Create Transmittal Package
nanoCAD button – Etransmit
Ribbon: Output –Export > Etransmit
Menu: File – Etransmit…
Command line: ETRANSMIT
This function forms packages of files for transmitting to other computer or transmission by internet. Transmittal package includes all drawing-related files such as xrefs and font files.
NOTE: In some CAD “set of files” term is used instead “package of files”.
Create transmittal * dialog box displays table with all drawing-related files (xrefs, fonts etc.). The dialog shows information about every file in transmittal: *Name, Size, Type, Date, Saved path.
Click button to display files in a tree structure.
Files marked with and are included in transmittal package.
To create transmittal package:
1. Run Etransmit command.
2. To include additional files, click the Add file… button in the Create Transmittal dialog box, then select files in standard dialog Open.
3. Clear check boxes for unnecessary files to exclude them from package.
4. Click OK. Specify a file name and locate the folder where you want to create the transmittal package in Save as dialog box. Transmittal package saves in a self-extracting ZIP-file.
You can set up Etransmit settings in the * Etransmit* section of the Options dialog (menu Tools – Options).
Options
Include fonts | Include associated font files (TTF and SHX) to transmittal package. |
Path options | Select options for files and folders included in package: Use organized folder structure; Place all files in one folder; Keep files and folder as is. |
Info: NanoCAD is a user friendly, low cost, and yet professional, CAD freeware tool for personal computer, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool ensures innovative, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
