Arc by three points
Ribbon: Home, Draw – Draw – Arc > 3-Point
Menu: Draw – Arc > 3 points
Toolbar: Draw –
Hotkeys: CTRL+ALT+A
Command line: A, ARC
Specify start point of arc or [Center]: | Specify start point 1. |
Specify second point of arc or [Center/End]: | Specify second point 2. |
Specify end point of arc: | Specify end point 3. |
Arc by center, start and end
Ribbon: Home, Draw – Draw – Arc > Center, Start, End
Toolbar: Draw –
Command line: ARCBYCENTERSTARTEND
Specify center point of arc: | Specify arc center (point 1). |
Specify start point of arc: | Specify start point 2. |
Arc by continue
Creates an arc tangent to the last created arc, line, or polyline object, 2D polyline or 3D polyline. The end point of previous object will be the arc start point.
Attention: For quick creation of such arcs you can also press Enter or SPACE in response to prompt “Specify start point of arc” in the arc creation command
Ribbon: Home, Draw – Draw – Arc > Continue
Menu: Draw – Arc > Continue
Toolbar: Draw –
Command line: ARCBYCONTINUE
Specify end point of arc: | Specify end point 1. |
Info: NanoCAD is an easy-to-use, affordable, and yet powerful, CAD app for PC, that provides a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool supports creative, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, if you like it.
