displays information on the number of block references in the current document. |
Description | Displays information entered during the block creation in the Description section of the Block definition dialog box. |
Left double-click on the column names separator automatically modifies the columns width.
To rename a block:
- Left double-click on the block name.
- Enter a new block name from the keyboard.
To delete the block definition:
- Select in the list the block to delete.
- Click уд_оп_бл button or select the Delete command in the context menu opened by the right click
- Confirm the deletion by clicking Yes button.
- Click the Close button to exit the dialog.
NOTE: The block definition is deleted in the Blocks dialog box, while block reference is deleted by selecting it in the drawing area, with further opening of the Delete command (or Del key).
NOTE: Some block definitions are systemic. They cannot be deleted.
Info: NanoCAD is an easy-to-use, cheap, and yet powerful, CAD application for PC, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool ensures progressive, collaborative and customizable features to enhance your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, if you like it.
