Ribbon: Point Clouds – Point Cloud > Create from View
Menu: Point Clouds > Create from View
Command line: NPC_CROP_FROM_VIEW
The command creates a new point cloud from the crop of the existing cloud. In this case the source point cloud is deleted.
To create a new cloud from crop:
1. Go to the model space viewport containing the clipped cloud and run the command.
2. If there are several clouds the command line will show a prompt to specify the necessary:
Use all clouds in VScreen? or [Yes/No]:
3. After specifying, the selected clouds will be deleted, and new ones will be created in their place from their clippings.
NOTE: when which command is undone, clipping on the source clouds is not restored.
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD freeware tool for Windows, that provides an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program provides progressive, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
