Coordinate axes
Array of orthogonal axes
CAD drafting DRAWING DESIGN 0Main menu: Construction – Coordinate axes – CAD software DRAWING DESIGN 1Construction grid.
CAD drawing DRAWING DESIGN 2Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 3Construction grid.
CAD software DRAWING DESIGN 4Toolbar: CAD drawing DRAWING DESIGN 5Construction grid ( “Coordinate axes”).
CAD drafting DRAWING DESIGN 6Command line: SPGRID.
Dialog array axes has two tabs – Digital and Letter to adjust accordingly alphanumeric array axes.
CAD software DRAWING DESIGN 7
In the table, select the first line step between adjacent axes (in units of nanoCAD) and the total number of axes. You can create multiple sequences with different axes step between the axles and a different number of axes in each sequence. To do this, the bottom line in the column Step select the desired step value. The new line will be added automatically.
CAD drawing DRAWING DESIGN 8
Column Total under the table, the distance between the extreme axes of the array.
Button CAD drafting DRAWING DESIGN 9 allows you to copy the settings from another array axes inserted into the drawing.
Button CAD software DRAWING DESIGN 10 reverses the number and letter codes available when auto-numbering is disabled, ie. modes: Disabled, According to GOST, Decremental.
Marking Tool Group axes includes the following elements:
list of markers to select the position of the markers in the array axes or to disable their display.
Available options markers vertical axes Left \Right\Two Sided\Hide
Available options markers vertical axes Up\Down\Two Sided\Hide
in the entry field Start with specified value of the first axes. By default, digital axes numbering starts at “1” for the letter – from “A”.
Switch Add ‘c’ index to the notation of the axes.
switch Autonumbered to control automatic placement of axes numbers.
Available options Autonumber Incremental\Decremental\GOST \disabled.
Axial Tool Group comprises three dimensions switch for controlling the display sizes between the axes of the array:
· dimensional chain · group chain dimensions · overall dimensionIn the graphics window, specify the position of the base point in the array, which will correspond to the insertion point. Move the cursor to the desired site and click the left mouse button. Base point indicated by the red squares.
CAD drawing DRAWING DESIGN 11
By default, when you insert the array you want to specify the insertion point in the drawing. To disable this mode, clear Specify a point . In the fields below, specify the X, Y coordinates of the insertion point, or select a point on the drawing by clicking CAD drafting DRAWING DESIGN 12.
Switch Specify angle serves to activate the visual selection angle array axes. If required, enter the exact value of the angle of rotation in the input field, enter the angle in the drawing by clicking CAD software DRAWING DESIGN 13.
Turn on the switch Split an array if you want to insert an array broken into separate axes and axial dimensions.
When the switch is on group chain dimensions, the size of the axes will be as follows:
CAD drawing DRAWING DESIGN 14
You can edit individual array axes on the drawing after insert. Call of axes editing can be done by double-clicking on the marker axes (you must enable edit mode by double-clicking in the settings nanoCAD Construction 23). To edit the axes can zoom the display so as to bring it closer to the marker. If the display scale of the array axes is small, then when you double-click will be called configuration dialog array. Editing dialog array axes has the form
CAD drafting DRAWING DESIGN 15
You can change the name of the marker (if configured array mode is in mode of disabled Autonumbering). Controls the display of the axes by means of a switch Hide axes.
You can edit the distance between axes by double-clicking dimensions on the drawing and entering its value.
The drawing can be edited using an array of axes grips.
Position of the axes can also be changed via the STRETCH command.
Array of polar axes
CAD software DRAWING DESIGN 16Main menu: Construction – Coordinate axes – CAD drawing DRAWING DESIGN 17Polar grid.
CAD drafting DRAWING DESIGN 18Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 19Polar grid.
CAD drawing DRAWING DESIGN 20Toolbar: CAD drafting DRAWING DESIGN 21Polar grid ( “Coordinate axes”).
CAD software DRAWING DESIGN 22Command line: SPPGRID.
CAD drawing DRAWING DESIGN 23
In the table, select the first line step between adjacent axes (degrees for digital and literal axes mm) and the total number of axes. You can create multiple sequences with different axes step between the axles and a different number of axes in each sequence. To do this, the bottom line in the Step column select the desired step value. The new line will be added automatically.
CAD drafting DRAWING DESIGN 24
Meaning the first step in the alphabet first axis determines the distance from the center axis of the array.
Button CAD software DRAWING DESIGN 25 allows you to copy the settings from another array axes inserted into the drawing.
Button CAD drawing DRAWING DESIGN 26 reverses the number and letter codes.
Tool Group Labeling axes includes the following elements:
Available options markers arc axes Start\End \On both sides\Castle\Hide.
Available options markers radial axes Show\Hide.
in the entry field Start with specified value of the first axis. By default, digital axes numbering starts at “1”, for the letter – from “A”.
Switch Add C index to the axis name.
switch Autonumbered to control automatic placement of axis numbers.
Available options Autonumber radial axes Clockwise\CCW \disabled .
Available options Autonumber arc axis from the center of\K Center\Disable.
Tool Group Axial dimensions contains two switches that serve to control the display size between the axes of the array:
· dimension chain · group chain dimensions · overall dimensionsIn the graphics window, specify the position of the base point in the array, which will correspond to the insertion point. Move the cursor to the desired site and click the left mouse button. Base point indicated by the red squares.
CAD drafting DRAWING DESIGN 27
By default, when you insert the array you want to specify the insertion point in the drawing. To disable this mode, clear Specify a point. In the fields below, specify the X, Y coordinates of the insertion point, or select a point on the drawing by clicking CAD software DRAWING DESIGN 28.
Switch Pick angle serves to activate the visual selection angle array axes. If required, enter the exact value of the angle of rotation in the input field, enter the angle in the drawing by clicking CAD drawing DRAWING DESIGN 29.
Turn on the switch Explode array if you want to insert an array broken into separate axis and axial dimensions.
When the switch is on group size, the size of the axes will be as follows:
CAD drafting DRAWING DESIGN 30
On the drawing you can edit individual array axis. Call of axis editing can be done by double-clicking on the marker axis (you must enable edit mode by double-clicking in the settings nanoCAD Construction 23).
CAD software DRAWING DESIGN 31
You can change the name of the marker (if configured array mode is in state of disabled Autonumbering).
Controls the display of the axis by means of a switch Hide axis .
Double click, you can change the value of the axial sizes (included in the chain, or the total size). When resizing shifted all axes, watching this.
Single axis
CAD drawing DRAWING DESIGN 32Main menu: Construction – Coordinate axes – CAD drafting DRAWING DESIGN 33Construction axis.
CAD software DRAWING DESIGN 34Ribbon: Construction – Architecture – CAD drawing DRAWING DESIGN 35Construction axis.
CAD drafting DRAWING DESIGN 36Toolbar: CAD software DRAWING DESIGN 37Construction axis ( “Coordinate axes”).
CAD drawing DRAWING DESIGN 38Command line: SPCLINE.
CAD drafting DRAWING DESIGN 39
1. In the dialog box Single axis indicate the number of the first axis inserted. Click OK. 2. Specify start point or the name of the first axis. 3. Specify the endpoint of the first axis. 4. Enter the distance to the next axis or the insertion point. Complete the cyclic command by pressing Esc.When you enter the distance from the keyboard position of the axis the current cursor position is given.
Switch CAD software DRAWING DESIGN 40Add the index ‘c’ to automatically add an index to the designation of the axis.
Switches Dimensional chain and total size includes automatic dimensioning between the axes. Dimensions may be linear or angular.
Dimension grouping joins chain of dimension into one single group dimension.
CAD drawing DRAWING DESIGN 41
Switch Stationing displays stationing dialog.
CAD drafting DRAWING DESIGN 42
Stationing can be chosen from a list of PC or CM. You can also specify the number of the first picket. You can set the initial value, enter it in the appropriate input box.
CAD software DRAWING DESIGN 43
Stationing is calculated as the ratio of the actual distance between pickets to the specified distance in meters plus supplement.
At a given distance between pickets 10m axis will be as follows:
CAD drawing DRAWING DESIGN 44
Anchor shows the direction of reference between the axes.
Axes inserted into the drawing are automatically numbered in ascending order by numbers or letters (depending on the designation of the first axis).
When you insert an axis , in context menu also some commands are available (N-Name, E-New, A-angle, and D-Dialog):
· When you choose N-name on the command line, you are prompted to enter a new designation for the next axis · Team New Eallows you to select a new location inserted axis. · A-angle translates insert axis in append mode radial axisCAD drafting DRAWING DESIGN 45
· D-Dialog is invoked to set parameters and add another axis.CAD software DRAWING DESIGN 46
When you click on “OK” dialog will be created in the drawing axis, located at a predetermined distance (angle) from the previous dialog with the entered name.
CAD drawing DRAWING DESIGN 47
When the command completes Single axis is finished the markers of axes are separated automatically.
Arc construction axis
CAD drafting DRAWING DESIGN 48Main menu: Construction – Coordinate axes – CAD software DRAWING DESIGN 49Separate arc construction Axis.
CAD drawing DRAWING DESIGN 50Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 51Separate arc construction Axis.
CAD software DRAWING DESIGN 52Toolbar: CAD drawing DRAWING DESIGN 53Separate arc construction Axis ( “Coordinate axes”).
CAD drafting DRAWING DESIGN 54Command line: SPARCCLINE.
To create a separate arc axis
1. Specify center point of the axis. 2. Specify radius of arc (click or enter a value on the keyboard). 3. Specify the start angle (click or enter a value on the keyboard). 4. Specify end angle (click or enter a value on the keyboard).CAD software DRAWING DESIGN 55
The double-click to open the context menu arc axis.
CAD drawing DRAWING DESIGN 56
Column Marker name contains a list of the names of the markers. To add a new marker, click in an empty field and enter the name of the marker.
Options arc axis:
· Hide marker – hides the marker so it is only displayed in the drawing axis; · Move marker – moves marker to the other end of the shaft; · Two side marker – adds a marker at the other end of the axis; · Hide axis – the axis hides, only the marker;Circular construction axis
CAD drafting DRAWING DESIGN 57Main menu: Construction – Coordinate axes – CAD software DRAWING DESIGN 58Separate Circular Construction Axis.
CAD drawing DRAWING DESIGN 59Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 60Separate Circular Construction Axis.
CAD software DRAWING DESIGN 61Toolbar: CAD drawing DRAWING DESIGN 62Separate Circular Construction Axis ( “Coordinate axes”).
CAD drafting DRAWING DESIGN 63Command line: SPCIRCCLINE.
To create a separate rotary axis:
1. Specify center point of the axis. 2. Specify the radius of the arc. 3. Specify marker angle.CAD software DRAWING DESIGN 64
Context menu of the rotary axis is as follows:
CAD drawing DRAWING DESIGN 65
Arc axis
· Hide marker – hides the marker and is only displayed in the drawing axis; · Hide axis – the axis hides, showing only the marker;Add markers
CAD drafting DRAWING DESIGN 66Main menu: Construction – Coordinate axes – CAD software DRAWING DESIGN 67Add marker.
CAD drawing DRAWING DESIGN 68Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 69Add marker.
CAD software DRAWING DESIGN 70Toolbar: CAD drawing DRAWING DESIGN 71Add marker ( “Coordinate axes”).
CAD drafting DRAWING DESIGN 72Command line: SPADDMARKER.
1. In the drawing select the coordination axis. 2. In the dialog box Additional markers specify a name to the marker. CAD software DRAWING DESIGN 73 3. Click OK. 4. Specify the name of the second additional marker and click OK or click Cancel to exit.Orientation mark for construction line
CAD drawing DRAWING DESIGN 74Main menu: Construction – Coordinate axes – CAD drafting DRAWING DESIGN 75Orientation Mark for Construction Axis.
CAD software DRAWING DESIGN 76Ribbon: Construction – Architecture – CAD drawing DRAWING DESIGN 77Orientation Mark for Construction Axis.
CAD drafting DRAWING DESIGN 78Toolbar: CAD software DRAWING DESIGN 79Orientation Mark for Construction Axis ( “Coordinate axes”).
CAD drawing DRAWING DESIGN 80Command line: SPCLINEORIENT.
1. In the drawing select the coordination axis. 2. Specify insertion point or distance in the selected direction. Distance is introduced based on the current scale nanoCAD Construction 23.When editing inserted into the drawing pointer orientation dialog box appears pointer axis orientation
CAD drafting DRAWING DESIGN 81
Marker Autoname automatically sets the name of the pointer axis orientation. By turning off the marker, you can specify your own name index.
Set the input field with a new name index. If necessary, add to the name of the index ‘C’, using the button CAD software DRAWING DESIGN 82
Separate markers
CAD drawing DRAWING DESIGN 83Main menu: Construction – Coordinate axes – CAD drafting DRAWING DESIGN 84Separate Markers.
CAD software DRAWING DESIGN 85Ribbon: Construction – Architecture – CAD drawing DRAWING DESIGN 86Separate Markers.
CAD drafting DRAWING DESIGN 87Toolbar: CAD software DRAWING DESIGN 88Separate Markers ( “Coordinate axes”).
CAD drawing DRAWING DESIGN 89Command line: SPSEPARATEMARKERS.
Select the drawing focal axis and confirm. Markers axes are automatically moved apart so as to avoid overlapping.
Rename construction lines
CAD drafting DRAWING DESIGN 90Main menu: Construction – Coordinate axes – CAD software DRAWING DESIGN 91Rename Construction Axes.
CAD drawing DRAWING DESIGN 92Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 93Rename Construction Axes.
CAD software DRAWING DESIGN 94Toolbar: CAD drawing DRAWING DESIGN 95Rename Construction Axes ( “Coordinate axes”).
CAD drafting DRAWING DESIGN 96Command line: SPRENAMECLINES.
1. Select construction line. 2. In the dialog box, enter the name of the axis. Click OK. 3. Select the drawing focal axis that you want to rename.CAD software DRAWING DESIGN 97
Switch by GOST enabled by default is used to select the direction of renaming. Also included is a marker which will verify compliance with GOST: axis names: exception letters, Cyrillic characters, similar numbers, etc.
When the switch is ascending order axes from left to right and top to bottom.If you turn off both switches numbering axes in descending order, i.e, from right to left and top to bottom.
If some of the selected axes are arranged non-parallel to the first axis, a message is shown, which indicates the number of these axes.
CAD drawing DRAWING DESIGN 98
Similar construction line
CAD drafting DRAWING DESIGN 99Main menu: Construction – Coordinate axes – CAD software DRAWING DESIGN 100Similar to Construction Axis.
CAD drawing DRAWING DESIGN 101Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 102Similar to Construction Axis.
CAD software DRAWING DESIGN 103Toolbar: CAD drawing DRAWING DESIGN 104Similar to Construction Axis ( “Coordinate axes”).
CAD drafting DRAWING DESIGN 105Command line: SPSIMILARCLINE.
1. Select the drawing coordination axis. 2. Specify the distance or the insertion point next axis. In the context menu of available commands (N-Name/E-New/D-dialog/ A-fill angle). 3. Complete the action of the cyclic command.Plug-axis automatically numbered in ascending order
When you insert available context menu commands (1-Name , 2-Dialog and, 3-Angle)
· When you choose one-name on the command line, you are prompted to enter a new designation for the following axis. · Command 2 Dialog brings up a box next axisCAD software DRAWING DESIGN 106
When you click OK to the axis it is added to the input field name in the distance determined in the pitch axis of the previous axis.
Push-button pitch / angle CAD drawing DRAWING DESIGN 107 or CAD drafting DRAWING DESIGN 108 changes over the distribution of axes when inserting – orthogonal or polar.
Exit the dialog box by clicking Cancel.
· Command 3-angle (3-distance) changes over the distribution of axes when inserting.Refresh intersections of constructions axes
CAD software DRAWING DESIGN 109Main menu: Construction – Coordinate axes – CAD drawing DRAWING DESIGN 110Refresh Intersections of Constructions Axes.
CAD drafting DRAWING DESIGN 111Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 112Refresh Intersections of Constructions Axes.
CAD drawing DRAWING DESIGN 113Toolbar: CAD drafting DRAWING DESIGN 114Refresh Intersections of Constructions Axes ( “Coordinate axes”).
CAD software DRAWING DESIGN 115Command line: SPREFRESHCLINECROSS.
Updates intersection focal axes, providing the requirements of GOST dash-dotted lines crossing in long strokes.
· Select the drawing focal axis and confirm · Intersection will be updated automatically.CAD drawing DRAWING DESIGN 116
Adding axis to the array
CAD drafting DRAWING DESIGN 117Main menu: Construction – Coordinate axes – CAD software DRAWING DESIGN 118Add Axes to Grid.
CAD drawing DRAWING DESIGN 119Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 120Add Axes to Grid.
CAD software DRAWING DESIGN 121Toolbar: CAD drawing DRAWING DESIGN 122Add Axes to Grid ( “Coordinate axes”).
CAD drafting DRAWING DESIGN 123Command line: SPGRIDADDAXES.
CAD software DRAWING DESIGN 124
· Select an array of axes · Select the axis you want to addCAD drawing DRAWING DESIGN 125
Axis will be added to the array, and will be numbered in accordance with the sequence of the array.
Removing the axes of the array
CAD drafting DRAWING DESIGN 126Main menu: Construction – Coordinate axes – CAD software DRAWING DESIGN 127Extract Axes from Grid.
CAD drawing DRAWING DESIGN 128Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 129Extract Axes from Grid.
CAD software DRAWING DESIGN 130Toolbar: CAD drawing DRAWING DESIGN 131Extract Axes from Grid ( “Coordinate axes”).
CAD drafting DRAWING DESIGN 132Command line: SPGRIDEXTRACTAXES.
CAD software DRAWING DESIGN 133
· Select an array of axes · Select the axis you want to remove from the array, for example, the axis 3The extracted axis is excluded from the numbering of the array and will be independent axis.
CAD drawing DRAWING DESIGN 134
Architectural decisions
Wall
CAD drafting DRAWING DESIGN 135Main menu: Construction – Architecture – CAD software DRAWING DESIGN 136Add Wall.
CAD drawing DRAWING DESIGN 137Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 138Add Wall.
CAD software DRAWING DESIGN 139Toolbar: Architecture – CAD drawing DRAWING DESIGN 140Add Wall.
CAD drafting DRAWING DESIGN 141Command line: SPWALLADD.
Walls can be straight and arc sections. To construct the arc wall segment in the context menu select the command arc.
CAD software DRAWING DESIGN 142
Ways of building arcs will be available in the context menu:
Arc – consistently indicates the starting, middle and end Points;
Bulge – consistently indicates the initial endpoint of the arc and the given bend;
Center – consistently indicates the arc center’s starting and end points;
Segment – used for constructing rectilinear segments;
Justify – Consistently indicates left, center and right points;
Also in the context menu are the following options:
Axis – toggles for drawing the wall relative to its axis (left, center, right);
Offset – - lets you draw a wall with an indent;
Properties – opens the properties dialog box wall;
Match – allows you to copy the properties being built with any existing walls.
Properties dialog wall
Dialog can be accessed from the context menu to create a wall, or by right-clicking on an already built facility.
CAD drawing DRAWING DESIGN 143
Key parameters are displayed in the left pane of the dialog box. In the right pane of the dialog box you can set the wall material. You have the opportunity to create a multi-layered wall.
All parameters of the walls can be set independently or choose Template. The template determines the composition of the wall, its width and height. If the user changes any of these parameters, then the connection is lost with the template.
CAD drafting DRAWING DESIGN 144 – Wall material. Opens the material of the wall, where you can see and edit the list of available materials.
CAD software DRAWING DESIGN 145 – New layer. Creates a new blank layer comprising the wall. Column Material selects the required material from the drop-down list. Priority layer will determine cleanup schedules while crossing the walls: a layer with a higher priority is displayed on top of layers with a lower priority.
CAD drawing DRAWING DESIGN 146 – Delete Layer. Removes the layer from the wall.
CAD drafting DRAWING DESIGN 147 – Hatch . Allows you to set or change the shading layer.
CAD software DRAWING DESIGN 148 – Move Up. Moves the list of layers on the active layer above the line.
CAD drawing DRAWING DESIGN 149 – Move Down. Moves the list of layers on the active layer below the line.
You can specify full or simplified representation. In the simplified representation layers and hatching are turned off.
CAD drafting DRAWING DESIGN 150
Editing with grips
Central grip moves wall parallel to its original position.
CAD software DRAWING DESIGN 151
Recent handles allow the wall to turn.
CAD drawing DRAWING DESIGN 152
Blue arrow allows you to turn the wall.
Polygonal wall
CAD drafting DRAWING DESIGN 153Main menu: Construction – Architecture – CAD software DRAWING DESIGN 154Add PolyWall.
CAD drawing DRAWING DESIGN 155Toolbar: CAD drafting DRAWING DESIGN 156Add PolyWall (toolbar “Architecture”).
CAD software DRAWING DESIGN 157Command line: SPPOLYWALLADD.
Polygonal wall provided in the form of a closed polygon.
The order of insertion
· 1. Call command. · 2. Specify the first point of the construction of the wall. · 3. Specify the following point. · 4. To complete the construction of press Enter. Wall will be closed automatically.Dialog properties wall
Dialogue can be accessed from the context menu to create a wall, or by right-clicking on the already-built facility.
CAD drawing DRAWING DESIGN 158
The main parameters of the wall are displayed on the left side of the dialog box. In the right part of the dialog is set composition of the wall. In this case it is possible to create multi-layered walls.
Options
CAD drafting DRAWING DESIGN 159
Template – Selecting the wall structure template.Type – Wall Type: wall or partition.
Floor – Choose the floor
Height – The height of the wall.
Representation – The representation in the drawing.
Normal
Simple (without hatch)
Contour
CAD software DRAWING DESIGN 160
CAD drawing DRAWING DESIGN 161
CAD drafting DRAWING DESIGN 162
The composition of the wall
All parameters of the wall you can set your own or choose from option “Template”. The template determines the composition of the wall, its width and height. If the user changes any of these settings, the connection is lost with the template.
CAD software DRAWING DESIGN 163
The composition of the wall is controlled by commands:
CAD drawing DRAWING DESIGN 164 – Wall’s materials. Opens the “Wall Material” dialog box, where you can see and edit the list of available materials.
CAD drafting DRAWING DESIGN 165 – Add layer. Create a new blank layer as a part of the wall. In the column “Material” it is necessary to choose the desired material from the dropdown list. Layer Priority will determine how cleanup schedules at the intersection of walls: a layer with a higher priority is displayed on top of the layer with a lower priority.
Important!
The last layer of the wall fills the remaining space inside the wall, regardless of the specified width.
CAD software DRAWING DESIGN 166 – Remove layer. Removes a layer from the walls.
CAD drawing DRAWING DESIGN 167 – Hatch. It allows you to create or change the shading layer.
CAD drafting DRAWING DESIGN 168 – Move up. Moves in the list of layers of the active layer on the line above.
CAD software DRAWING DESIGN 169 – Move down. Moves in the list of layers of the active layer on the line below.
CAD drawing DRAWING DESIGN 170 – Flip wall. Visually changes the order of the layers of the wall.
Editing walls
Convert to wall
CAD drafting DRAWING DESIGN 171Main menu: Construction – Architecture -Wall Edit – CAD software DRAWING DESIGN 172Convert to Wall….
CAD drawing DRAWING DESIGN 173Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 174Convert to Wall….
CAD software DRAWING DESIGN 175Toolbar: Architecture – CAD drawing DRAWING DESIGN 176Convert to Wall….
CAD drafting DRAWING DESIGN 177Command line: SPWALLCONV.
Command allows you to convert the wall lines and arcs.
Call the command and specify the primitives for conversion. In the dialog box, specify the required parameters of the wall.
At the end of the command, specify the delete source primitives or not.
CAD software DRAWING DESIGN 178
Wall modifier
CAD drawing DRAWING DESIGN 179Main menu: Construction – Architecture -Wall Edit – CAD drafting DRAWING DESIGN 180Add Wall Modifier.
CAD software DRAWING DESIGN 181Ribbon: Construction – Architecture – CAD drawing DRAWING DESIGN 182Add Wall Modifier.
CAD drafting DRAWING DESIGN 183Toolbar: Architecture – CAD software DRAWING DESIGN 184Add Wall Modifier.
CAD drawing DRAWING DESIGN 185Command line: SPWALLMODADD.
CAD drafting DRAWING DESIGN 186Library: Architecture – Modifiers
CAD software DRAWING DESIGN 187
When using a build modifier of base elements, you can choose different configuration object.
CAD drawing DRAWING DESIGN 188
To connect the modifier to the wall run the mouse pointer across any wall modifier bound to the walls. To unbind modifier from the wall or tie it again, you can through the context menu commands Attach/Detach.
CAD drafting DRAWING DESIGN 189
Convert to wall modifier
CAD software DRAWING DESIGN 190Main menu: Construction – Architecture -Wall Edit – CAD drawing DRAWING DESIGN 191Convert to Wall Modifier.
CAD drafting DRAWING DESIGN 192Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 193Convert to Wall Modifier.
CAD drawing DRAWING DESIGN 194Toolbar: Architecture – CAD drafting DRAWING DESIGN 195Convert to Wall Modifier.
CAD software DRAWING DESIGN 196Command line: SPWALLMODCONV.
Command is working as follows:
· After launch the command you need to select objects on the drawing; · Specify insertion point.After that, the user-created modifier can be used as ordinary modifier from database, but its graphics and parameters are fixed.
Join wall
CAD drawing DRAWING DESIGN 197Main menu: Construction – Architecture -Wall Edit – CAD drafting DRAWING DESIGN 198Join.
CAD software DRAWING DESIGN 199Ribbon: Construction – Architecture – CAD drawing DRAWING DESIGN 200Join.
CAD drafting DRAWING DESIGN 201Toolbar: Architecture – CAD software DRAWING DESIGN 202Join.
CAD drawing DRAWING DESIGN 203Command line: SPWALLJOIN.
The team brings together two walls in one. The properties of the final wall will be taken to that the command was specified first.
CAD drafting DRAWING DESIGN 204
CAD software DRAWING DESIGN 205
CAD drawing DRAWING DESIGN 206
Break the wall
CAD drafting DRAWING DESIGN 207Main menu: Construction – Architecture -Wall Edit – CAD software DRAWING DESIGN 208Break.
CAD drawing DRAWING DESIGN 209Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 210Break.
CAD software DRAWING DESIGN 211Toolbar: Architecture – CAD drawing DRAWING DESIGN 212Break.
CAD drafting DRAWING DESIGN 213Command line: SPWALLBREAK.
Command allows you to break the wall into several sections. The mouse cursor indicates the point of decomposition.
CAD software DRAWING DESIGN 214
CAD drawing DRAWING DESIGN 215
When the command completes space partition walls are not visible, and see how there can be a partition of the individual segments were selected.
CAD drafting DRAWING DESIGN 216
Extend wall
CAD software DRAWING DESIGN 217Main menu: Construction – Architecture -Wall Edit – CAD drawing DRAWING DESIGN 218Extend.
CAD drafting DRAWING DESIGN 219Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 220Extend.
CAD drawing DRAWING DESIGN 221Toolbar: Architecture – CAD drafting DRAWING DESIGN 222Extend.
CAD software DRAWING DESIGN 223Command line: SPWALLEXTEND.
Wall extends to the nearest intersection.
The first step in the implementation of both teams are selected object.
CAD drawing DRAWING DESIGN 224
Then you must specify the object you want to extend. The facility will be completed before crossing.
CAD drafting DRAWING DESIGN 225
CAD software DRAWING DESIGN 226
If, after calling the command instead of selecting objects press space bar on the keyboard, then, were selected for the second stage of the command wall, will be extended to the nearest intersection.
Trim wall
CAD drawing DRAWING DESIGN 227Main menu: Construction – Architecture -Wall Edit – CAD drafting DRAWING DESIGN 228Trim.
CAD software DRAWING DESIGN 229Ribbon: Construction – Architecture – CAD drawing DRAWING DESIGN 230Trim.
CAD drafting DRAWING DESIGN 231Toolbar: Architecture – CAD software DRAWING DESIGN 232Trim.
CAD drawing DRAWING DESIGN 233Command line: SPWALLTRIM.
CAD drafting DRAWING DESIGN 234
Mouse indicate the portion of the wall that you want to crop.
CAD software DRAWING DESIGN 235
CAD drawing DRAWING DESIGN 236
If, after calling the command instead of selecting objects, press space bar on the keyboard, then, were selected for the second stage of the command wall will be cut to the nearest intersection.
Make Corner
CAD drafting DRAWING DESIGN 237Main menu: Construction – Architecture -Wall Edit – CAD software DRAWING DESIGN 238Make Corner.
CAD drawing DRAWING DESIGN 239Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 240Make Corner.
CAD software DRAWING DESIGN 241Toolbar: Architecture – CAD drawing DRAWING DESIGN 242Make Corner.
CAD drafting DRAWING DESIGN 243Command line: SPWALLCORNER.
Command allows you to create the angle between the walls.
CAD software DRAWING DESIGN 244
Both walls are selected alternately, the angle between them to be formed. selection order does not matter.
CAD drawing DRAWING DESIGN 245
CAD drafting DRAWING DESIGN 246
Window
CAD software DRAWING DESIGN 247Main menu: Construction – Architecture – CAD drawing DRAWING DESIGN 248Add Window.
CAD drafting DRAWING DESIGN 249Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 250Add Window.
CAD drawing DRAWING DESIGN 251Toolbar: Architecture – CAD drafting DRAWING DESIGN 252Add Window.
CAD software DRAWING DESIGN 253Command line: SPWINDOWADD.
CAD drawing DRAWING DESIGN 254Library: Architecture – Windows
CAD drafting DRAWING DESIGN 255
Using the construction of the base elements of the window, you can choose different configurations for the object.
CAD software DRAWING DESIGN 256
A window can be constructed either as a separate entity or attached to a wall. Run the mouse pointer across any wall window bound to the walls. Detach from the window wall or tie it again, through the context menu commands Attach/Detach.
CAD drawing DRAWING DESIGN 257
Base point – allows you to change the position of the base point of the window. Click on the shortcut menu, you must specify the new position of the base point. Inserting an object distance is measured from the base point.
CAD drafting DRAWING DESIGN 258CAD software DRAWING DESIGN 259
Properties – opens a dialog box where you can specify the window dimensions.
CAD drawing DRAWING DESIGN 260
Analog – allows you to copy the properties of the window being created with the existing one.
Snap – the ability to bind to the window wall.
Unbind – allows user to detach from the window wall and build an independent object.
Reference – allows you to set the benchmark for accurate positioning of the window.
CAD drafting DRAWING DESIGN 261
Width – allows you to set the width of the window, indicating it on the drawing.
CAD software DRAWING DESIGN 262CAD drawing DRAWING DESIGN 263
Editing handles
Square blue knob lets you change the position of the window. Light blue arrows allow flipping of the window.
CAD drafting DRAWING DESIGN 264
Door
CAD software DRAWING DESIGN 265Main menu: Construction – Architecture – CAD drawing DRAWING DESIGN 266Add Door.
CAD drafting DRAWING DESIGN 267Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 268Add Door.
CAD drawing DRAWING DESIGN 269Toolbar: Architecture – CAD drafting DRAWING DESIGN 270Add Door.
CAD software DRAWING DESIGN 271Command line: SPDOORADD.
CAD drawing DRAWING DESIGN 272Library: Architecture – Doors
CAD drafting DRAWING DESIGN 273
Causing the construction of the base elements of the door, you can choose different configuration object.
The door can be constructed as a separate entity located or attached to a wall.When the command, as soon as the mouse crossed any wall, door is bound to the wall. Disconnecting from the walls is possible through the context menu commands.
Base point – allows you to change the position of the reference point door. Clicking on the shortcut menu, you must specify the new position of the base point. Inserting an object distance is calculated from the base point.
Flip horizontally – deploys an object horizontally.
Flip vertically – expands vertically.
Properties – opens the door to a dialogue where you can set the width of the door.
CAD software DRAWING DESIGN 274
Analog – to copy properties of the future with the existing door.
Snap – the ability to bind the door to the wall.
Unbind – allows to decouple the door from the wall and build an independent object.
Reference – allows you to set the benchmark for accurate positioning door.
CAD drawing DRAWING DESIGN 275
Width – allows you to specify the width of the door, indicating it in the drawing.
CAD drafting DRAWING DESIGN 276CAD software DRAWING DESIGN 277
Editing grips
Square blue knob lets you change the position of the door. Light blue arrows allow flip door.
CAD drawing DRAWING DESIGN 278
Column
CAD drafting DRAWING DESIGN 279Main menu: Construction – Architecture – CAD software DRAWING DESIGN 280Add Column.
CAD drawing DRAWING DESIGN 281Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 282Add Column.
CAD software DRAWING DESIGN 283Toolbar: Architecture – CAD drawing DRAWING DESIGN 284Add Column.
CAD drafting DRAWING DESIGN 285Command line: SPCOLUMNADD.
CAD software DRAWING DESIGN 286Library: Architecture – Columns
CAD drawing DRAWING DESIGN 287
Using the library you can select different types columns as your need.CAD drafting DRAWING DESIGN 288
The column is not attached to the wall, but the slewing angle is oriented to the nearest wall. Needed to build the object and show the command to specify the insertion point.
CAD software DRAWING DESIGN 289CAD drawing DRAWING DESIGN 290
CAD drafting DRAWING DESIGN 291
Rotate – allows you to set the angle of rotation of the column.
Base – allows you to change the position of the reference point of the column. Clicking on the shortcut menu, you must specify the new position of the base point.
Properties – opens a dialog column, where you can specify the column.
CAD software DRAWING DESIGN 292
Reference – allows you to set the starting point for accurate positioning of the column.
Editing handles
In the column there is only one handle, allowing movement of the object.
CAD drawing DRAWING DESIGN 293
Add Object
CAD drafting DRAWING DESIGN 294Main menu: Construction – Architecture – CAD software DRAWING DESIGN 295Add Object.
CAD drawing DRAWING DESIGN 296Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 297Add Object.
CAD software DRAWING DESIGN 298Toolbar: Architecture – CAD drawing DRAWING DESIGN 299Add Object.
CAD drafting DRAWING DESIGN 300Command line: SPOBJECTADD.
CAD software DRAWING DESIGN 301Library: Architecture – Planar objects
CAD drawing DRAWING DESIGN 302
Database elements required can choose the type of object.
Construction of the facility plan can be directed to the wall. To do this, move the cursor to the wall and change its angle according to the angle of the wall.
CAD drafting DRAWING DESIGN 303CAD software DRAWING DESIGN 304
CAD drawing DRAWING DESIGN 305
Rectangle – allows you to set the angle of rotation of the object.
Base – allows you to change the position of the reference point of the object. Clicking on the shortcut menu, you must specify the new position of the base point.
Properties – opens the Properties dialog box of the object if the object has editable properties.
CAD drafting DRAWING DESIGN 306
Reference – allows you to set the benchmark for accurate positioning of the object.
Editing handles
The object plan usually has only one handle, which moves the object.
Stairs
CAD software DRAWING DESIGN 307Main menu: Construction – Architecture – CAD drawing DRAWING DESIGN 308Stairs.
CAD drafting DRAWING DESIGN 309Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 310Stairs.
CAD drawing DRAWING DESIGN 311Toolbar: Architecture – CAD drafting DRAWING DESIGN 312Stairs.
CAD software DRAWING DESIGN 313Command line: SPSTAIRADD.
Stairs include linear and arc segments. For building arc section you need to select Arc in context menu.
CAD drawing DRAWING DESIGN 314
After that in context menu will be options for creating arc available.
CAD drafting DRAWING DESIGN 315
Line – starts mode for creating linear segments.
Bulge – starts mode for specifying first, middle and end points of arc.
Center – starts mode for specifying center, start and end point of arc.
Besides these there are following options available:
Rectangle – starts mode for creating stairs by specifying rectangle.
Width – allows to specify width of stairs by selecting it on the drawing.
CAD software DRAWING DESIGN 316
Axis – switches position of point of insertion of stairs (Left, Center, Right).
Properties – opens stairs’ dialogue.
Match – allows to copy properties of current stairs from existing one.
Reference – allows to create stairs from any reference point on specified distance.
To create stairs you have to specify required parameters in properties panel.
CAD drawing DRAWING DESIGN 317
Room
CAD drafting DRAWING DESIGN 318Main menu: Construction – Architecture – CAD software DRAWING DESIGN 319Room.
CAD drawing DRAWING DESIGN 320Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 321Room.
CAD software DRAWING DESIGN 322Toolbar: Architecture – CAD drawing DRAWING DESIGN 323Room.
CAD drafting DRAWING DESIGN 324Command line: SPROOM.
1. Call the command.
2. Select the construction method (from the context menu or from the command line).
Variants of “rooms”:
· Full – Automatically detects the contour of the room along the closed contour of the walls and without taking into account the inner islands. · cLear – Automatically defines a room outline along a closed wall contour, taking into account internal islands. · Rectangle – Mode of building a room in the form of a rectangle. · Polyline – Creates a room by specifying an existing polyline. · Contour -Freeform room construction mode with the ability to create arc segments. Switching between arc and straight line segments is also called via the context menu. · Magnet – Allows you to create rooms with complex shapes, automatically defining the shape of the contour segments. Pick the first point of the contour, then move the mouse cursor close to the existing walls or contour. · mUltiple contours – Switches to the mode of building a room consisting of several contours. · One contour – Switches to the mode of building a room consisting of one contour.3. Build the room using the chosen method.
4. After creating a room, the “Room” dialog box opens.
Dialog
After defining the outline, the “Room” dialog box opens.
CAD software DRAWING DESIGN 325
Toolbar
CAD drawing DRAWING DESIGN 326“Hatch modify” – calls the room hatch editing dialog.
CAD drafting DRAWING DESIGN 327Overridden area – starts the room selection process.
The dialog has 2 tabs:
· Parameters · FinishingParameters
Tab “Parameters” allows you to change the display settings of various elements of the room, assign different space groups, as well as the geometric parameters of the room.
CAD software DRAWING DESIGN 328
Basic
Name – sets the name of the room that is displayed when the corresponding mark is applied.
Number – changes the value of the room number when the corresponding mark is applied.
Category – sets the room category.
Group of rooms – sets the room group.
Floor – sets the number of storeys in the room.
Rooms appartment types – sets the type of apartment.
Show contour – controls the display of a selected or newly constructed room. By default, rooms are displayed without a border, only as marks.
Floor mark – sets the value of the floor mark.
Geometry
Height – room height, assigned individually for each room.
Area – room area, calculated parameter.
Perimeter – perimeter of the room, calculated parameter.
Capacity – room volume, calculated parameter.
Markers
On the right side of the “Parameters” tab there is a list of markers that can be added to indicate a room. The highlighted marker is displayed in the preview window.
The number of selectable markers for placement is limited only by the list.
The markers “The name and the area”, “Room number”, “Area” are part of the room, the rest of the markers are tied to the room. Anchored markers can be edited and deleted directly in the drawing.
Finishing
On the “Finishing” tab, interior elements are indicated with an indication of finishing materials and calculation of areas. When creating a room, the finishing list is generated automatically, taking into account all openings.
CAD drawing DRAWING DESIGN 329
Table columns
· Element – selectable finishing element. · Finishing – selection of the type of finishing produced. · Height, mm – element height, the field is available for editing when the “Wall area: Default group” value is selected in the “Calculate” column. · Wall finishing thickness, mm – entering the thickness of the finish, the field is available for editing when you select the values “Area”, “Wall area: Default group” and “Perimeter” in the “Calculate” column. · Area, m2 – input of the finishing area, the field is available for editing when the “Modifier” and “Opening” values are selected in the “Calculate” column, for other values the area is calculated automatically. · Calculate – this column sets the type of finishing calculation. Each item from the list has its own calculation type. · Note – text box for entering a note on the trim element.Toolbar
· CAD drafting DRAWING DESIGN 330Add – button for adding finishing line. Adds a line identical to the selected line. The line immediately following the selected line is added. · CAD software DRAWING DESIGN 331Delete – removing finishing line button. Deletes the selected line. · CAD drawing DRAWING DESIGN 332Up – button for changing the order of lines. Moves the selected line up one. · CAD drafting DRAWING DESIGN 333Down – button for changing the order of lines. Moves the selected line down one line. · CAD software DRAWING DESIGN 334Save as default finishing – button for saving the finishing pattern. A saved finishing list will be created by default in every new room. · CAD drawing DRAWING DESIGN 335Wall group selector – allows you to create an additional group of walls and interior walls with a finish other than the “Walls and interior walls“element. When the command is activated, an additional panel for configuring wall groups is displayed.CAD drafting DRAWING DESIGN 336
The panel consists of a list of groups and a graphic window.
The list of groups is used to display, add and edit groups. There is a “Default group” group in the list. This group belongs to the “Walls and interior walls” element and cannot be deleted. The list is controlled by three buttons:
· CAD software DRAWING DESIGN 337New wall group – Adds a new empty group to the group list and a new element with the same name to the trim list. The name of the group is changed directly in the list of groups by pressing the highlighted group again. · CAD drawing DRAWING DESIGN 338Delete wall group – Removes a group from the list. All walls that belong to the group will be moved to the “Default group”. You cannot delete the “Default group”. · CAD drafting DRAWING DESIGN 339Get from drawing – The command allows you to specify the walls of the group directly in the drawing, similar to the selection in the graphics window.The graphic window for selecting walls is necessary for displaying and specifying the walls included in the group. To add or remove a wall from a group, click LMB on the required wall. When a wall is added to a group, the wall will be moved from the group in which it was previously, when deleted, it is moved to the “Default group”.
Explication
Explication of rooms
CAD software DRAWING DESIGN 340Main menu: Construction – Architecture – Schedules – CAD drawing DRAWING DESIGN 341Shedule of rooms.
CAD drafting DRAWING DESIGN 342Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 343Shedule of rooms.
CAD drawing DRAWING DESIGN 344Toolbar: Architecture – CAD drafting DRAWING DESIGN 345Shedule of rooms.
CAD software DRAWING DESIGN 346Command line: SPEXPLROOMS.
For the formation of Explication of rooms after calling the command to all premises were selected to be included in the statement.
CAD drawing DRAWING DESIGN 347
CAD drafting DRAWING DESIGN 348
Sheet of decorations
CAD software DRAWING DESIGN 349Main menu: Construction – Architecture – Schedules – CAD drawing DRAWING DESIGN 350Sheet of Decoration.
CAD drafting DRAWING DESIGN 351Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 352Sheet of Decoration.
CAD drawing DRAWING DESIGN 353Toolbar: Architecture – CAD drafting DRAWING DESIGN 354Sheet of Decoration.
CAD software DRAWING DESIGN 355Command line: SPTABLEROOMS.
For the preparation of list of decorations after the call of command to you need to select rooms to be included in the statement. A dialog box with the options to customize data sorting is appeared.
CAD drawing DRAWING DESIGN 356
Settings for table generation and grouping:
· By storeys: Do not display \Column + union \Title · By quarters: Do not display \Group · By groups of rooms: Do not display \Group \Merge · Show in Name column: Name space \ number and name spaceWhen selecting settings on the floors: Do not print, the flats: Do not display by category spaces: Do not display – displays the source table as is.
In the dialog box, you can delete unwanted items in statement finishes.
Double-clicking on a table placed in the drawing, a dialog box opens Gazette decoration, ie at any point in the table can be edited to change the output options and grouping data.
List of openings
CAD drafting DRAWING DESIGN 357Main menu: Construction – Architecture – Schedules – CAD software DRAWING DESIGN 358List of openings.
CAD drawing DRAWING DESIGN 359Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 360List of openings.
CAD software DRAWING DESIGN 361Toolbar: Architecture – CAD drawing DRAWING DESIGN 362List of openings.
CAD drafting DRAWING DESIGN 363Command line: SPLISTOFOPENINGS.
Command to generate a list of all allocated openings in the drawing.
After running the command you need to select the insertion point of the table.
Then select the openings included in the statement. To do this, select a region (rectangle) all necessary doorways.
Important!
In order to correctly fill the list of openings the openings on the drawing must have different positions.
List of columns
CAD software DRAWING DESIGN 364Main menu: Construction – Architecture – Schedules – CAD drawing DRAWING DESIGN 365List of columns.
CAD drafting DRAWING DESIGN 366Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 367List of columns.
CAD drawing DRAWING DESIGN 368Toolbar: Architecture – CAD drafting DRAWING DESIGN 369List of columns.
CAD software DRAWING DESIGN 370Command line: SPLISTOFCOLUMNS.
Command formation for all selected columns specification drawing.
Then select the columns that are included in the specification. To do this, select a region (rectangle) all the necessary columns.
CAD drawing DRAWING DESIGN 371
List of materials
CAD drafting DRAWING DESIGN 372Main menu: Construction – Architecture – Schedules – CAD software DRAWING DESIGN 373Materials List.
CAD drawing DRAWING DESIGN 374Ribbon: Construction – Architecture – CAD drafting DRAWING DESIGN 375Materials List.
CAD software DRAWING DESIGN 376Toolbar: Construction Architecture – CAD drawing DRAWING DESIGN 377Materials List.
CAD drafting DRAWING DESIGN 378Command line: SPLISTOFCOLUMNS.
1. Call command CAD software DRAWING DESIGN 379“Materials List”.
2. Select the walls and confirm the selection with the “Enter” key.
3. Position the bill of materials you created on the drawing. If the selected walls do not have a wall composition with materials, the list of materials will not be created.
Graphics
Similar object
CAD drawing DRAWING DESIGN 380Main menu: Construction -Architecture – Graphics – CAD drafting DRAWING DESIGN 381Similar object.
CAD software DRAWING DESIGN 382Ribbon: Construction – Architecture – CAD drawing DRAWING DESIGN 383Similar object.
CAD drafting DRAWING DESIGN 384Command line: SPSIMILAROBJECT.
The command is used to create parallel lines, concentric arcs and circles.
1. Call the CAD software DRAWING DESIGN 385“Similar object” command.
2. Specify the object on the drawing for which you want to create a similar one.
3. Specify the position of the new object.
Symmetrical rectangle
CAD drawing DRAWING DESIGN 386Main menu: Construction -Architecture – Graphics – CAD drafting DRAWING DESIGN 387Symmetrical rectangle.
CAD software DRAWING DESIGN 388Ribbon: Construction – Architecture – CAD drawing DRAWING DESIGN 389Symmetrical rectangle.
CAD drafting DRAWING DESIGN 390Command line: SPRECT.
The command allows you to insert axisymmetric rectangles into the drawing, which are closed polylines.
1. Call the CAD software DRAWING DESIGN 391“Symmetrical rectangle” command. The “Axisymmetric rectangle” dialog opens.
CAD drawing DRAWING DESIGN 392
2. In the “Axisymmetric rectangle” dialog box, specify the required dimensions for the rectangle.
3. Specify the insertion point in the graphic field of the dialog box (on the left) (the current insertion point is marked with a red square).
4. Set the modes if necessary:
“Specify rotation angle” – when inserting a rectangle, it will be possible to rotate the rectangle relative to the insertion point;
“Copy rectangle” – after inserting a rectangle, it is proposed to insert copies of it;
“Create dimensions” – sets the overall dimensions of the rectangle.
5. Confirm the changes with the “OK” button.
6. Place the rectangles on the drawing. Placement of rectangles on the drawing is done cyclically. To complete the command, press the “Enter” key.
CAD drafting DRAWING DESIGN 393
Import IFC plans
CAD software DRAWING DESIGN 394Main menu: Construction – Architecture – CAD drawing DRAWING DESIGN 395Import IFC plans.
CAD drafting DRAWING DESIGN 396Ribbon: Construction – Architecture – CAD software DRAWING DESIGN 397Import IFC plans.
CAD drawing DRAWING DESIGN 398Command line: SPIMPORTIFCPLANS.
The command allows you to import a plan of an architectural object from an IFC file. Plans are formed from objects nanoCAD Construction .
Important!
Before importing, make sure that you have the database of elements connected, as it contains objects nanoCAD Construction .
1. Call command CAD drafting DRAWING DESIGN 399“Import IFC plans”.
2. In the browser, select the IFC file from which the import will be made.
3. Wait a while while the plans are imported. The larger the file, the longer the import will take.
4. Plans will be built on the drawing. They will include: Formats, axes, walls, windows, doors and other architectural objects nanoCAD Construction .
CAD software DRAWING DESIGN 400
Engineering networks
Equipment
CAD drawing DRAWING DESIGN 401Main menu: Construction – Communications – CAD drafting DRAWING DESIGN 402Equipment.
CAD software DRAWING DESIGN 403Toolbar: Communications – CAD drawing DRAWING DESIGN 404Equipment.
CAD drafting DRAWING DESIGN 405Command line: SPEQUIPMENT.
This command is used to insert the object “Equipment” from Template library.
Insertion
1. Call the command insertion equipment. You will be prompted to leave the last used equipment from a library of templates, or if there is no such equipment by default.
CAD software DRAWING DESIGN 406
2. Select the necessary equipment if needed. To do this in the context menu, select “Dialog”. On the form template library to select the necessary equipment and confirm.
CAD drawing DRAWING DESIGN 407
3. Select the base point and the direction of insertion.
4. Continue to insert the same type of objects equipment (item 1,2,3) or end (press Enter).
Note:
Equipment, trace and ports when inserting receive a unique number (the “Number” in the properties)
Editing
Edit location
CAD drafting DRAWING DESIGN 408
The object “Equipment” has two grips:
· Grip moving- it allows you to move an object, · Grip directions- changes the direction of the object.Editing options
Call for editing by choosing from the context menu of a selected object the command “Edit” or double-clicking on the object editing.
When you call opens the edit form, this form Template library.
The process of editing an object “Equipment” is similar to the process of editing the template “equipment”.
Save as Template
If you want to save the object “Equipment” as a template to be:
· In the form of editing select “Save as Template” CAD software DRAWING DESIGN 409. · In the form of “Create element” and enter the name of the note. · Confirm entry. The equipment will be added to the Template library.CAD drawing DRAWING DESIGN 410
Trace
CAD drafting DRAWING DESIGN 411Main menu: Construction – Communications – CAD software DRAWING DESIGN 412Trace.
CAD drawing DRAWING DESIGN 413Toolbar: Communications – CAD drafting DRAWING DESIGN 414Trace.
CAD software DRAWING DESIGN 415Command line: SPTRACE.
This command is used for laying tracks between objects “Port” and “Equipment”. The trace is taken from Template library.
Insertion
1. Call the command inserts trace. You will be prompted to insert the last used trace from the template library, or, if not, the default trace.
2. Select the right trace, if necessary. To do this in the context menu, select “Dialog”. On the form template library select the desired trace and confirm.
CAD drawing DRAWING DESIGN 416
3. Select the first object anchor. If the type of connection trace and the connection type of the object (trace, equipment or port) will be the same, then the object will be highlighted.
CAD drafting DRAWING DESIGN 417
4. Select the second object.
CAD software DRAWING DESIGN 418
5. Continue inserting trace (paragraph 1,2,3,4) or end (press Enter).
Note:
Editing
Edit location
CAD drawing DRAWING DESIGN 419
The object “Port” has 3 grips:
· Grip parallel transfer – it allows you to move an object parallel to the fixed position, · Grip adding vertices – adds the top of the object, · Grip stretch – modifies the provisions of the basic points of the object.Editing options
The process of editing the object “Trace” is similar to the process of editing the template “Trace”.
Save as Template
If you want to save the object “Trace” as a template to be:
· In the form of editing select “Save as Template” CAD drafting DRAWING DESIGN 420. · In the form of “Create element” and enter the name of the note. · Confirm entry. The equipment will be added to the Template library.CAD software DRAWING DESIGN 421
Port
CAD drawing DRAWING DESIGN 422Main menu: Construction – Communications – CAD drafting DRAWING DESIGN 423Port.
CAD software DRAWING DESIGN 424Toolbar: Communications – CAD drawing DRAWING DESIGN 425Port.
CAD drafting DRAWING DESIGN 426Command line: SPPORT.
This command is used to insert the object “Port” of Template manager.
Insertion
1. Call the command insert the connector. You will be prompted to insert the connector of the last used template library, or, if not, the port by default.
CAD software DRAWING DESIGN 427
2. Select the appropriate connector if necessary. To do this in the context menu, select “Dialog”. On the form template library select the port and confirm the selection.
CAD drawing DRAWING DESIGN 428
4. Continue to insert the ports (point 1,2,3) or end (press Enter).
Note:
Editing
Edit location
CAD drafting DRAWING DESIGN 429
The object “Port” has two grips:
The process of editing the object “Port” is similar to the process of editing the template “Port”.
Save as Template
If you want to save the object “Port” as a template to be:
· In the form of editing select “Save as Template” CAD software DRAWING DESIGN 430. · In the form of “Create element” and enter the name of the note. · Confirm entry. The equipment will be added to the Template library.CAD drawing DRAWING DESIGN 431
Table of connections
CAD drafting DRAWING DESIGN 432Main menu: Construction – Communications – CAD software DRAWING DESIGN 433Table of connections.
CAD drawing DRAWING DESIGN 434Toolbar: Communications – CAD drafting DRAWING DESIGN 435Table of connections.
CAD software DRAWING DESIGN 436Command line: SPPORTTABLE.
Table of connections allows to connect a conditional links between ports.
These compounds are primarily needed to automatically trace divorce.
Dilogue
CAD drawing DRAWING DESIGN 437
The form of dialogue “ConnectorsTableForm” consists of two overlapping lists. This is done for the convenience of the binding.
Each is equipped with a list of commands:
· Filer – opens the panel filter for columns. It used to filter the list. · Columns – customizable columns. · Remove selected links – remove links from the selected object.The columns
Number – indicates the sequence number of the object
Template – a template in which the object was created
Equipment -the equipment to which it belongs port
Connection – a list of numbers of objects to which a view objects.
Note:
Sign “?” – It is not defined
Linking objects
To assign a connection to another object should be:
1. Select the object. Press and hold the left mouse button.
2. Lead one to connect objects. You can move an object in the same list and in the backup.
3. Lower the left mouse button. The object will be contacted and a mix of both fields to add a number of objects connected to the objects.
Note:
When going through the list of object over which the mouse cursor will be highlighted in the drawing. This allows you to verify the correctness of the choice of object.
Delete links
2. Call the popup menu
3. From the pop-up menu, choose the remote connection, or “All”.
Showing links in the drawing
In imposing relations on the drawing shown links between objects on the non-printed layer “ISO_UNPLOTTED”.
CAD drafting DRAWING DESIGN 438
Automatic tracing
CAD software DRAWING DESIGN 439Main menu: Construction – Communications – CAD drawing DRAWING DESIGN 440Automatic tracing.
CAD drafting DRAWING DESIGN 441Toolbar: Communications – CAD software DRAWING DESIGN 442Automatic tracing.
CAD drawing DRAWING DESIGN 443Command line: SPTRACINGADD.
Team automatically separates trace on the already established relations between ports.
The guide trace
In order to build the correct trace, it is necessary to construct the auxiliary directional trace, which may for example, be positioned along the walls.
Auxiliary trace – trace which is set to “Directional trace” (“Yes”).
Building trace
To build trace should:
1. Select the command “Automatic tracing”
2. Specify equipment, ports and directional trace, or select all of the active network by pressing “Enter”.
CAD drafting DRAWING DESIGN 444
If there is no specified equipment and ports or derectional trace, a dialog appears offering to separate trace on the network.
CAD software DRAWING DESIGN 445
5. After selecting objects in the dialog “Connection Type” select the types of connections through which trace should be diluted.
CAD drawing DRAWING DESIGN 446
6. Confirm your selection. The trace is automatically built according to the design rules.
CAD drafting DRAWING DESIGN 447
Note:
If the guide has the same pattern as the communications facilities, communications facilities will be connected to the rail.
If necessary, you can cancel by trace, rail and adjust the command again or manually edit the trace built.
Template library
CAD software DRAWING DESIGN 448Main menu: Construction – Communications – CAD drawing DRAWING DESIGN 449Template library.
CAD drafting DRAWING DESIGN 450Toolbar: Communications – CAD software DRAWING DESIGN 451Template library.
CAD drawing DRAWING DESIGN 452Command line: SPEQUIPMENTLIBRARY.
Form template library is required to work with templates of engineering networks (add, edit, delete) and consists of three parts: a panel of wood patterns, the list of designated parameters, the panel attributes.
CAD drafting DRAWING DESIGN 453
Tree patterns
Tab templates
Tree patterns is divided into 3 main sections: ports, traces and equipment. In each section of the corresponding templates are added.
Switch notes whether the pattern present when editing the parameter list. When the level of several patterns of one type, the parameters will change them together.
Each type of template tab gets its parameter list.
Important!
When you activate the equipment, its ports automatically added to the list of options on the “Connectors”.
Replacing graphic
When you select a particular pattern, its schedule will be displayed in the “Preview panel” below.
Displaying the setting knob CAD software DRAWING DESIGN 454“Preview panel”.
CAD drawing DRAWING DESIGN 455
To change the schedule template should:
1. Activate pattern
2. Press button CAD drafting DRAWING DESIGN 456“Select graphics”
3. Specify the new graphics and confirm (press Enter)
4. Specify the insertion point and confirm (press Enter)
Adding template
The CAD software DRAWING DESIGN 457“New template” adds a new template is selected in the tree section.
When you run the command, the creation of a form of the element, which you must specify the location to save the template in the database elements, name, note and confirm.
CAD drawing DRAWING DESIGN 458
The new template is added to the appropriate section.
Important!
For the “Equipment” and “Port” do not forget to specify the schedule. If the schedule is not specified, will use the default schedule.
Note:
To add a template is better to use separate rooms creating Equipment, Trace and Port
Delete template
The CAD drafting DRAWING DESIGN 459“Erase template” deletes the selected object in the tree. Section can not be deleted.
Save as template
The “Save as template” is active when editing objects Equipment and port, and allows you to save the object as a template.
Tab Labels
In the tab “Labels”, you specify which tags will be added to the objects in the inset to the drawing.
The number of labels can be more than one for each type of template.
Note:
Library displays the label of the folder “Library” specified in the settings.
CAD software DRAWING DESIGN 460
Parameter List
The parameter list contains the settings of the selected template(s) and allows them to edit.
The parameter list is divided tabs: Connectors, Traces, Equipments. Each tab displays the parameters of ports, traces, equipments, respectively. Options ports belonging to the equipment are displayed on the “Connectors”. All three tabs are similar.
CAD drawing DRAWING DESIGN 461
Adding an attribute
Adding a new optional parameter is from the Control attributes for this:
1. Select attribute
2. Not omitting the left button to move the key attribute in the parameter list.
If the list of parameters are specified attributes for all templates defined species, and a new attribute will be added for all.
Re-attribute can not be added.
Edit attribute
The parameter list is divided into two parts: the left-name right – the input field.
Entry fields with a gray background can not be edited.
Remove attribute
emoval of property carried out by pressing the CAD drafting DRAWING DESIGN 462“Erase attribute” from the context menu of the selected attribute.
If the property can not be removed, the button will be disabled.
Panel attributes
Panel attribute contains additional parameters that may be added to the list of parameters by gripping and handling.
The panel is a two-level tree. The first level of the section, the second – the attribute.
If the panel does not need attributes, you can turn to the CAD software DRAWING DESIGN 463“attributes panel” (in the lower left corner of the form).
Adding properties
To add a parameter to the list of parameters necessary to:
1. Select an attribute
2. Do not omitting left button to transfer the key attribute in the parameter list.
Options properties
Attributes are divided into 3 types: CAD drawing DRAWING DESIGN 464Dropdown list, CAD drafting DRAWING DESIGN 465checkbox and CAD software DRAWING DESIGN 466editbox.
Finds
If you want to find a particular attribute, for this is the search.
CAD drawing DRAWING DESIGN 467
Search is provided with a field for entering text search, as well as buttons to navigate through the attributes found
Found attributes are marked in yellow.
CAD drafting DRAWING DESIGN 468
Create attribute
Creating an attribute is carried out from the editor library attributes. ButtonCAD software DRAWING DESIGN 469in the upper right corner.
Create trace
CAD drawing DRAWING DESIGN 470Main menu: Construction – Communications – CAD drafting DRAWING DESIGN 471Create trace.
CAD software DRAWING DESIGN 472Toolbar: Communications – CAD drawing DRAWING DESIGN 473Create trace.
CAD drafting DRAWING DESIGN 474Command line: SPCREATETRACE.
This command creates a new template trace and places it in Template library.
To create
1. Select command
2. A form will appear “Create element”, in which said storage elements in the base template, name, note and confirm the entered parameters.
CAD software DRAWING DESIGN 475
3. Next, open the edit form, this form Template library. The process of editing the template “Trace” is described in detail in the section Template library.
Create port
CAD drawing DRAWING DESIGN 476Main menu: Construction – Communications – CAD drafting DRAWING DESIGN 477Create port.
CAD software DRAWING DESIGN 478Toolbar: Communications – CAD drawing DRAWING DESIGN 479Create port.
CAD drafting DRAWING DESIGN 480Command line: SPCREATEPORT.
This command creates a new template port and places it in Template library.
To create
1. Select command
2. Show on drawing a new graphics for the port. Confirm your selection (press Enter). If the graphics is not selected, the grafics will be taken by default.
CAD software DRAWING DESIGN 481
3. Specify the base point of insertion port created.
CAD drawing DRAWING DESIGN 482
4. After specifying the form will be “Create element”, in which said storage elements in the base template, name, note and confirm the entered parameters.
CAD drafting DRAWING DESIGN 483
5. Next, open the edit form, this form Template library. The process of editing the template “Port” is described in detail in the section Template library.
Create equipment
CAD software DRAWING DESIGN 484Main menu: Construction – Communications – CAD drawing DRAWING DESIGN 485Create equipment.
CAD drafting DRAWING DESIGN 486Toolbar: Communications – CAD software DRAWING DESIGN 487Create equipment.
CAD drawing DRAWING DESIGN 488Command line: SPCREATEEQUIPMENT.
This command creates a new template equipment and places it in Template library.
To create
1. Create graphics equipment.
CAD drafting DRAWING DESIGN 489
2. Set the necessary ports. Subsequently, the interconnection of networks will be carried out between the ports.
CAD software DRAWING DESIGN 490
3. Select a team creation of the equipment.
4. Specify the drawing graphics with ports for the equipment. Confirm your selection (press Enter). If graphics and ports are not selected, the grafics will be taken by default.
CAD drawing DRAWING DESIGN 491
5. Specify the base point of the insertion created equipment.
CAD drafting DRAWING DESIGN 492
6. After specifying the form will be “Create element”, in which said storage elements in the base template, name, note and confirm the entered parameters.
CAD software DRAWING DESIGN 493
7. Next, open the edit form, this form Template library. The process of editing the template “Equipment” is described in detail in the section Template library.
Attribute library editor
Called from the edit form templates. It is necessary to create a new (missing) attribute.
CAD drawing DRAWING DESIGN 494
Dialog
Toolbar – Includes “search attribute” button and edit the attributes of a tree.
Attribute tree – It displays a list of available attributes for editing.
Properties window – It displays the properties of the attribute or class.
Adding an attribute
To add a command is carried out:
CAD drafting DRAWING DESIGN 495Add category
CAD software DRAWING DESIGN 496Add a textbox
CAD drawing DRAWING DESIGN 497Add checkbox
CAD drafting DRAWING DESIGN 498Add dropdown list
Adding an attribute or category is made in the selected category or parent category selected attribute.
Edit attribute
To change the location attribute in the tree attributes, attribute to press the left mouse button and drag it to the desired part of the tree.
To edit the properties of the attribute must be:
1. Select an attribute or category
2. Make changes in the “Paremeters window”:
For the category of available properties for the change:
Display Name – a name that will be displayed in the tree attributes.
For the “Editbox” properties are available for changing:
System name – work name attribute to identify it in the system (for example, when building reports).
Display name – a name that will be displayed in the tree attributes.
Control type – feature allows you to change the type attribute. Possible values: textbox, checkbox, dropdown list.
Data type – property defines the value of the type attribute will return.
Value – default value.
For the “Checkbox” properties are available for changing:
Data type – property defines the value of the type attribute will return (always Boolean).
Value – default value (Yes all No).
For the “Dropdown list” properties are available for changing:
List items – a list of possible values.
Fixed list – The default is “Yes”. Allow only values from the list by using the attribute. If you set to “No”, permits to enter their values in a list by using the attribute with the new values will be added to the list. It will also be available the “Maximum size of the list.”
Remove attribute
To delete an attribute you must:
1. Select a category, or delete attributes (by selecting a category remove all attributes included in it).
2. Press “CAD software DRAWING DESIGN 499Erase selected”.
Important!
You can not delete attributes from the category “Properties.” This will affect the further work with the utilities.
Sample create label
Create a label for equipment.
1. Insert equipment
CAD drawing DRAWING DESIGN 500
2. Add a note (eg, constructional note (spnotep))
3. The dialogue form editing notes to add the necessary fields to the drawing for this:
a) from the context menu of the field call the command “Pick from drawing”
CAD drafting DRAWING DESIGN 501
b)In the dialog box “Value picker” choose “Take from property”
CAD software DRAWING DESIGN 502
c) Specify the equipment and in the dialog box, select the desired option
CAD drawing DRAWING DESIGN 503
4. Confirm the settings notes and paste it to the drawing.
CAD drafting DRAWING DESIGN 504
5. From the context menu, select notes “Save object as template”
6. In the dialog box “Template Wizard”, click “Create template”
CAD software DRAWING DESIGN 505
7. Save the template in the base element according to the settings.
CAD drawing DRAWING DESIGN 506
8. Now create a label will be available in the “Labels” in “Equipment”
CAD drafting DRAWING DESIGN 507
Library
CAD software DRAWING DESIGN 508Library: Communications.
The objects of engineering networks (equipment, connectors, tracks) available in the template library are also available in the base of elements.
The section is divided into subsections by type of object: Equipment, Connectors, Routes.
Each subsection is divided by the type of network: domestic gas supply, ventilation, …
CAD drawing DRAWING DESIGN 509
Area
Net area by internal point
CAD drafting DRAWING DESIGN 510Command line: SPAREA.
The command allows you to calculate and build the net area by specifying the inner point of the closed contour.
1. Call the command. 2. Pick a point within the closed contour. The contour will be highlighted.CAD software DRAWING DESIGN 511
3. Specify the position of the text (area value). A dialogue “Area” will open.CAD drawing DRAWING DESIGN 512
4. In the dialogue “Area” customize the type of inscription and confirm with the “OK” button. The object area will be built.CAD drafting DRAWING DESIGN 513
Area by internal point
CAD software DRAWING DESIGN 514Command line: SPAREA1.
The command allows you to calculate and build the total area by specifying the inner point of a closed contour.
1. Call the command. 2. Pick a point within the closed contour. The contour will be highlighted.CAD drawing DRAWING DESIGN 515
3. Specify the position of the text (area value). A dialogue “Area” will open.CAD drafting DRAWING DESIGN 516
4. In the dialogue “Area” customize the type of inscription and confirm with the “OK” button. The object area will be built.CAD software DRAWING DESIGN 517
Area by rectangle
CAD drawing DRAWING DESIGN 518Command line: SPAREA2.
The command allows you to build an area by specifying the diagonal of a rectangle.
1. Call the command. 2. Pick the first corner point.CAD drafting DRAWING DESIGN 519
3. Pick the second corner point.CAD software DRAWING DESIGN 520
4. Specify the position of the text (area value). A dialogue “Area” will open.CAD drawing DRAWING DESIGN 521
5. In the dialogue “Area” customize the type of inscription and confirm with the “OK” button. The object area will be built.CAD drafting DRAWING DESIGN 522
Area by contour
CAD software DRAWING DESIGN 523Command line: SPAREA3.
The command allows you to build an area by specifying a contour.
1. Call the command. 2. Specify the starting point of the contour.CAD drawing DRAWING DESIGN 524
3. Pick subsequent points of the contour. To finish, press the “Enter” key, the contour will close automatically.CAD drafting DRAWING DESIGN 525
4. Specify the position of the text (area value). A dialogue “Area” will open.CAD software DRAWING DESIGN 526
5. In the dialogue “Area” customize the type of inscription and confirm with the “OK” button. The object area will be built.CAD drawing DRAWING DESIGN 527
Area(Text)
CAD drafting DRAWING DESIGN 528Command line: SPAREA4.
The command allows you to set the text label of the area.
1. Call the command. 2. Specify the position of the text (area value). A dialogue “Area” will open.CAD software DRAWING DESIGN 529
3. In the dialogue “Area” customize the type of inscription and confirm with the “OK” button. The object area will be built.CAD drawing DRAWING DESIGN 530
CAD drafting DRAWING DESIGN 531
Area by polyline
CAD software DRAWING DESIGN 532Command line: SPAREA5.
The command allows you to build an area by specifying a polyline.
1. Call the command. 2. Select a polyline in the drawing. An open polyline will be closed automatically.CAD drawing DRAWING DESIGN 533
3. Specify the position of the text (area value). A dialogue “Area” will open.CAD drafting DRAWING DESIGN 534
4. In the dialogue “Area” customize the type of inscription and confirm with the “OK” button. The object area will be built.CAD software DRAWING DESIGN 535
Area Editing Dialog
CAD drawing DRAWING DESIGN 536
The dialogue consists of:
1. Three text fields for entering explanatory text. Auxiliary commands are available in the context menu of text boxes for editing a label. The expression “<>” in fields is a reference to the calculated area value. In addition to entering the expression “<>” in the value fields to display the calculated area value, you can also use the “Face-value” context menu command.
2. The CAD drafting DRAWING DESIGN 537“Symbols” button calls the table of special symbols for insertion into the current cursor position of the edited input field.
3. The “Text height” input field indicates the height of the text font.
4. The switch “Show contour” controls the selection of the border of the measured area in the drawing.
5. The CAD software DRAWING DESIGN 538“Copy Property” button allows you to copy design parameters from another drawing object.
Form premises
CAD drawing DRAWING DESIGN 539Command line: SPQUARTERS.
The command creates a quarters object.
1. Call the command. The “Quarters” dialog will open.
CAD drafting DRAWING DESIGN 540
2. In the “Marker” group, select the type of marker (Type 1, Type 2 or Type 3).
3. Using the commands for creating areas in the “Measuaring square” group, draw the outline of the quarter.
4. Set the parameters, properties and category of the quarter.
5. Confirm the settings with the “OK” button.
6. Specify the position of the text.
8. The quarter will be built.
CAD software DRAWING DESIGN 541
Convert areas into rooms
CAD drawing DRAWING DESIGN 542Command line: SPCONVERTTOROOMS.
The command is used to change the object type “Area” to the object type “Space”.
2. Select the object(s) to transform in the drawing. Objects for transformation can be both “Areas” and “Quarters”.
CAD drafting DRAWING DESIGN 543
3. The selected objects will be converted to “Space” objects.
CAD software DRAWING DESIGN 544
Working with parametric objects
Working with Database Objects
Parts Library nanoCAD Construction 23 is a database and stored in a file with the extension * .mcs. By default, after installing nanoCAD Construction 23 used base recorded in a file in the folder std.mcs data, housed in the installation directory of the program nanoCAD Construction 23.
Select another database possible, specifying the desired file in the “Database access“option in the settingsnanoCAD Construction 23 “The path to the local database”.
Parts of the database can be exported as individual files, or import from external files into the current database of standard elements.
The basic tools for working with database objects
The basic tools for working with database objects are:
“Main menu- Construction – Library objects”
or on the toolbar “ Library objects”
CAD drawing DRAWING DESIGN 545
· CAD drafting DRAWING DESIGN 546Tab manager · CAD software DRAWING DESIGN 547Standard parts library · CAD drawing DRAWING DESIGN 548Reinsert object · CAD drafting DRAWING DESIGN 549Threaded fastening · CAD software DRAWING DESIGN 550Rivet joint · Markers, Groups · CAD drawing DRAWING DESIGN 551Insert group · CAD drafting DRAWING DESIGN 552Group objects · CAD software DRAWING DESIGN 553Add marker · CAD drawing DRAWING DESIGN 554Template wizard · Cover · CAD drafting DRAWING DESIGN 555Move up · CAD software DRAWING DESIGN 556Move down · CAD drawing DRAWING DESIGN 557Change hiden mode · CAD drafting DRAWING DESIGN 558Regenerate supression contours · Part trim · CAD software DRAWING DESIGN 559Add part trim · CAD drawing DRAWING DESIGN 560Remove part trim · CAD drafting DRAWING DESIGN 561Add view · CAD software DRAWING DESIGN 562Change representation · CAD drawing DRAWING DESIGN 563Mirrow part · CAD drafting DRAWING DESIGN 564Regenerate Std Parts · CAD software DRAWING DESIGN 565User defined objectTab Manager
CAD drawing DRAWING DESIGN 566Main menu: Construction – Library objects – CAD drafting DRAWING DESIGN 567Tab manager.
CAD software DRAWING DESIGN 568Ribbon: Construction – Library objects – CAD drawing DRAWING DESIGN 569Tab manager.
CAD drafting DRAWING DESIGN 570Toolbar: CAD software DRAWING DESIGN 571Tab manager (on toolbar “Library objects”).
CAD drawing DRAWING DESIGN 572Command line: SPTABS.
Object Manager nanoCAD Construction 23 includes the following tools:
· Manager database of standard objects · Objects · Pruning of standard parts · Finding and replacing text · Copying propertiesTab “Library”
Tab “Library” object manager is a universal means of access to the standard database objectsnanoCAD Construction 23.
Details in the database are classified according to their design purpose.
CAD drafting DRAWING DESIGN 573
Management and structure the database by using the toolbar and the context menu that includes the ability to add, delete, or rename folders.
Toolbar
· CAD software DRAWING DESIGN 574Del object. Removes the selected item or folder from the database · CAD drawing DRAWING DESIGN 575Add folder. Adds a folder to the database · CAD drafting DRAWING DESIGN 576Insert object. Performs insert the selected database object in the drawing · CAD software DRAWING DESIGN 577View. Includes preview of database objects · CAD drawing DRAWING DESIGN 578Search panel. It includes search bar facilities on base · CAD drafting DRAWING DESIGN 579Refresh. Updates the tree base in the object manager. Press this button after making changes to the databaseContext menu
The context menu has a different structure depending on call.
In the palette – the object context menu:
CAD software DRAWING DESIGN 580
In the palette – the context menu of a folder:
CAD drawing DRAWING DESIGN 581
“Add Folder” – adds the folder to a dedicated subsidiary. If the command was run on the selected object, the folder will be added to the parent folder object.
“Save object in database as dwf block” – This utility allows you to save a single database of the drawings in format dwg, including standard items nanoCAD Construction 23, design elements and primitives nanoCAD.
“Delete object” – This command deletes the selected object.
“Delete folder” – This command deletes the selected folder with all its contents.
“Rename” – The command allows you to rename an object (folder).
“Import object” – Adding to our previously exported file or folder object database DB.
To import a database from an external file, use the command “Import object” in the context menu invoked by a right-click on any folder or object in the section “Library” object manager. This will bring up a dialog box in which you specify the path to the file.
When importing compares the last modification date of the original (stored in the database) and the imported object. At concurrence of the imported content from content database objects will be updated only if they have more recent modification date.
If the command “Import object” was called for a standard lens, the outer fragment is imported to the folder containing the object.
CAD drafting DRAWING DESIGN 582
“Export object” – Save the file to disk or folder object database DB.
To export any portion of the database you should use the command “Export object”. In the resulting dialog box, then you need to specify the path and file name for saving the captured designated section base.
Note:
Import operation into the database or export from the database can be made as separate objects, and entire folders with libraries of parts.
“Send by email” – It creates an e-mail with an attachment – Export objects.
CAD software DRAWING DESIGN 583
“Copy” – Stored in a buffer object reference to paste a label on it.
“Paste shortcut” – Inserts a shortcut to a previously copied object
“Open with ScriptMaster” – Opens the object in the Object Wizard to edit.
“Add this folder palette” create a bookmark in the palette manager of the objects of the selected folder.
“Refresh” – Updating of the database (for example, after editing).
Tab “Objects”
Tab “Objects” object manager is a universal means of reviewing, monitoring, editing facilities nanoCAD Construction 23, are on the drawing.
Places on this tab are grouped into sections – for example, standard parts, callout, bolted connections, etc. In order to navigate in the drawing the selected object is highlighted.
CAD drawing DRAWING DESIGN 584
Toolbar
· CAD drafting DRAWING DESIGN 585 Edit object.It calls the dialog for editing the selected object · CAD software DRAWING DESIGN 586 Del object. Deletes the selected object · CAD drawing DRAWING DESIGN 587Refresh. Updates the list of objects. The button is used when adding or removing objects from the drawing · CAD drafting DRAWING DESIGN 588sQuick select. Search Tool nanoCAD Construction 23 objects in the drawing on the set parameters, run the command “Quick Pick” · CAD software DRAWING DESIGN 589Find and Replace. Open dialog boxFind and Replace.Context menu
In addition to the teams that are in the toolbar, the context menu of a selected object contains the following items depending on the selected object, and includes a team of repeating the context menu of the object on the drawing. Thus the tab “Objects” allows you to edit objects without having to search for them saturated drawing regardless of layer.
CAD drawing DRAWING DESIGN 590
For example, for sub-database nanoCAD Construction 23, further include items “Change representation”, “Bring to Front”, “Send to Back”, and “Change cover mode”.
Option “Hide” makes the selected object invisible in the drawing.
IFC viewer
CAD drafting DRAWING DESIGN 591Functional panel:IFC.
File viewer IFC (Industry Foundation Classes). IFC is used as the format for the information model building BIM (Building Information Modeling).
CAD software DRAWING DESIGN 592
Import models
1. Run the import command: · Button CAD drawing DRAWING DESIGN 593“Import” in the main function bar menu “IFC”. · Button “Import” in the tree. · CAD drafting DRAWING DESIGN 594Command line: IFCVIEW3D. 2. Select the IFC file and confirm.Begin analysis and file import nanoCAD environment. Download time depends on the capacity of the computer and the complexity of the file.
3. After importing the tree items will be available, obedennennoe in one project. When you import multiple serial models, the tree will be displayed several projects.CAD software DRAWING DESIGN 595
View models
Viewing patterns by using wood elements.
When you select a tree node (object), its attributes are displayed. Each type of object attributes its composition.
CAD drawing DRAWING DESIGN 596
Each type of object is located on its own layer and has its own color. Layer and color for objects is configured in the design settings.
The visibility of an object is controlled by removing or ticking a checkbox on an object.
CAD drafting DRAWING DESIGN 597
Rotate the model by standard means nanoCAD.
IFC import settings
CAD software DRAWING DESIGN 598
The settings dialog consists of a list and an Import/Export toolbar.
List
The list consists of a set of IFC classes. The name of the class is in the first column “IfcClass”. It is not possible to add a new class or remove it.
The “Layer”, “Color” and “Visibility” columns are configured.
Layer – the name of the layer on which the graphics of this class will be placed.
Color – the color of the graphic.
Visibility – controls the display of graphics in the drawing.
Toolbar
CAD drawing DRAWING DESIGN 599Import settings – the command allows you to import settings from an XML file.
CAD drafting DRAWING DESIGN 600Export settings – the command allows you to export settings to an XML file.
CAD software DRAWING DESIGN 601Main menu: Construction – Library objects – CAD drawing DRAWING DESIGN 602Standard parts library.
CAD drafting DRAWING DESIGN 603Ribbon: Construction – Library objects – CAD software DRAWING DESIGN 604Standard parts library.
CAD drawing DRAWING DESIGN 605Toolbar: “Library objects”) – CAD drafting DRAWING DESIGN 606Standard parts library .
CAD software DRAWING DESIGN 607Command line: SPSTD.
Inserting standard parts from the nanoCAD Construction 23 database is carried out using the database manager, which can be presented in full (dialog) form and in the form of a tool palette.
CAD drawing DRAWING DESIGN 608
1. Select the insert object. 2. After selecting the object, specify the insertion point for the object. 3. Select the insertion direction (not all parts need to specify a direction vector). The dialog box for selecting object parameters will open. 4. Adjust the options in the dialog box.The standard dialog contains the following sections (sections are divided into tabs):
· Table parameters · Properties · Dependences · CalculationsImportant!
The composition of the sections (tabs of the insert dialog) is determined by the class of the part, its parameters and the environment of the insert.
The button CAD drafting DRAWING DESIGN 609“Dynamic input” turns on the mode of visual definition of parameters when inserting.
CAD software DRAWING DESIGN 610
As you move the mouse cursor, follow the change in the size of the object. LMB click to confirm the selection of the parameter value.
The “Apply” button allows you to apply the selected parameter values to the object without closing the dialog box. This deactivates the “Dynamic input” mode.
Important!
The description given here refers to the standard dialog for selecting parameters. Some objects of the nanoCAD Construction 23 base use special dialog boxes. In special dialog boxes, the location of the controls may vary.
Note:
If the path to the custom help is specified in the “Help” parameter of the standard part form, it will be called if the focus is on the form control. If the focus is on the “Cancel” or “OK” buttons, the help for standard items opens.
5. Click “OK” to complete the dialog.Toolbar Commands
· Add folder – Adds a folder at the specified location in the object tree. · Delete – Deletes the selected object or folder. · Edit note – Changes the name and note of the selected object.CAD drawing DRAWING DESIGN 611
Context menu commands
· Import – Imports a base object. · Export – Exports a base object. · Send by email – Exports the object and sends it to the specified mail address. · Cut – Cuts an object, folder. · Paste – Inserts a previously cut object, folder. · Paste shortcut – Inserts a shortcut to a previously cut object, folder. · Add folder – Adds a folder at the specified location in the object tree. · Delete – Deletes the selected object or folder. · Edit note – Changes the name and note of the selected object. · Publish- Makes the object visible to other users of the network database. Objects can be published by administrators and editors (editors only their own objects). · Remove publish – Makes the object invisible to other users of the network database. Objects can be unpublished byadministrators and editors (editors only their own objects).Note:
The “Publish” and “Remove publish” commands are only available to editors and database administrators.
The table settings
On the “table settings” dialog insert standard parts displayed parameters responsible for the geometry of the object. These parameters correspond GOST’u (OST’u).
CAD drafting DRAWING DESIGN 612
Properties
Properties of the parts that can be changed and described in the script are displayed on the “Properties”. On this tab located custom and reference parameters, switches species details and details of performances.
CAD software DRAWING DESIGN 613
In the process of inserting parts “Glass” automatically set the relationship between the items “Bearing”, “End caps” and “Glass” (with parts falling into the aperture).
For items that have parameters available for manual entry or dynamically change tab “Properties” presents additional opportunities.
Consider the example of the detail “Glass” features interaction details.
CAD drawing DRAWING DESIGN 614
The “Bearing diameter” – gray. This says that this option is not available for editing and dependence associated with the diameter of the bearing.
CAD drafting DRAWING DESIGN 615
To enable editing of this option, you must go to the tab “Dependencies” and remove the dependency between the diameter of the items “Bearing” and an inner diameter of workpiece “glass.”.
CAD software DRAWING DESIGN 616
Remove Dependency pressing the “Delete”
After this option is available for editing.
CAD drawing DRAWING DESIGN 617
Dependences
The “Dependences” tab allows editing of dependences set automatically during the details allocation on the drawing, and dependences set with the “Dependences control dialog” .
Types of dependencies:
CAD drafting DRAWING DESIGN 618
Parametric – settable parameter object equality arithmetic expression object parameters, which occurs accession.
CAD software DRAWING DESIGN 619
CAD drawing DRAWING DESIGN 620
Calculations
For rod attachment parts provided estimation during insertion. The result of the calculation is the recommended thread diameter for given loading conditions and strength class details.
For some types of rolling bearings estimation is also provided. The result of the calculation is the life of the bearing for the given loading conditions.
Reinsert object
CAD drafting DRAWING DESIGN 621Main menu: Construction – Library objects – CAD software DRAWING DESIGN 622Reinsert object.
CAD drawing DRAWING DESIGN 623Ribbon: Construction – Library objects – CAD drafting DRAWING DESIGN 624Reinsert object.
CAD software DRAWING DESIGN 625Toolbar: CAD drawing DRAWING DESIGN 626Reinsert object (on toolbar “Library objects”).
CAD drafting DRAWING DESIGN 627Command line: SPPICKPOINT.
Serves to re-insert the object in the drawing, combines editing commands properties and movement of item.
1. Click reinsert objectCAD software DRAWING DESIGN 628. 2. Select the drawing or pasted object from the database. 3. Specify the new position of the object and insertion point. 4. Click OK.Threaded fastening
CAD drawing DRAWING DESIGN 629Main menu: Construction – Library objects – CAD drafting DRAWING DESIGN 630Threaded fastening.
CAD software DRAWING DESIGN 631Ribbon: Construction – Library objects – CAD drawing DRAWING DESIGN 632Threaded fastening.
CAD drafting DRAWING DESIGN 633Toolbar: “Library objects”- CAD software DRAWING DESIGN 634Threaded fastening.
CAD drawing DRAWING DESIGN 635Command line: SPJOINT.
Tool for inserting a threaded fastening from library nanoCAD Construction 23.
1. Specify the starting point of the threaded fastener in the drawing.
2. Specify the end point of the threaded fastener, the “Fasteners” dialog will open. When inserting, tools are available to select the direction of drawing. Specifying the start and end points defines the centerline of the fastener. The intersected lines make up the thickness of the part package being fastened.
CAD drafting DRAWING DESIGN 636
3. In the “Fasteners” dialog box, customize the look of the threaded fastener.
Note:
The thread fastener insert dialog automatically saves the last selected template and thread diameter.
4. Confirm the settings with the “Apply” button, or with the “OK” button if you want to close the dialog at the same time. A threaded fastener will be built.
CAD software DRAWING DESIGN 637
Editing a threaded fastener
You can edit a threaded fastener by editing the “Threaded fastener” object, or by editing individual parts included in the threaded fastener.
When editing, you can change the composition, diameter of the threaded fastener, as well as the parameters of the individual parts that are included in it.
To open the threaded fastener setup dialog, apply any of the standard editing tools to the centerline of a group of parts.
If tooltips are enabled in nanoCAD Construction 23 settings, then when you hover the cursor over the centerline, the “Threaded fastening” tooltip appears.
Threaded fastener settings dialog box
CAD drawing DRAWING DESIGN 638
Template list panel
It is possible to save a threaded fastener template for later reuse of assemblies with the same set of parts. To work with templates, use the buttons at the top of the dialog box, and below is a list of available templates:
CAD drafting DRAWING DESIGN 639
Button CAD software DRAWING DESIGN 640“Create new template” adds a new empty template. When creating a new template, the required number of holes is automatically added depending on the number of lines crossed in the drawing.
Button CAD drawing DRAWING DESIGN 641“Delete template” removes the selected template from the list. “Editing template” stores the current setting of the threaded fasteners. It cannot be removed.
Button CAD drafting DRAWING DESIGN 642“Selecting insertion point” is intended to reselect the insertion point and the length of the threaded fastener in the drawing.
Button CAD software DRAWING DESIGN 643“Manually select holes length and placement” opens a window for setting parameters of a package of connected parts.
CAD drawing DRAWING DESIGN 644
LMB clicking on one of the cells in the “Parts type” column switches the part / gap:
CAD drafting DRAWING DESIGN 645
In the “Parts width” column, the thickness of the corresponding part (or gap) is set. After setting the parameters of the connection package, close the window with the “OK” button.
The context menu of the list of templates contains the commands:
· Add folder · Delete object · Rename · Import object · Export object · Send by email · Copy · Configuration toolThese commands are similar to those used in the object manager nanoCAD Construction 23.
Tab “Template”
The following settings are available on the “Template” tab in the center of the dialog:
· Fasteners properties · Package thickness – thickness of the package of parts to be joined, in mm. · View – selection of standard image projection. · Small thread pitch – fine pitch switch. · Simplified view – simplified / full image switch. · Details of the threaded assembly. The components included in the assembly are listed here in order. · Screw · Hole · Spot facing · Washer · NutTo select a part of a threaded assembly from the nanoCAD Construction 23 base, click in the cell of the GOST column of the corresponding element.
The “Select object” dialog box will open the attachment parts folder.
CAD software DRAWING DESIGN 646
Additional settings for assembly components are available when expanding the list:
CAD drawing DRAWING DESIGN 647
Button CAD drafting DRAWING DESIGN 648“Clear” in the right column of the list table clears the selected position.
Tab “Preview”
A preview of the threaded assembly is available on the tab.
CAD software DRAWING DESIGN 649
List of thread diameters
CAD drawing DRAWING DESIGN 650
The “lightbulb” icon above the list indicates that the selected diameter value can be used for all objects in the assembly:
CAD drafting DRAWING DESIGN 651 The diameter value does not match one or more parts. Assembly is not possible. CAD software DRAWING DESIGN 652 The diameter value applies to all parts in the assembly. Assembly is possible.Button CAD drawing DRAWING DESIGN 653“Add part to template”
Adds a part to the assembly after being selected from the list. The list of details available for adding depends on the currently selected object:
CAD drafting DRAWING DESIGN 654
Button CAD software DRAWING DESIGN 655“Remove part from template”
Removes the selected object from the parts list.
Button CAD drawing DRAWING DESIGN 656“Dynamic selection”
Turns on the mode of visual selection of the bolt length after closing the dialog.
Graphical display type selection list
When inserting a threaded fastener, 3 display methods are available, selected by the “Select fasteners insert part” button on the bottom toolbar of the dialog. The figure on the button displays the currently selected display method:
CAD drafting DRAWING DESIGN 657
With local out
CAD software DRAWING DESIGN 658
Normal insert type
CAD drawing DRAWING DESIGN 659
Insert hidden fastener
CAD drafting DRAWING DESIGN 660
CAD software DRAWING DESIGN 661
CAD drawing DRAWING DESIGN 662
Displaying chamfers on holes
To select the options for displaying chamfers in the drawing, you must correctly place the marks in the hole properties.
CAD drafting DRAWING DESIGN 663
Setting the hole type
To change the hole type, click on it in the connection part set and select a different type in the “Select object” dialog box that opens.
CAD software DRAWING DESIGN 664
Rivet joint
CAD drawing DRAWING DESIGN 665Main menu: Construction – Library objects – CAD drafting DRAWING DESIGN 666Rivet joint.
CAD software DRAWING DESIGN 667Ribbon: Construction – Library objects – CAD drawing DRAWING DESIGN 668Rivet joint.
CAD drafting DRAWING DESIGN 669Toolbar: CAD software DRAWING DESIGN 670Rivet joint ( “Library objects”).
CAD drawing DRAWING DESIGN 671Command line: SPRIVET.
Insertion tool riveted joint parts of the base standard elements nanoCAD Construction 23.
1. Specify the starting point for drawing the rivet assembly. 2. Specify the endpoint of the rivet assembly. When you insert the available tools of choice destinations rendering . 3. In the dialog box mounting parts adjust the view of the rivet connections.CAD drafting DRAWING DESIGN 672
To select the type of rivet base nanoCAD Construction 23 click in the rivet.
To select the type of base openings nanoCAD Construction 23 click in the hole for rivets.
It is possible to save the template riveted joint for later reuse assemblies with the same set of items. To work with templates use the buttons at the top of the dialog box, and below is a list of available templates:
CAD software DRAWING DESIGN 673
“Editable Template” stores the current settings bolting. It can not be deleted.
Button CAD drawing DRAWING DESIGN 674Create a new template. Adds a new blank template.
Button CAD drafting DRAWING DESIGN 675Delete template. Deletes the selected template from the list.
In the context menu templates available commands:
· Add Folder · Delete object · Rename · Import from file · Export to file · Send by email · CopyThese commands are similar to those used in in the Object Manager nanoCAD Construction 23.
Button CAD software DRAWING DESIGN 676Select the insertion point and the length of the riveted joint. Designed to re-select the insertion point and the length of the rivet assembly drawing.
Button CAD drawing DRAWING DESIGN 677Set package connection manually. Opens setup package of the parts.
CAD drafting DRAWING DESIGN 678
Left-click on one of the cells in the column “type items” to switch the item / gap:
CAD software DRAWING DESIGN 679
In the “Thickness” is set to the thickness of the relevant part (or gap) After configuring the package connected, close the window by pressing OK.
The right side of the dialog box mounting parts is a list of values diameter rivets.
CAD drawing DRAWING DESIGN 680When you insert the rivet connections are available 3 ways to display selected button Insert mode riveted joint at the bottom of the dialog box toolbar. Drawing on the button displays the currently selected display method:
CAD drafting DRAWING DESIGN 681With a local cutaway CAD software DRAWING DESIGN 682Normal Box CAD drawing DRAWING DESIGN 683Insert hidden2 types available (front and side) display riveted joint:
CAD drafting DRAWING DESIGN 684Front view CAD software DRAWING DESIGN 685Left side viewYou can choose the type rivet connections:
CAD drawing DRAWING DESIGN 686The number of types depending on the type of rivet.
CAD drafting DRAWING DESIGN 687Automatic detection of packet connection
When you insert the rivet connections made automatically recognize the boundaries of the parts. If the line crosses the insertion direction perpendicular to a few segments in the drawing, they are defined as the boundaries of parts and installs Connection:
CAD software DRAWING DESIGN 688
Insertion point and the length of the rivet assembly are determined automatically based on the thickness of the package details.
CAD drawing DRAWING DESIGN 689
Editing riveted joint
A dialog box settings riveted joint, apply any of the standard editing tools to the centerline of the group details.
If the settings nanoCAD Construction 23 included tooltips, then when you move the cursor to the center line will show “Rivet connection”.
Markers, groups
User Groups
Working with groups in Construction 23 is performed using the following commands:
· Create custom groups · Inserting User GroupsCreate custom groups
CAD drafting DRAWING DESIGN 690Main menu: Construction – Library objects – Markers, Groups – CAD software DRAWING DESIGN 691Group objects.
CAD drawing DRAWING DESIGN 692Ribbon: Construction – Library objects – CAD drafting DRAWING DESIGN 693Group objects.
CAD software DRAWING DESIGN 694Toolbar: CAD drawing DRAWING DESIGN 695Group objects ( “Library objects”).
CAD drafting DRAWING DESIGN 696Command line: SPGROUPOBJECTS.
Constraints describing the interaction of two or more objects, It is advisable to store these in the objects database in a related group. Group nanoCAD Construction 23 has the following features:
· Group is stored in the object database, has a pattern preview before pasting. · Components of the group in addition to objects nanoCAD Construction 23 can be primitives and blocks in nanoCAD. · Group may be transferred as part of the database file to other users. · Group may have additional dependencies with other groups and objects. · Components of the group remain together parametric dependence. · Components in the group can be specified both individually and in groups.Thus, the group is a powerful way of organizing and structuring graphics data in a separate local file drawing document.
Create a Group
Button CAD software DRAWING DESIGN 697Group objects
Gather and create database objects in the design position in the drawing. On the toolbar, Library objects,click Group objects.
Select the required objects in the drawing AutoCAD specify the origin of the group.
In the dialog box New group on the left side is a list of objects in the group. Name objects in the list is taken from the string value for the specifications set in the properties of objects.
Button CAD drawing DRAWING DESIGN 698Highlight group objects highlights and centers on the screen objects in the group.
Button CAD drafting DRAWING DESIGN 699Set parameter table. Opens the editor table settings. Table of parameters used to select the group attribute values from a predefined list of values.
Button CAD software DRAWING DESIGN 700Show form editor. Opens Form Editor to create a special dialog box.
ButtonCAD drawing DRAWING DESIGN 701save changes to database. Saves the base group Construction Site 23.
In the right part of the window picture preview and a list of attributes for the group.
Editing attributes produced in the cells of the table.
CAD drafting DRAWING DESIGN 702
Adding attributes produced from the parameter list of objects in the group.
Expand the selected entry in the list (with the “+” next to the name of the object) and double click on the parameter, add an attribute in the table.
You can install a bidirectional relationship between the group and attribute parameter object that is associated with this attribute. The list of attributes in the column Attribute Properties , click the left mouse button on the icon CAD software DRAWING DESIGN 703. Depending on the mode change bidirectional, it will indicate the icon CAD drawing DRAWING DESIGN 704. Thus, when the value of the attribute group, and the parameter of the object is changed.
Save the group of objects in the database by pressing the buttonCAD drafting DRAWING DESIGN 705save changes to database. Choose a location and name for the group (the default group name matches the specified value attribute Group Name). Click OK.
Group created and saved to the database. Now you can insert multiple grouped objects in a drawing, resizing and positioning of objects, while preserving established parametric and geometric constraints.
Important!
Group objects only retains information about dependencies between objects and attributes set. For insertion to be carried out correctly, you must have a database of all the objects in this group.
When working with a group of attributes of the various available methods for selecting values. In the context menu of the column Properties attribute in the attribute list, select:
CAD software DRAWING DESIGN 706 · Add property from object – allows you to set the attribute value by linking it with an attribute value of another object in the drawing. · Set to unique string – allows you to set the attribute-counter, which will increase its value by 1 for each subsequent inserted marker. In the Value column for the visible attribute counter must specify a character string – prefix. The drawing will be appended to the prefix value of the counter. · Set to calculated field – allows you to set the attribute value using a mathematical expression, using references to other attributes of the marker and mathematical functions. In reference to another attribute marker use the name of the attribute recorded in braces. · Automatically increment – allows you to set the attribute-counter, which will increase its value to 1, compared with the same attribute of the previous insertion marker. This attribute allows the counter-repetition of identical values for several markers that distinguishes it from the attribute set to a unique value. · Set to simple field – sets the attribute type by default.Insert group
Insert group may be carried out as the object manager , and with a tool insert group.
Button CAD drawing DRAWING DESIGN 707Insert Group toolbar Library objects opens a dialog Box group.
In the list of the group and press OK. If you insert a group of objects , you must specify the insertion point of the group. If you insert a group of dependencies , you need to select the drawing objects that you want to associate with the dependencies.
In the dialog box Insert group commands are available:
CAD drafting DRAWING DESIGN 708Create group. Creates a new group.
CAD software DRAWING DESIGN 709Delete group. Deletes the selected group from the database.
CAD drawing DRAWING DESIGN 710Select items from the drawing for the group. Used to edit an existing or new group.
CAD drafting DRAWING DESIGN 711Detail groups. Opens a list of groups of items.
CAD software DRAWING DESIGN 712Dependence group. Opens a list of groups dependencies.
Switch multiple . Enables insertion of multiple groups in the drawing.
Switch Add group marker. If installed, together with a group of drawing a marker is added to the group.
Marker group is designed for group editing and data to other objects in the drawing (see Binding arbitrary graphical and tabular data ).
CAD drawing DRAWING DESIGN 713
Editing a Group
After you insert a group of objects in the drawing, or when the command to edit the marker group opens the edit dialog group.
CAD drafting DRAWING DESIGN 714Highlight group objects. Highlights and centers on the screen objects in the group.
CAD software DRAWING DESIGN 715Edit marker Properties. Includes editing mode, where you can change the set of objects in the group, add or remove attributes.
CAD drawing DRAWING DESIGN 716Object tree. Enables and disables the object tree in the left pane.
CAD drafting DRAWING DESIGN 717Set parameters table. This button is available if the group contains a table of parameters. In the dialog box, select the row attribute values, and click OK.
Group dependencies
Group dependencies remain parametric description and assembly relationships between objects. When you insert such groups they are not added to the drawing objects, but only established the relationship between existing objects.
Consider creating and maintaining relationships between the two cuffs.
Important!
Before you create a group, you must place the drawing objects to be included in the group and set the dependencies between objects.
Insert the base of the two objects Cuff GOST 8752-79. Set between the geometric co-directional dependence Combining axis and the plane at a distance obj.B (see Constraints between two objects ) and the parametric dependence of the outer diameter.
CAD software DRAWING DESIGN 718
Select Insert group. CAD drawing DRAWING DESIGN 719
In the dialog box, click Dependence groups.
CAD drafting DRAWING DESIGN 720
Button CAD software DRAWING DESIGN 721 Creates group. In the groups list, change the name of the new group (eg, “Package cuffs”). To edit, click the left mouse button on the name of the group.
CAD drawing DRAWING DESIGN 722
Click CAD drafting DRAWING DESIGN 723Select group details from drawing and select the drawing both cuffs. Press Enter.
In the dialog box, select the dependent listed in the list established between objects. Click OK.
CAD software DRAWING DESIGN 724
Look at the result of the creation of group dependencies.
CAD drawing DRAWING DESIGN 725
In the description of the group under the picture preview Set the selection order when inserting objects group dependencies.
Group dependencies are stored in the database automatically. Click Cancel to complete the group.
Insert a drawing of the base of the cuff, which must be applied to create a dependency.
CAD drafting DRAWING DESIGN 726
Select Insert group , click Group Dependency . In the list of dependence “ Package cuffs. “ Click OK.
CAD software DRAWING DESIGN 727
Select the drawing cuffs to be connected sequentially (in the example need to perform steps 10-11 twice).
CAD drawing DRAWING DESIGN 728
Automatically set dependence stored in the description of the group.
Inserting Groups
CAD drafting DRAWING DESIGN 729Main menu: Construction – Library objects – Markers, Groups – CAD software DRAWING DESIGN 730Insert group.
CAD drawing DRAWING DESIGN 731Ribbon: Construction – Library objects – CAD drafting DRAWING DESIGN 732Insert group.
CAD software DRAWING DESIGN 733Toolbar: CAD drawing DRAWING DESIGN 734Insert group ( “Library objects”).
CAD drafting DRAWING DESIGN 735Command line: SPINSERTGROUP.
CAD software DRAWING DESIGN 736Library: Groups.
Command Options
Insert group Box lets you create a set of objects with superimposed parametric and geometric constraints.
CAD drawing DRAWING DESIGN 737
CAD drafting DRAWING DESIGN 738Create group
CAD software DRAWING DESIGN 739Deleting Group
CAD drawing DRAWING DESIGN 740Select group details from drawing
CAD drafting DRAWING DESIGN 741CAD software DRAWING DESIGN 742 Switch between groups of objects and dependencies
The mechanism used in the team group insert , you can insert a group of objects
CAD drawing DRAWING DESIGN 743
The “Add marker group” enables the group a graphic element – a marker located at the insertion point of the group. In marker may include parameters of individual parts group that can help you when pasting automatically change the geometry of the group of related components.
“Multiple insert” allows you to create multiple copies of the selected group.
If a user group has been maintained by the standard in the folder $\MCS\Groups, then insert it in the tree by choosing the object manager.
If a group is defined form, then insert dialogue is as follows:
CAD drafting DRAWING DESIGN 744
· The dialog box includes a tree of groups – a list of objects and their parameters group. This tree can disable button CAD software DRAWING DESIGN 745 · The preview window group · Form input values groupWhen you click on CAD drawing DRAWING DESIGN 746 you can switch to edit mode group settings.
Universal marker
CAD drafting DRAWING DESIGN 747Main menu: Construction – Library objects – Marks and groups – CAD software DRAWING DESIGN 748Add marker.
CAD drawing DRAWING DESIGN 749Ribbon: Construction – Library objects – CAD drafting DRAWING DESIGN 750Add marker.
CAD software DRAWING DESIGN 751Toolbar: “Library objects”- CAD drawing DRAWING DESIGN 752Add marker.
CAD drafting DRAWING DESIGN 753Command line: SPCREATEUMARKER.
The “Marker” tool is designed specifically to create a connection between an arbitrary graphic object (primitive) nanoCAD and a spreadsheet-specification. A universal marker is a translator of data from drawing objects into the nanoCAD Construction 23table by means of special means – marker attributes.
Marker attributes can be visible or hidden. The values of the visible attributes are displayed in the drawing as text strings.
The marker, as an object nanoCAD Construction 23, can be saved in the object library and used repeatedly. The marker can also be included in the groups of objects nanoCAD Construction 23, providing the ability to specify the entire functional groups.
Create marker
Let’s consider creating a marker in the form of a positional leader.
1. Set the required current scale. 2. Insert two text lines into the drawing and draw a horizontal line between them.CAD software DRAWING DESIGN 754
These objects will form a leader shelf template with two text labels. To use text strings as marker attributes, the first character must be “$”.
3. Call the command CAD drawing DRAWING DESIGN 755“Add marker”, use a box or crossing box to select the objects that made up the marker.CAD drafting DRAWING DESIGN 756
4. Snap the base point of the marker.CAD software DRAWING DESIGN 757
5. The “Creation of a marker” dialog box appears. The properties table will list the attributes entered in the callout text boxes:CAD drawing DRAWING DESIGN 758
Column “Name” contains the working name of the attribute.
Column “Description” describes the attribute.
In column “Value” the values of the attribute are entered. Values can be either numeric or text. Auxiliary commands are available in the context menu of the “Value” column.
CAD drafting DRAWING DESIGN 759
Column “Attribute property” is used to indicate the type of the input attribute. Various attribute labels are provided to indicate their type. The default is “Set to simple field”.
CAD software DRAWING DESIGN 760
Attribute types:
· Add property from object – allows you to set an attribute value by associating it with the attribute value of another object in the drawing.Important!
An object is understood as an object from the base of standard products.
After choosing the type, it is suggested to select the object and the object attribute.
CAD drawing DRAWING DESIGN 761
After selecting an attribute, its value falls into the “Value” column, and in the “Attribute property” column the name of the selected attribute.
CAD drafting DRAWING DESIGN 762
After assigning an attribute, you can change the type of relationship with an object attribute:
CAD software DRAWING DESIGN 763One-way communication – changing the value in an attribute of an object affects the value of the marker.
CAD drawing DRAWING DESIGN 764Two way communication – changing the value in the marker affects the attribute of the object, and vice versa.
CAD drafting DRAWING DESIGN 765Basic communication – an attribute of an object can only be changed from a marker. If the attribute is a table value in a basic relationship, the closest value from the table is displayed. The entered value will be displayed in brackets.
· Set To Unique string – allows you to set a counter attribute that will increase its value by 1 for each subsequent inserted marker. In the “Value” column for the visible counter attribute, you can specify a character string – a prefix. In the drawing, the counter value will be appended to the prefix.CAD software DRAWING DESIGN 766
CAD drawing DRAWING DESIGN 767
· Set to calculated field – allows you to set the value of an attribute using a mathematical expression, using references to other marker attributes, operators, and mathematical functions. The name of the desired attribute is used as a reference to another marker attribute.Note:
Computed attributes are defined and calculated from top to bottom.
Important!
Calculations are performed in curly braces.
Function:
CAD drafting DRAWING DESIGN 768
Result:
CAD software DRAWING DESIGN 769
· Automatically increment – allows you to set a counter attribute that will increase its value by 1 compared to the same attribute of the previous inserted marker. Such a counter attribute allows repetition of the same values for several markers, which distinguishes it from an attribute set to a unique value.CAD drawing DRAWING DESIGN 770
CAD drafting DRAWING DESIGN 771
· Set to simple field – sets the default attribute type to plain text.Note:
Attributes included in the block can be included in the marker attribute table nanoCAD!
6. Edit the marker using the marker controls at the bottom of the dialog box.CAD software DRAWING DESIGN 772
Include:
· “Marker draw mode”. When you click on this button, a drop-down list of rendering modes appears: · CAD drawing DRAWING DESIGN 773Simple marker. · CAD drafting DRAWING DESIGN 774Draw position line. · CAD software DRAWING DESIGN 775Linear align.When you select the display method with the addition of a leader line, an additional button CAD drawing DRAWING DESIGN 776“Arrow Type” appears to select the type of arrow:
CAD drafting DRAWING DESIGN 777
Click this button and select the desired extension line arrow type.
Arrow display parameters are defined in the “Settings – Symbols – Extension – Additional extension lines” settings.
· CAD software DRAWING DESIGN 778“Unploted”. When this button is enabled, the marker is placed on a special layer that is not displayed when printing. When this mode is activated, the icon on the (CAD drawing DRAWING DESIGN 779) button changes and the marker is displayed in gray on the screen (in accordance with the color of the non-printed layer). · CAD drafting DRAWING DESIGN 780“Show form editor”- calls the custom form editor to create a dialog for working with marker attributes.The following commands are available in the drop-down menu:
“Edit Form”. Open Form Editor.
“Add Form. Adds additional forms, while the marker can change the appearance of the form, by condition or by the user’s choice. By default, the marker has one form.
CAD software DRAWING DESIGN 781
The form editor uses standard Windows form generation technology. The toolkit consists of three blocks – the graphic editor area, the toolbar with form objects and the properties window of the inserted elements. For inserted fields, the “Field Name” (“Variable”) can be selected from the list of existing marker description fields. In this case, the default field value is equal to the field value in the marker description.
When adding a second form, you are prompted to enter a name for the form. The variable Tag – mcFormName is added to the properties table. This variable is responsible for the name of the form, it can be set in a calculated field and, for example, made equal to execution. Empty or “Main” is considered the main form.
CAD drawing DRAWING DESIGN 782
· CAD drafting DRAWING DESIGN 783“Geometry”. Used to change the appearance of the generic marker and define the insertion point.The following commands are available in the drop-down menu:
Get new geometry. The button is used to change the appearance of the universal marker and define the insertion point.
Export marker source graphics. Exports marker geometry to a file.
Add Implemetnation. Adds additional performances, while the marker can change its appearance, by condition or by the user’s choice.When creating a new implementation, you are prompted to enter its name. When adding implementation, the Tag – mcImplementation variable is added to the properties table. This variable is responsible for the name of the current marker implementation. It can be set to a calculated field or linked to a list on a form. Empty or “Main” is considered the main implementation.
CAD software DRAWING DESIGN 784
· CAD drawing DRAWING DESIGN 785“Set parameters table”. Opens the marker parameter table editor. When inserting a marker and having a table of values, it is possible to assign a group of values to the marker attributes.CAD drafting DRAWING DESIGN 786
In the list, select the parameters whose values will be selected from the table. In the right part of the window, enter the required number of lines with values. Close the dialog with the “OK” button.
· CAD software DRAWING DESIGN 787Save changes to odatabase. The button is intended for writing a marker to library nanoCAD Construction 23. · CAD drawing DRAWING DESIGN 788Apply changes to all markers of this types. Applies changes to all markers of this type in the drawing. Serves for changing the marker template for all markers made according to this template and inserted into the drawing. 7. If necessary, add any number of hidden attributes, filling in the rows of the table in sequence. The attribute is added in the bottom line of the table, marked with an “*” symbol. 8. For future use of the marker, save it to the database as a named object.CAD drafting DRAWING DESIGN 789
In the “Create element” dialog box, specify the path to save, the name of the object and the note (for more information on working with the object base, see the nanoCAD Construction 23Object Manager). After you save the marker, a message appears prompting you to update the existing copies of the marker in the drawing.
9. nanoCAD Construction 23 makes it possible to immediately apply the created marker. The command line prompts you to install the generated token. Pick an insertion point in the drawing. Identical markers can be simply copied in the future. In other cases, the marker is inserted directly from the base.CAD software DRAWING DESIGN 790
Edit marker
Editing of a marker is carried out in a dialog box, the title of which corresponds to the name of the marker. For example, when you call for editing the “Position_Marker” marker, the creation of which was described in the previous paragraph, the dialog box will look like this:
CAD drawing DRAWING DESIGN 791
Additional commands are located at the bottom of the window:
· “Marker draw mode”. When you click on this button, a drop-down list of rendering modes appears: · CAD drafting DRAWING DESIGN 792Simple marker. · CAD software DRAWING DESIGN 793Draw position line. · CAD drawing DRAWING DESIGN 794Linear align.When you select the display method with the addition of a leader line, an additional button CAD drafting DRAWING DESIGN 795“Arrow Type” appears to select the type of arrow:
CAD software DRAWING DESIGN 796
· CAD drawing DRAWING DESIGN 797 “Unploted”. When this button is enabled, the marker is placed on a special layer that is not displayed when printing. When this mode is activated, the icon on the (CAD drafting DRAWING DESIGN 798) button changes and the marker is displayed in gray on the screen (in accordance with the color of the non-printed layer). · CAD software DRAWING DESIGN 799“Highlight info source object”. Highlights in the drawing the object with which the marker is associated (The function is available if the “Add property from object” mode is set for one or several attributes and the corresponding object was specified when inserting the marker). · CAD drawing DRAWING DESIGN 800“Edit marker properties”. Turns on the edit mode, in which you can change the appearance of the marker, add or remove attributes.System variables in marker
mcImplementation – Execution management. Empty or “Main” means the main view.
mcFormName – Form management. Empty or “Main” means the main form.
mcArrowSize – Arrow size control.
mcDefLayer – Controls the marker location layer. The “Value” field contains the name of the layer.
mcShowFormOnInsert – Controls the display of the dialog when inserting. If the value is 0, the dialog is not shown when inserting. The value can be calculated.
Template Wizard
CAD drafting DRAWING DESIGN 801Main menu: Construction – Library objects – Markers, Groups – CAD software DRAWING DESIGN 802Template wizard.
CAD drawing DRAWING DESIGN 803Ribbon: Construction – Library objects – CAD drafting DRAWING DESIGN 804Template wizard.
CAD software DRAWING DESIGN 805Toolbar: CAD drawing DRAWING DESIGN 806Template wizard ( “Library objects”).
CAD drafting DRAWING DESIGN 807Command line: SPTWIZ.
Template Wizard is designed to create easy to use tools of commonly used design elements drawing.
Basic rules
When the command will be asked to select an object to create a template. If the object was preselected, then immediately start dialogue Template Wizard.
CAD software DRAWING DESIGN 808
Command Options
Button Create template – creates a template in the database or applies the changes made in the editor.
Button From – Starts the form template.
Button CAD drawing DRAWING DESIGN 809Create a new template – Creates a new template in the database based on the selected graphics and created form.
Button CAD drafting DRAWING DESIGN 810Delete form – deletes the created form template.
Example of creating a template
Consider the example of creating a template signs of roughness. To do this, the drawing shall bear one designation:
CAD software DRAWING DESIGN 811
After you run the Wizard Templates chosen designation roughness.
To work with the template you must save it in the database that will be invited to do by pressing the button CAD drawing DRAWING DESIGN 812.
CAD drafting DRAWING DESIGN 813
Then click on the Create a form and create a form using the notation tools online forms.
For example, we can take two parameters – the first line designations and direction of irregularities. Both parameters are added to the form as a combo box (drag while holding Ctrl).
CAD software DRAWING DESIGN 814 > CAD drawing DRAWING DESIGN 815
After editing, we obtain the form of the following form:
CAD drafting DRAWING DESIGN 816
Close the form editor, click to update in template.
CAD software DRAWING DESIGN 817
Template will be saved in the database and will be displayed in the object manager.
CAD drawing DRAWING DESIGN 818
Now when you insert from the database will be able to also place the designation of roughness on the shelf line-outs, but when you edit your form will appear:
CAD drafting DRAWING DESIGN 819
Editing blocks nanoCAD
If the original graphics selected block nanoCAD, its attributes are also displayed in the form editor as available variables.
CAD software DRAWING DESIGN 820 > CAD drawing DRAWING DESIGN 821
When creating a form in the database and maintaining such a block is inserted into the drawing as a block of the same source, only the attributes can be set up via a custom form.
CAD drafting DRAWING DESIGN 822
Control overlapping objects
Change hidden mode
CAD software DRAWING DESIGN 823Main menu: Construction – Library objects – Cover – CAD drawing DRAWING DESIGN 824Change hidden mode.
CAD drafting DRAWING DESIGN 825Toolbar: “Library objects”- CAD software DRAWING DESIGN 826Change hidden mode.
CAD drawing DRAWING DESIGN 827Command line: SPCHCOVER.
The command switches the display mode of hidden lines.
nanoCAD Construction 23 allows you to hide individual graphics elements. The overlapping nature of the base object or user block is determined by a special parameter – the overlap level ZOrder. ZOrder – this is a numeric parameter whose value determines the overlap priority. An object with a large ZOrder value overrides an object with a lower value.
Primitives nanoCAD have the lowest overlapping level and therefore are always overlapped by objects from the database. That at an insertion of object nanoCAD Construction 23 objects nanoCAD did not overlap, it is necessary to disable the switch in the object insert dialog “Cover primitives”:
CAD drafting DRAWING DESIGN 828
The area in the drawing that the base object covers nanoCAD Construction 23, is called “Contour of suppression”. An overlap exists within this contour.
1. Call command.CAD software DRAWING DESIGN 829
2. In the context menu, select the desired view of the overlapped objects “Normal”, “Dotted” or “Switch”.Normal
Dotted
Switch
CAD drawing DRAWING DESIGN 830
CAD drafting DRAWING DESIGN 831
The command appends the value. Those. If a normal overlap has been established, then the dashed line becomes, and vice versa.
3. Select the secant frame for the objects for which you want to change the overlapping mode. 4. Repeat if necessary items 2 and 3, or complete the command on the key “Enter”.Regenerate suppression contours
CAD software DRAWING DESIGN 832Main menu: Construction – Library objects- Cover – CAD drawing DRAWING DESIGN 833Regenerate suppression contours.
CAD drafting DRAWING DESIGN 834Toolbar: “Library objects”- CAD software DRAWING DESIGN 835Regenerate suppression contours.
CAD drawing DRAWING DESIGN 836Command line: SPCOVER.
Regenerate the drawing and redraw the contents of the current viewport.
Before
After
CAD drafting DRAWING DESIGN 837
CAD software DRAWING DESIGN 838
Move up
CAD drawing DRAWING DESIGN 839Main menu: Construction – Library objects – Cover – CAD drafting DRAWING DESIGN 840Move up.
CAD software DRAWING DESIGN 841Toolbar: “Library objects”- CAD drawing DRAWING DESIGN 842Move up.
CAD drafting DRAWING DESIGN 843Command line: SPMOVEUP.
1. Call command;CAD software DRAWING DESIGN 844
2. Select the objects you want to move up;CAD drawing DRAWING DESIGN 845
3. Select the objects to be compared;CAD drafting DRAWING DESIGN 846
4. After the selection is complete, the objects that need to be moved up will automatically increase the overlap level (ZOrder).CAD software DRAWING DESIGN 847
Move down
CAD drawing DRAWING DESIGN 848Main menu: Construction – Library objects – Cover – CAD drafting DRAWING DESIGN 849Move down.
CAD software DRAWING DESIGN 850Toolbar: “Library objects”- CAD drawing DRAWING DESIGN 851Move down.
CAD drafting DRAWING DESIGN 852Command line: SPMOVEDOWN.
1. Call command;CAD software DRAWING DESIGN 853
2. Select the objects you want to move down;CAD drawing DRAWING DESIGN 854
3. Select objects to be compared;CAD drafting DRAWING DESIGN 855
4. After the selection is complete, the objects that are to be moved down will automatically decrease the overlap level (ZOrder).CAD software DRAWING DESIGN 856
Part trim
Add part trim
CAD drawing DRAWING DESIGN 857Main menu: Construction – Library objects – Part trim – CAD drafting DRAWING DESIGN 858Add part trim.
CAD software DRAWING DESIGN 859Ribbon: Construction – Library objects – CAD drawing DRAWING DESIGN 860Add part trim.
CAD drafting DRAWING DESIGN 861Toolbar: “Library objects”- CAD software DRAWING DESIGN 862Add part trim.
CAD drawing DRAWING DESIGN 863Command line: SPTRIM.
The command allows you to trim objects of metal structures.
Trimming with contour indication
1. Call the command CAD drafting DRAWING DESIGN 864“Add part trim”.
2. Pick an outline. A contour can be a line segment, circle, arc, polyline (closed and open).
CAD software DRAWING DESIGN 865
3. Specify trimming objects.
If a circle or closed polyline is used as a path, the trimming object is selected within the path.
CAD drawing DRAWING DESIGN 866CAD drafting DRAWING DESIGN 867
If a linear path is used, the trimming object is selected from one side of the path.
CAD software DRAWING DESIGN 868CAD drawing DRAWING DESIGN 869
4. Press the “Esc” button to end trimming. The object will be trimmed.
CAD drafting DRAWING DESIGN 870
Trimming mode “COntour”
1. Call the command CAD software DRAWING DESIGN 871“Add part trim”.
2. Select trim mode “COntour”.
3. Draw a closed polyline path.
CAD drawing DRAWING DESIGN 872
4. Pick a trimming object within the path.
CAD drafting DRAWING DESIGN 873
5. Trimming an object is made.
CAD software DRAWING DESIGN 874
Trimming mode “rectangle by tWO points”
1. Call the command CAD drawing DRAWING DESIGN 875“Add part trim”.
2. Select trim mode “rectangle by tWO points”.
3. Pick the first corner.
CAD drafting DRAWING DESIGN 876
4. Pick the second corner.
CAD software DRAWING DESIGN 877
5. Pick a trimming object inside the rectangle.
CAD drawing DRAWING DESIGN 878
6. Trimming an object is made.
CAD drafting DRAWING DESIGN 879
Trimming mode “rectangle by thrEE points”
Allows for trimming at the desired angle.
1. Call the command CAD software DRAWING DESIGN 880“Add part trim”.
2. Select trim mode “rectangle by thrEE points”.
3. Pick the first point.
CAD drawing DRAWING DESIGN 881
4. Pick the second point.
CAD drafting DRAWING DESIGN 882
5. Pick the size of the outline.
CAD software DRAWING DESIGN 883
6. Pick a trimming object inside the rectangle.
CAD drawing DRAWING DESIGN 884
7. Trimming an object is made.
CAD drafting DRAWING DESIGN 885
Trimming mode “HOle”
1. Call the command CAD software DRAWING DESIGN 886“Add part trim”.
2. Select trim mode “HOle”.
3. Pick the center of the hole.
CAD drawing DRAWING DESIGN 887
4. Pick a radius for the hole.
CAD drafting DRAWING DESIGN 888
5. Pick a trimming object inside the circle.
CAD software DRAWING DESIGN 889
CAD drawing DRAWING DESIGN 890
Remove part trim
CAD drafting DRAWING DESIGN 891Main menu: Construction – Library objects – Part trim – CAD software DRAWING DESIGN 892Remove part trim.
CAD drawing DRAWING DESIGN 893Ribbon: Construction – Library objects – CAD drafting DRAWING DESIGN 894Remove part trim.
CAD software DRAWING DESIGN 895Toolbar: “Library objects”- CAD drawing DRAWING DESIGN 896Remove part trim.
CAD drafting DRAWING DESIGN 897Command line: SPTRIMDELETE.
The command removes a previously created trim.
1. Call the command CAD software DRAWING DESIGN 898“Remove part trim”.
CAD drawing DRAWING DESIGN 899
2. Specify the objects you want to reset and press “Enter” (or press “Spacebar”) to select all objects.
CAD drafting DRAWING DESIGN 900
3. The specified objects will be restored to their original state.
CAD software DRAWING DESIGN 901
Add View
CAD drawing DRAWING DESIGN 902Main menu: Construction – Library objects – CAD drafting DRAWING DESIGN 903Add view.
CAD software DRAWING DESIGN 904Ribbon: Construction – Library objects – CAD drawing DRAWING DESIGN 905Add view.
CAD drafting DRAWING DESIGN 906Toolbar: CAD software DRAWING DESIGN 907Add view (on toolbar “Library objects”).
CAD drawing DRAWING DESIGN 908Context menu: CAD drafting DRAWING DESIGN 909Add view (on select object).
CAD software DRAWING DESIGN 910Command line: SPADDVIEW.
Designed to quickly add a new type of projection from the base of the inserted object to the drawing.
· Select the object to copy. · Specify the insertion point of the object. Context menu commands Front / left / right / top / bottom standard projection (to insert a particular projection, it is necessary that it be recognized in the object). · Context menu commands Point, Angle mode selection switch, respectively the insertion point or selection mode direction. · Complete the cyclic command.Adding a projection view to the object database can be done using the Add View from the context menu for the selected object.
Simplified / Full View
CAD drawing DRAWING DESIGN 911Main menu: Construction – Library objects – CAD drafting DRAWING DESIGN 912Change representation.
CAD software DRAWING DESIGN 913Ribbon: Construction – Library objects – CAD drawing DRAWING DESIGN 914Change representation.
CAD drafting DRAWING DESIGN 915Toolbar: CAD software DRAWING DESIGN 916Change representation (on toolbar “Library objects”).
CAD drawing DRAWING DESIGN 917Context menu: CAD drafting DRAWING DESIGN 918Change representation (on select object).
CAD software DRAWING DESIGN 919Command line: SPCHANGEREPRESENT.
· Press the button and select the database object in the drawing. · Context menu commands Full, Simplified select the object representation.Switching presentation can be accomplished by using the Change view from the context menu for the selected object.
Mirror Part
CAD drawing DRAWING DESIGN 920Main menu: Construction – Library objects – CAD drafting DRAWING DESIGN 921Mirrow part.
CAD software DRAWING DESIGN 922Ribbon: Construction – Library objects – CAD drawing DRAWING DESIGN 923Mirrow part.
CAD drafting DRAWING DESIGN 924Toolbar: CAD software DRAWING DESIGN 925Mirrow part (on toolbar “Library objects”).
CAD drawing DRAWING DESIGN 926Command line: SPMIRROWSTD.
· Press the button and select the database object in the drawing. · Press Enter.Occur along the axis of revolution object X.
Regenerate STD parts
CAD drafting DRAWING DESIGN 927Main menu: Construction – Library objects – CAD software DRAWING DESIGN 928Regenerate Std Parts.
CAD drawing DRAWING DESIGN 929Toolbar: CAD drafting DRAWING DESIGN 930Regenerate Std Parts (on toolbar “Library objects”).
CAD software DRAWING DESIGN 931Command line: SPREGENSTD.
The team needed to upgrade the graphics part of the object (s).
Operation
1. Call the command “Regenerate STD parts” 2. Specify the objects that you need to update or Enter, if you need to update all of the objects. 3. These objects will be updatedUser defined object
CAD drawing DRAWING DESIGN 932Main menu: Construction – Library objects – CAD drafting DRAWING DESIGN 933User defined object.
CAD software DRAWING DESIGN 934Ribbon: Construction – Library objects – CAD drawing DRAWING DESIGN 935User defined object.
CAD drafting DRAWING DESIGN 936Toolbar: CAD software DRAWING DESIGN 937User defined object (on toolbar “Library objects”).
CAD drawing DRAWING DESIGN 938Command line: SPCUSTOMOBJ.
Tool User object makes it easy to group in objects nanoCAD and nanoCAD Construction 23 into a single object. Custom objects support the ability to overlap other objects in the drawing.
1. Select the objects to create a custom object. 2. Specify part origin point. 3. Specify the drawing insertion and direction. 4. In the dialog box, set the value of the level of overlap of the object (for Level Z).CAD drafting DRAWING DESIGN 939
When you create a custom object contour suppression, external contour of the object is automatically detected contour suppression external contour of the object. Subsequently, the control circuit is used when objects overlap on the drawing..
Custom objects support editing with standard tools nanoCAD Construction 23.
Dialog “Overrides”
CAD software DRAWING DESIGN 940Shortcut: ALT+RBM (when you hover over a line or shading standard element).
It overrides the style of the individual lines in a standard cell.
Sample call
1. Insert a standard element, such as I-beams.In the properties, select the rendition of “left view” and the type of display “view with a cut”.
CAD drawing DRAWING DESIGN 941
2. Do not get fooled by the hatch and press ALT+RBM. The “Overrides” dialog box.
CAD drafting DRAWING DESIGN 942
Options
Colour -changes the color of the line.
CAD software DRAWING DESIGN 943CAD drawing DRAWING DESIGN 944CAD drafting DRAWING DESIGN 945
Line width – change the line width.
CAD software DRAWING DESIGN 946CAD drawing DRAWING DESIGN 947CAD drafting DRAWING DESIGN 948
Hatch angle (degree) – controls the tilt hatch. The parameter is active only for the hatch.
CAD software DRAWING DESIGN 949CAD drawing DRAWING DESIGN 950CAD drafting DRAWING DESIGN 951
Hatch step – changes hatching step. The parameter is active only for the hatch.
CAD software DRAWING DESIGN 952CAD drawing DRAWING DESIGN 953CAD drafting DRAWING DESIGN 954
Hide object – it makes an invisible line. The other parameters are ignored.
CAD software DRAWING DESIGN 955CAD drawing DRAWING DESIGN 956CAD drafting DRAWING DESIGN 957
If the setting “Show invisible lines” is “Yes”, then the line will be displayed with a color according to the setting of “Color of invisible lines”.
Override main lines
CAD software DRAWING DESIGN 958Context menu: Override main lines (on the selected object).
CAD drawing DRAWING DESIGN 959Command line: SPOVERRIDEMAINLT, OVERRIDEMAINLT.
Users sometimes need to make retrofit drawings that show both new and existing objects at the same time.
That is, for example, welding new fittings into an existing tank. In this case, the main lines of existing objects (fittings, hatches, bolts, shells, bottoms and any other elements of the base) should be depicted either as thin or dashed lines.
To change these parameters, use the “Override main lines” command.
1. Select the standard elements to override.
CAD drafting DRAWING DESIGN 960
2. Call the “Override main lines” command. The “Overriding the main lines” dialog opens.
CAD software DRAWING DESIGN 961
3. Specify the required parameters.
CAD drawing DRAWING DESIGN 962
4. Click the “OK” button. The main lines of the selected objects will be overridden.
CAD drafting DRAWING DESIGN 963
Dialog
CAD software DRAWING DESIGN 964
Linetype – the parameter allows you to select the line type from the list: Solid or Dashed line.
Width – the parameter allows you to select the line thickness from the list.
Color – the parameter allows you to select the color of the lines.
Button CAD drawing DRAWING DESIGN 965“Clear all redefinitions” – removes all previously made overrides, brings the selected objects to the default settings.
Dimensions
Dimension Style Manager
CAD drafting DRAWING DESIGN 966Main menu: Format – CAD software DRAWING DESIGN 967 Dimension Styles….
CAD drawing DRAWING DESIGN 968Main menu: Dimensions – CAD drafting DRAWING DESIGN 969 Dimension Styles….
CAD software DRAWING DESIGN 970Ribbon: Home – Annotation – CAD drawing DRAWING DESIGN 971 Dimension Style Manager.
CAD drafting DRAWING DESIGN 972Toolbar: Settings – CAD software DRAWING DESIGN 973Dimension Style Manager.
CAD drawing DRAWING DESIGN 974Command line: DIMSTYLE.
The software defaults to a government industry standard dimension style.
Dimension styles allow you to control the appearance of dimensions and quickly format them.
CAD drafting DRAWING DESIGN 975
Dialog box composition
The inscription “Current style: …” – information about the current dimension style, which is used when applying dimensions.
“Styles” list – a list of all dimension styles in the document.
The “Preview of: …” window is a graphical representation of the style selected in the “Styles” list.
Buttons:
· Set current – sets the selected dimension style current. · New… – opens a dialogue “Creating style”. · Modify… – change the parameters of the style selected in the list. Opens dialog “Modify dimension style”. · Override… – change the parameters of the current dimension style. Opens dialog “Modify dimension style”. · Compare… – compare two dimension styles, or view a list of all the properties of a style. The comparison results can be copied to the clipboard. Opens dialog “Comparing Dimension Styles”. · Delete… – deletes the selected dimension style.Restoring the Dimension Style
CAD software DRAWING DESIGN 976Command line: SPSETGOST, SETGOST.
This command is necessary to create (restore) the standard dimensional style of the environment nanoCAD Construction .
Dimension style settings are stored within drawing files. If the file was not created in nanoCAD Construction , then it may not have the required dimension style for correct work in the nanoCAD Construction environment.
Creating a dimension style
Button “New…” in the dialog box “Dimension style manager”.
The new style is based on the existing style.
CAD drawing DRAWING DESIGN 977
Field “New Style Name” – style name.
List “Start With” – the style on the basis of which the new one will be created.
List “Use for” – a dimension sub-style is selected from the list (applicable only to certain types of dimensions).
Button “OK” – opens a dialogue “Modify dimension style”.
In the “Modify dimension style” dialog, properties for a new style are set and parameters of an existing one are edited.
This dialog is called when you click the “Modify…” or “Override…” buttons from the “Dimension Style Manager”, as well as from the “Creating style” window.
The name of the edited style is reflected in the title of the dialog.
CAD drafting DRAWING DESIGN 978
Dialog “Modify dimension style” contains tabs:
· Lines · Symbols and arrows · Text · Fit · Primary units · Alternate units · TolerancesThe model image on each tab shows a preliminary result of the property changes.
Tab Lines
Sets the format and properties of dimension lines, extension lines, arrows, and center marks.
CAD software DRAWING DESIGN 979
Simension lines
Color – setting the color of dimension lines.
Linetype – setting the dimension line type.
Lineweight – setting weights for dimension lines.
Extend deyond ticks – when using serifs as dimension arrows, setting the distance the dimension line should extend beyond the extension lines.
Baseline spacing – setting the distance between dimension lines in dimensions from a common base.
Suppress – sets the suppression of the display of dimension lines if they go beyond the extension lines.
· Dim line 1 – suppress the first dimension line. · Dim line 2 – suppress the second dimension line.Extension lines
Color – setting the color of the extension lines.
Linetype ext line 1 – setting the type of the first extension line.
Linetype ext line 2 – setting the type of the second extension line.
Lineweight – setting weights for extension lines.
Suppress – set to suppress extension lines:
· Ext line 1 – suppress the first extension line. · Ext line 2 – suppress the second extension line.Extend beyond dim lines – setting the distance that extension lines should protrude beyond the dimension line.
Offset from origin – sets the distance by which extension lines deviate from object points.
Fixed length extenson lines – sets the full length of the extension lines from the dimension line to the origin of the dimension.
Tab Symbols and arrows
Sets the format and position of arrows, center marks, arc length symbols, and radius dimension polylines.
CAD drawing DRAWING DESIGN 980
Arrowheads
Controls the appearance of dimension arrows.
First – selection of the arrow type for the first dimension line. When you change the type of the first arrow, the type of the second is automatically changed.
Second – selection of the arrow type for the second dimension line.
Leader – setting the arrow type for the leader.
Arrow size – displaying the existing one and setting a new size for the arrows.
Center marks
Controls the placement of center marks and centerlines when placing a diameter or radius.
None – do not create center mark and centerlines.
Mark – create a center mark.
Line – create centerlines.
Size – displays an existing one and sets a new size for the center mark or centerline.
Arc length symbol
Controls the display of the arc symbol in the arc length dimension.
Preceding dimension text – inserts arc length characters before dimension text.
Above dimension text – inserts arc length characters above dimension text.
None – prohibiting the display of arc length symbols.
Radius dimension jog
Controls the display of broken lines (zigzags) of radius dimensions, in cases where the center is located outside the page.
Jog angle – sets the angle of the perpendicular line connecting the extension and dimension lines of the radius dimension.
Tab Text
Setting the format, placement and alignment of dimension texts.
CAD drafting DRAWING DESIGN 981
Text appearance
Text style – selects the current dimension text style from the list.
Text color – setting the color of the dimension text.
Fill color – setting the background color of the text in dimensions.
Text height – sets the current height of the dimension text. If the text style specifies a fixed height (that is, the style’s height value is not 0), then the height entered here is ignored.
Fraction height scale – setting the scale of fractional values relative to the rest of the text. This option is available if the “Unit format” is set to “Fractional” on the “Primary units” tab. The height of fractional texts is determined by multiplying the height of the regular text by a given factor.
Draw frame around text – sets the display of dimension text in a frame.
Text placement
Vertical – select the option to align the dimension text vertically relative to the dimension line:
· Centered – centered dimension text between extension lines. · Above – positioning the dimension text above the dimension line. The distance from the dimension line to the bottom border of the text is equal to the value specified in the “Offset from dim line” option. · Outdise – positioning the dimension text next to the dimension line on the side farthest from the first fit point. · JIS – placement of dimension text in accordance with the requirements of Japanese industrial standards JIS (Japanese Industrial Standards). · Below – the location of the dimension text below the dimension line. The distance from the dimension line to the top border of the text is equal to the value specified in the “Offset from dim line” option.Horizontal – select an option to position the dimension text horizontally along the dimension line relative to the extension lines:
· Centered – centered dimension text between extension lines along the dimension line. · At Ext Line 1 – the location of the text to the left of the first extension line. The distance from the extension line to the text is equal to the sum of twice the dimension arrow (“Symbols and arrows” tab) and the text gap (the “Offset from dim line” option). · At Ext Line 2 – the distance from the extension line to the text is equal to the sum of twice the dimension arrow (“Symbols and arrows” tab) and the text gap (the “Offset from dim line” option). · Over Ext Line 1 – positioning text above or along the first extension line. · Over Ext Line 2 – positioning text above or along the second extension line.Offset from dim line – setting the size of the current text gap (the width of the empty space around the text located at the break in the dimension line). This value is also used as the minimum length of the broken dimension line fragments.
The text is located between the extension lines only if the lengths of these fragments are not less than the size of the text gap. If text is above or below the dimension line, it will only fit between the extension lines if there is enough space for the dimension arrows and dimension text to be spaced apart by the text gap.
Text alignment
Sets the orientation of the dimension text between and outside dimension lines.Horizontal – place text horizontally.
Aligned with dimension line – place text along the dimension line.
ISO standart – place along the dimension line if the text is inside the extension lines, or horizontally if the text is outside.
Tab Fit
Controls the position of dimension text, arrows, leaders, and dimension lines.
CAD software DRAWING DESIGN 982
Fit options
Set the layout of text and arrows if there is not enough space between the extension lines to place them together:
Either text or arrows (best fit) – move either the text or arrows outside the dimension lines, whichever is the best location.
Arrows – move outside the extension lines, first arrows, then text.
Text – move outside the extension lines, first the text, then the arrows.
Both text and arrows – if there is not enough space, then both text and arrows are located outside the extension lines.
Always keep text between ext lines – always place text between extension lines.
Suppress arrows if they don’t inside extension lines – if there is not enough space for arrows between the extension lines, they are not displayed.
Text placement
Selecting an action when the dimension text is moved from the default position (specified by the dimension style):
Beside the dimension line – the dimension line moves with the text.
Over dimension line, with leader – dimension lines do not move, but a leader is drawn that connects them and the text. The leader is not drawn if the text is too close to the dimension line.
Over dimension line, without leader – no connections are made between the text and the dimension line.
Scale dimension feature
Use overall scale of – setting the scale factor for all dimension style parameters that specify dimensions, distances and indents, including the height of the text and the size of the arrows.
Scale dimensions to layout – sets a scale factor based on the ratio of units in the current model space viewport and paper space.
Fine tuning
Place text manually – places the dimension at the point specified when prompted for Dimension line position. All horizontal placement modes are ignored.
Draw dim line between ext lines – draw dimension line between extension lines, even if dimension arrows are positioned outside of them.
Tab Primary units
Sets the format and precision of base units, and dimension text prefixes and suffixes.
CAD drawing DRAWING DESIGN 983
Linear dimensions
Unit format – controls the display and format of tolerances in dimension text.
Precision – setting the number of decimal places in the dimension text.
Fraction format – setting format for fractional texts.
Decimal separator – selection of separator type for sizes expressed in decimal units.
Round off – setting rounding rules for all types of dimensions, except for angular dimensions. Example: for a given accuracy of 0.25, all measured distances are rounded to the nearest multiple of 0.25. When you enter a value of 1.0, all measured distances are rounded to the nearest whole value. The number of digits in fractional parts of distances depends on the precision specified in the “Precision” field.
Prefix – defining the dimension text prefix. You can enter special characters or use control codes to display special characters. For example, the control code “%% c” matches the diameter character. An explicit prefix takes precedence over default prefixes such as those used for diameter and radius.
Suffix – definition of a dimension text suffix. You can enter special characters or use control codes to display special characters. For example, typing the suffix mm will add it to the dimension text. The suffix entered here takes precedence over the default suffixes.
Measurement scale
Scale factor – setting the scale factor for linear dimensions. It is recommended not to change the default value of 1.00. The factor has no effect on angular dimensions, rounding accuracy, positive and negative tolerances.
Apply to layout dimension only – applies a scale factor only to dimensions plotted in layout viewports. It is recommended to disable the setting.
Important!
Changing the value of the scale of the dimensions of a style in a customization changes the value in the dimensions of the same style that are already assigned. This bug is unrecoverable for technical reasons.
Zero suppression – Controls the suppression of leading and trailing zeros, as well as feet and inches zero.
· Leading – suppress leading zeros in all decimal sizes. Example: 0.3000 is written as .3000. · Trailing – suppress trailing zeros in all decimal sizes. Example: 11.5000 is represented as 11.5 and 30.0000 is represented as 30.Angular dimensions
Sets the current corner format for angular dimensions.
Units format – selection of units of measure for angular dimensions.
Precision – setting the number of decimal places in angular dimensions.
Zero suppression – control of suppression of leading and trailing zeros.
· Leading – suppress leading zeros in all decimal sizes. Example: 0.3000 is written as .3000. · Trailing – suppress trailing zeros in all decimal sizes. Example: 11.5000 is represented as 11.5 and 30.0000 is represented as 30.Tab Alternate units
Setting the format and precision for alternative dimension units.
CAD drafting DRAWING DESIGN 984
Display alternate units – inclusion of the possibility of using alternative dimensional units.
Alternate units
Unit format – setting the format of alternative units.
Precision – setting the number of decimal places after the decimal point.
Multiplier for all units – setting the conversion factor from basic units to alternative ones. Example: To convert inches to millimeters, enter 25.4. The value has no effect on angular dimensions and does not apply to rounding precision or positive and negative tolerances.
Round distances to – sets the rounding rule for all types of dimensions, except for angular dimensions. Example: when setting the accuracy to 0.25, all measured distances are rounded to the nearest multiple of 0.25. When you enter a value of 1.0, all measured distances are rounded to the nearest whole value. The number of digits in fractional parts of distances depends on the precision specified in the “Precision” field.
Prefix – defining the prefix of the alternate dimension text. You can enter special characters or use control codes to display special characters. For example, the control code “%% c” matches the diameter character. An explicit prefix takes precedence over default prefixes such as those used for diameter and radius.
Suffix – defining the suffix of the alternate dimension text. You can enter special characters or use control codes to display special characters. For example, entering the suffix mm will add it to the text. The suffix entered here takes precedence over the default suffixes.
Zero suppression
Controls the suppression of leading and trailing zeros and feet and inches zero.
Placement
Sets the position of alternate units in dimension text.
After primary value – display the value in alternate units immediately following the value in base units.
Below primary value – display the value in alternate units below the value in base units.
Tab Tolerances
Controls the display and format of tolerances in dimension text.
CAD software DRAWING DESIGN 985
Tolerance format
Method – choice of method for determining tolerances.
None- disable display of tolerances.
Symmetrical – application of two limit deviations, with which the dimension text is displayed with the same upper and lower limit deviations. The tolerance is separated from the dimension by the “±” symbol. The value is entered in the “Upper value” field.
CAD drawing DRAWING DESIGN 986
Deviation – application of two limiting deviations. Dimension text is displayed with different upper and lower tolerance limits. When applying a dimension, a plus sign is put in front of the upper limit deviation and a minus sign in front of the lower one.
CAD drafting DRAWING DESIGN 987
Limits – displays dimension text as limit dimensions. The maximum size limit is above the minimum size limit. The largest limit is obtained by adding the upper limit deviation to the nominal size; the smallest – by subtracting the lower limit deviation from the nominal size.
CAD software DRAWING DESIGN 988
Basic – displays the dimension text as a nominal boxed dimension.
CAD drawing DRAWING DESIGN 989
Precission – setting the number of decimal places after the decimal point.
Upper value – setting the value of the upper limit deviation. When the “Symmetrical” method is turned on, both deviations are assigned this value.
Lower value – setting the value of the lower limit deviation.
Scaling for height – setting the current text height for deviations.
Vertical position – alignment of deviation texts:
· Bottom – alignment of deviation and nominal size on the bottom. CAD drafting DRAWING DESIGN 990 · Middle – aligning deviation and nominal size to the middle of the dimension text. CAD software DRAWING DESIGN 991 · Top – alignment of deviation and nominal size at the top. CAD drawing DRAWING DESIGN 992Zero suppression – control of suppression of leading and trailing zeros.
· Leading – suppress leading zeros in all decimal sizes. Example: 0.3000 is written as .3000. · Trailing – suppress trailing zeros in all decimal sizes. Example: 11.5000 is represented as 11.5 and 30.0000 is represented as 30.Alternate units tolerance
Alternative unit tolerance formatting.
· Leading – suppress leading zeros in all decimal sizes. Example: 0.3000 is written as .3000. · Trailing – suppress trailing zeros in all decimal sizes. Example: 11.5000 is represented as 11.5 and 30.0000 is represented as 30.Comparing Dimension Styles
The dialog for comparing two dimension styles or viewing a list of all style properties is invoked by the “Compare…” button in the “Dimension Style Manager” dialog.
CAD drafting DRAWING DESIGN 993
“Compare:” field – selects the first dimension style to compare.
“With:” field – selects the second dimension style for comparison.
“Difference table” – the table contains data on non-matching properties.
Table columns:
· Description – parameter name. · Variable – parameter system name. · Variable value columns – parameter values in compared styles.Button CAD software DRAWING DESIGN 994“Copy to clipboard” – allows you to copy comparison results to the clipboard.
Auto
CAD drawing DRAWING DESIGN 995Main menu: Dimensions – CAD drafting DRAWING DESIGN 996Auto.
CAD software DRAWING DESIGN 997Ribbon: Annotate – Dimensions – CAD drawing DRAWING DESIGN 998Auto.
CAD drafting DRAWING DESIGN 999Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1000Dimensions.
CAD drawing DRAWING DESIGN 1001Toolbar: Dimensions – CAD drafting DRAWING DESIGN 1002Dimensions.
CAD software DRAWING DESIGN 1003Command line: SPMDIM, MDIM.
When inserting dimensions, context menu commands are available to switch the dimension view:
· Auto · Aligned · Horizontal · Vertical · Radius · Diameter · Large arc radius · Arc · Ordinate · Angle · Chain · Base · Properties (Opens the size edit dialog) · GroupNote:
If you hold down the CTRL key while placing linear dimensions at the time you select the dimension line, you can skew the dimension extension lines.
If you hold down the SHIFT key while placing linear or angular dimensions while selecting the position of the dimension line, you can move the dimension text along the dimension line.
Linear dimensioning
To apply the dimension you need:
1. Select a segment;
2. Place the dimension number.
Dimensions can change to horizontal, vertical, or parallel, depending on the position of the drop point.
Dimensioning by selecting characteristic (anchor) points
CAD drawing DRAWING DESIGN 1004
To apply dimensions, you must:
1. Select the first node;
2. Select the second node;
3. Place the dimension number.
When selecting anchor points of the circle, the diameter sign is automatically set.
Dimensioning between two parallel lines
CAD drafting DRAWING DESIGN 1005
To apply the dimensions shown above, you must:
1. Select the first segment;
2. Select the second segment;
Dimensioning through a point perpendicular to the selected line
CAD software DRAWING DESIGN 1006CAD drawing DRAWING DESIGN 1007
1. Specify the segment, perpendicular to which the dimension will be applied;
2. Without interrupting the commands, point to the end point of the line segment (a circle of small diameter should appear around the point);
Undo an erroneously inserted dimension without exiting the command
Dimensioning is performed in a cyclic mode, i.e. when applying one dimension, the team does not stop its work, but suggests setting the next dimension or choosing a different type of dimension. In some cases, the previous dimension may not be set correctly. To remove an erroneous dimension, there is the “Undo” context menu command. You can also call the command with the “Ctrl + Z” hotkeys. The command is available when setting the dimension after specifying the dimension number.
Auxiliary markers
Auxiliary autodimension markers appear when you hover over a drawing object and show what type of dimension will be built in this case:
· CAD drafting DRAWING DESIGN 1008 Indicates that the diametral dimension will be drawn. · CAD software DRAWING DESIGN 1009 Shows what a linear dimension will be drawn (horizontal, vertical or parallel). · CAD drawing DRAWING DESIGN 1010 Shows that the angular dimension will be drawn. · CAD drafting DRAWING DESIGN 1011 Shows that the chain of dimensions will be built. · CAD software DRAWING DESIGN 1012 Shows that the slanted dimension will be drawn. · CAD drawing DRAWING DESIGN 1013 Indicates that the radial dimension will be drawn.Linear dimensions
Aligned dimension
CAD drafting DRAWING DESIGN 1014Main menu: Dimensions – CAD software DRAWING DESIGN 1015Aligned.
CAD drawing DRAWING DESIGN 1016Ribbon: Annotate – Dimensions – CAD drafting DRAWING DESIGN 1017Aligned.
CAD software DRAWING DESIGN 1018Toolbar: Dimensions – CAD drawing DRAWING DESIGN 1019Aligned.
CAD drafting DRAWING DESIGN 1020Context menu: aLigned – when calling any dimension.
CAD software DRAWING DESIGN 1021Command line: SPMDIMALI, MDIMALI.
Horizontal dimension
CAD drawing DRAWING DESIGN 1022Context menu: Horizontal – when calling any dimension.
CAD drafting DRAWING DESIGN 1023Command line: SPMDIMHOR, MDIMHOR.
Vertical dimension
CAD software DRAWING DESIGN 1024Context menu: Vertical – when calling any dimension.
CAD drawing DRAWING DESIGN 1025Command line: SPMDIMVER, MDIMVER.
Parallel, horizontal, vertical dimensions
1. Choose dimension;
2. Select the type of binding:
· “nEarest snap gets object” – dimensions the entire selected object; · “nEarest snap gets point” (default) – sets dimension nodes at a selected location on an object.3. Specify the end nodes of the dimension based on the selected snap type:
· “nEarest snap gets object” – specify an object, the end nodes of the dimension will be the end points of the object; · “nEarest snap gets point” – specify the start and end nodes on the selected object.4. Place the dimension number. The dimension will be built.
Auxiliary markers
Construction markers appear when you select a certain linear dimension:
· CAD drafting DRAWING DESIGN 1026 Parallel dimension is selected. · CAD software DRAWING DESIGN 1027 Horizontal dimension is selected. · CAD drawing DRAWING DESIGN 1028 Vertical dimension is selected.Linear dimension
CAD drafting DRAWING DESIGN 1029Main menu: Dimensions – CAD software DRAWING DESIGN 1030Linear.
CAD drawing DRAWING DESIGN 1031Ribbon: Annotate – Dimensions – CAD drafting DRAWING DESIGN 1032Linear.
CAD software DRAWING DESIGN 1033Toolbar: Dimensions – CAD drawing DRAWING DESIGN 1034Linear.
CAD drafting DRAWING DESIGN 1035Command line: DIMLINEAR.
Linear dimensioning
1. Call the CAD software DRAWING DESIGN 1036“Linear” command;
2. Specify the first node;
3. Indicate the second node;
4. Place the dimension number. Linear dimension will be created.
Radius
CAD drawing DRAWING DESIGN 1037Main menu: Dimensions – CAD drafting DRAWING DESIGN 1038Radius.
CAD software DRAWING DESIGN 1039Ribbon: Annotate – Dimensions – CAD drawing DRAWING DESIGN 1040Radius.
CAD drafting DRAWING DESIGN 1041Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1042Radius.
CAD drawing DRAWING DESIGN 1043Toolbar: Dimensions – CAD drafting DRAWING DESIGN 1044Radius .
CAD software DRAWING DESIGN 1045Context menu: Radial – when calling any dimension.
CAD drawing DRAWING DESIGN 1046Command line: SPMDIMRAD, MDIMRAD.
CAD drafting DRAWING DESIGN 1047CAD software DRAWING DESIGN 1048CAD drawing DRAWING DESIGN 1049
To apply a radial dimension, you must:
1. Select the “Radius” dimension;
2. Select an arc (circle), the dimension will snap to the arc;
3. Specify the insertion point.
Diameter
CAD drafting DRAWING DESIGN 1050Main menu: Dimensions – CAD software DRAWING DESIGN 1051Diameter.
CAD drawing DRAWING DESIGN 1052Ribbon: Annotate – Dimensions – CAD drafting DRAWING DESIGN 1053Diameter.
CAD software DRAWING DESIGN 1054Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1055Diameter.
CAD drafting DRAWING DESIGN 1056Toolbar: Dimensions – CAD software DRAWING DESIGN 1057Diameter.
CAD drawing DRAWING DESIGN 1058Context menu: Diametral – when calling any dimension.
CAD drafting DRAWING DESIGN 1059Command line: SPMDIMDIA, MDIMDIA.
CAD software DRAWING DESIGN 1060
To apply the dimension of the circle, you must:
1. Select the dimension “Diameter”;
2. Select the circle, the dimension snaps to the circle;
3. Pick an insertion point.
Large arc radius
CAD drawing DRAWING DESIGN 1061Main menu: Dimensions – CAD drafting DRAWING DESIGN 1062Large arc radius.
CAD software DRAWING DESIGN 1063Ribbon: Annotate – Dimensions – CAD drawing DRAWING DESIGN 1064Large arc radius.
CAD drafting DRAWING DESIGN 1065Ribbon: – Symbols – CAD software DRAWING DESIGN 1066Large arc radius.
CAD drawing DRAWING DESIGN 1067Toolbar: Dimensions – CAD drafting DRAWING DESIGN 1068Large arc radius.
CAD software DRAWING DESIGN 1069Context menu: big RAdius – when calling any dimension.
CAD drawing DRAWING DESIGN 1070Command line: SPDIMHRAD, DIMHRAD.
CAD drafting DRAWING DESIGN 1071
To dimension a large arc radius, you need to:
1. Select the “Large arc radius” dimension;
3. Specify the insertion point of the arrow;
4. Specify the insertion point of the value on the arrow.
Arc length dimension
CAD software DRAWING DESIGN 1072Main menu: Dimensions – CAD drawing DRAWING DESIGN 1073Arc.
CAD drafting DRAWING DESIGN 1074Ribbon: Annotate – Dimensions – CAD software DRAWING DESIGN 1075Arc length.
CAD drawing DRAWING DESIGN 1076Ribbon: – Symbols – CAD drafting DRAWING DESIGN 1077Arc length dimension.
CAD software DRAWING DESIGN 1078Toolbar: Dimensions – CAD drawing DRAWING DESIGN 1079Arc length.
CAD drafting DRAWING DESIGN 1080Context menu: arC – when calling any dimension.
CAD software DRAWING DESIGN 1081Command line: SPMDIMARC, MDIMARC.
Arc dimension
CAD drawing DRAWING DESIGN 1082
1. Select the arc dimension;
2. Select an arc (the arc dimension will snap to the arc);
Circle dimension
CAD drafting DRAWING DESIGN 1083
2. Specify the starting point on the circle;
3. Specify the end point on the circle;
4. Specify the insertion point.
Ordinate dimension
CAD software DRAWING DESIGN 1084Main menu: Dimensions – CAD drawing DRAWING DESIGN 1085Ordinate dimension.
CAD drafting DRAWING DESIGN 1086Ribbon: Annotate – Dimensions – CAD software DRAWING DESIGN 1087Ordinate.
CAD drawing DRAWING DESIGN 1088Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1089Ordinate dimension.
CAD software DRAWING DESIGN 1090Toolbar: Dimensions – CAD drawing DRAWING DESIGN 1091Ordinate dimension.
CAD drafting DRAWING DESIGN 1092Context menu: Ordinate – when calling any dimension.
CAD software DRAWING DESIGN 1093Command line: SPMDIMORD, MDIMORD.
CAD drawing DRAWING DESIGN 1094
1. Call the “Ordinate dimension” command.
2. Pick the location of the first dimension of the ordinate chain.
CAD drafting DRAWING DESIGN 1095
3. Select the first dimension you set. All subsequent dimensions will be snapped to it. If for some reason dimensioning has been completed (after the first dimension has been added), select the ordinate dimension (or autosize) again and specify the dimensioned.
CAD software DRAWING DESIGN 1096
4. Sequentially specify the coordinates of the remaining dimensions.
CAD drawing DRAWING DESIGN 1097
5. Press the “Esc” key to end the command.
Angle dimension
CAD drafting DRAWING DESIGN 1098Main menu: Dimensions – CAD software DRAWING DESIGN 1099Fill angle.
CAD drawing DRAWING DESIGN 1100Ribbon: Annotate – Dimensions -CAD drafting DRAWING DESIGN 1101Angular.
CAD software DRAWING DESIGN 1102Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1103Angle dimension.
CAD drafting DRAWING DESIGN 1104Toolbar: Dimensions – CAD software DRAWING DESIGN 1105Angle dimension.
CAD drawing DRAWING DESIGN 1106Toolbar: Construction Dimensions – CAD drafting DRAWING DESIGN 1107Angle dimension.
CAD software DRAWING DESIGN 1108Context menu: aNguLar – when calling any dimension.
CAD drawing DRAWING DESIGN 1109Command line: SPMDIMANG, MDIMANG.
Create an angular dimension by specifying two line segments
CAD drafting DRAWING DESIGN 1110CAD software DRAWING DESIGN 1111CAD drawing DRAWING DESIGN 1112
To apply an angular dimension, you must:
1. Select an angular dimension;
2. Select the first segment;
3. Select the second segment;
4. Pick an insertion point.
Angular dimension of hole centers
CAD drafting DRAWING DESIGN 1113CAD software DRAWING DESIGN 1114CAD drawing DRAWING DESIGN 1115CAD drafting DRAWING DESIGN 1116
To apply the angular dimension with the indication of the centers, you must:
2. Specify the center of the axial circle (on which the holes lie);
3. Pick the center of the first hole;
4. Pick the center of the second hole;
5. Pick an insertion point.
Dimensions Chain
CAD software DRAWING DESIGN 1117Main menu: Dimensions – CAD drawing DRAWING DESIGN 1118Dimensions Chain.
CAD drafting DRAWING DESIGN 1119Ribbon: Annotate – Dimensions – CAD software DRAWING DESIGN 1120Continue dimension.
CAD drawing DRAWING DESIGN 1121Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1122Continue dimension.
CAD software DRAWING DESIGN 1123Toolbar: Dimensions – CAD drawing DRAWING DESIGN 1124Dimensions Chain.
CAD drafting DRAWING DESIGN 1125Command line: SPCHAINCONT, CHAINCONT.
A chain of dimensions is a sequence of dimensions counted from the end of the previous dimension (the beginning of each new dimension coincides with the end of the previous one).
Dimension chains can be linear, ordinate, or angular. Before building the base dimensions, at least one linear, ordinate or angular dimension must be applied to the object.
Ordinate chain of dimensions
Note:
Constructing an ordinate chain of dimensions is similar to constructing ordinate dimensions.
1. Call the command;
2. Select the set ordinate dimension (the dimension from which the ordinate sizes will begin to form);
3. Construct the ordinate dimensions in sequence;
4. Press the “Enter” key to complete the construction.
Linear dimension chain
2. Select the set linear dimension (the dimension from which the chain of dimensions will begin to form);
CAD software DRAWING DESIGN 1126
3. Specify the required number of anchor points;
CAD drawing DRAWING DESIGN 1127
CAD drafting DRAWING DESIGN 1128
Angle chain dimensions
2. Select the preset angular dimension (the dimension from which the chain of dimensions will begin to form);
CAD software DRAWING DESIGN 1129
CAD drawing DRAWING DESIGN 1130
CAD drafting DRAWING DESIGN 1131
Baseline dimension
CAD software DRAWING DESIGN 1132Main menu: Dimensions – CAD drawing DRAWING DESIGN 1133Base dimension.
CAD drafting DRAWING DESIGN 1134Ribbon: Annotate -Dimensions – CAD software DRAWING DESIGN 1135Baseline dimension.
CAD drawing DRAWING DESIGN 1136Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1137Baseline dimension.
CAD software DRAWING DESIGN 1138Toolbar: Dimensions – CAD drawing DRAWING DESIGN 1139Base dimension.
CAD drafting DRAWING DESIGN 1140Context menu: Base – when calling any dimension.
CAD software DRAWING DESIGN 1141Command line: SPCHAINBASE, CHAINBASE.
Base dimensions are a sequence of dimensions measured from one base point.
Base dimensions can be linear, ordinate, or angular. Before building the base dimensions, at least one linear, ordinate or angular dimension must be applied to the object.
Note:
The construction of an ordinate chain of dimensions is similar to construction ordinate dimension.
Linear base dimensions
2. Select the set dimension as the base (the dimension from which the base sizes will begin to form);
CAD drawing DRAWING DESIGN 1142
3. Specify the required number of anchor points.
CAD drafting DRAWING DESIGN 1143
CAD software DRAWING DESIGN 1144
Note:
Each new dimension is set at a specified distance from the previous one. The value of the offset of the dimensions is set by the “Step” parameter in the base dimensions in the “Lines” tab of the “Modify dimension style” dialog.
Corner base dimensions
2. Select the preset angular dimension (the dimension from which the base dimensions will begin to form);
CAD drawing DRAWING DESIGN 1145
CAD drafting DRAWING DESIGN 1146
CAD software DRAWING DESIGN 1147
Group dimension
CAD drawing DRAWING DESIGN 1148Main menu: Dimensions – CAD drafting DRAWING DESIGN 1149Group dimension.
CAD software DRAWING DESIGN 1150Ribbon: Annotate – Dimensions – CAD drawing DRAWING DESIGN 1151Group dimension.
CAD drafting DRAWING DESIGN 1152Ribbon: – Symbols – CAD software DRAWING DESIGN 1153Group dimension.
CAD drawing DRAWING DESIGN 1154Toolbar: Dimensions – CAD drafting DRAWING DESIGN 1155Group dimension.
CAD software DRAWING DESIGN 1156Context menu: Grouped – when calling any dimension.
CAD drawing DRAWING DESIGN 1157Command line: SPDIMGROUP, DIMGROUP.
CAD drafting DRAWING DESIGN 1158
2. Select all the objects that will participate in creating the group dimension. To complete the selection press the “Enter” key;
3. Specify the location of the chain of dimensions.
If the setting “Arrows in chains” is set to “Point”, then when dimensioning a chain of small numerical dimensions, intersecting arrows are automatically replaced by dots.
CAD software DRAWING DESIGN 1159CAD drawing DRAWING DESIGN 1160
Offset dimension
CAD drafting DRAWING DESIGN 1161Main menu: Dimensions – CAD software DRAWING DESIGN 1162Offset dimension.
CAD drawing DRAWING DESIGN 1163Ribbon: – Symbols – CAD drafting DRAWING DESIGN 1164Offset dimension.
CAD software DRAWING DESIGN 1165Toolbar: Dimensions – CAD drawing DRAWING DESIGN 1166Offset dimension.
CAD drafting DRAWING DESIGN 1167Command line: SPDIMOFFSET, DIMOFFSET.
The command allows you to build a size similar to the contour of the selected object. Similarity size is indicated by an arc above the value.
1. Call the command CAD software DRAWING DESIGN 1168“Offset dimension”.
2. Select the method for specifying the object: “sElection” or “frEe”. The “sElection” method is used in paper space when you need to dimension an object in an inactive viewport. In all other cases, the “frEe” method is used.
3. Specify the object from which the dimension will be built. The selected object can be specified: line, arc, spline, polyline, circle or ellipse.
CAD drawing DRAWING DESIGN 1169
4. Specify the first insertion point (starting point of origin of the dimension) or press the “Space” (or RMB) to automatically add endpoints to the entire length of the object (does not work for closed objects).
CAD drafting DRAWING DESIGN 1170
5. Specify the second insertion point (end point of origin of the dimension), if you have not pressed the “Space” (or RMB) key.
CAD software DRAWING DESIGN 1171
6. Place the dimension leader in the drawing.
CAD drawing DRAWING DESIGN 1172
7. Offset dimension will be built. The command will continue to work in a cyclic mode. Press the “Esc” key to exit cyclic mode.
Grips
1. Dimension value placement grip.
2. Extension line position grips.
3. Dimension endpoint grips.
CAD drafting DRAWING DESIGN 1173
Edit dimension
CAD software DRAWING DESIGN 1174LMB double click on the dimension.
CAD drawing DRAWING DESIGN 1175Context menu: Properties – when calling any dimension.
CAD drafting DRAWING DESIGN 1176Context menu: Edit – at the selected dimension.
CAD software DRAWING DESIGN 1177Command line: SPFEDIT, FEDIT.
The dialog box looks like this:
CAD drawing DRAWING DESIGN 1178
The window is divided into an area of text input fields with the name of the dimension type and a set of dimension design commands.
Additional auxiliary commands are available in the context menu of the dialog box text fields:
· History – the list contains the values previously entered in this field; · Recent – the list contains frequently used values when filling in this type of field; · Insert division- allows you to insert a division; · Pick from drawing – allows you to copy values from drawing objects; · Symbols – allows you to insert symbols from a list or from a symbol table; · etc.The presence of this or that command in the context menu depends on the purpose of the field.
The button in front of the dimension value input field allows you to add special characters to the dimension text.
CAD drafting DRAWING DESIGN 1179
Buttons CAD software DRAWING DESIGN 1180“First arrow” and CAD drawing DRAWING DESIGN 1181“Second arrow” allow you to select the type of arrows. When you click on them, a list with images of arrow options appears.
CAD drafting DRAWING DESIGN 1182
Button CAD software DRAWING DESIGN 1183“Test on leader” – toggles the display mode of the text on the leader.
Button CAD drawing DRAWING DESIGN 1184“Text in rectangle”- toggles the display mode of dimension text in a rectangle.
Button CAD drafting DRAWING DESIGN 1185“Dimension value display scale”- provides a list of display scales for the size value. Default 1:100.
Button CAD software DRAWING DESIGN 1186“Calculate value” – calls the calculator to calculate the value.
Button CAD drawing DRAWING DESIGN 1187“Text style” – calls the text settings dialog box.
CAD drafting DRAWING DESIGN 1188
Button CAD software DRAWING DESIGN 1189“Match properties”- allows you to copy properties from an existing dimension in the drawing.
Break dimension line
CAD drawing DRAWING DESIGN 1190Main menu: Dimensions – CAD drafting DRAWING DESIGN 1191Break dimension.
CAD software DRAWING DESIGN 1192Main menu: Construction – Breaks – CAD drawing DRAWING DESIGN 1193Break dimension line.
CAD drafting DRAWING DESIGN 1194Ribbon: Annotate – Dimensions -CAD software DRAWING DESIGN 1195Break dimension line.
CAD drawing DRAWING DESIGN 1196Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1197Break dimension line.
CAD software DRAWING DESIGN 1198Toolbar: Dimensions – CAD drawing DRAWING DESIGN 1199Break dimension line.
CAD drafting DRAWING DESIGN 1200Toolbar: Construction Breaks – CAD software DRAWING DESIGN 1201Break dimension line.
CAD drawing DRAWING DESIGN 1202Command line: SPDIMBREAK, DIMBREAK.
To create a dimension line break, you must:
· Call the command; · Select the dimension. If the size was selected before calling the command, you do not need to select it again; · Select two points by specifying a section of the dimension line to create a break; · The break will be made.CAD drafting DRAWING DESIGN 1203
First point selection
CAD software DRAWING DESIGN 1204
Second point selection
CAD drawing DRAWING DESIGN 1205
Result
Restore dimension line
CAD drafting DRAWING DESIGN 1206Main menu: Dimensions – CAD software DRAWING DESIGN 1207Restore dimension.
CAD drawing DRAWING DESIGN 1208Main menu: Construction – Breaks – CAD drafting DRAWING DESIGN 1209Unbreak dimension line.
CAD software DRAWING DESIGN 1210Ribbon: Unnotate – Dimensions – CAD drawing DRAWING DESIGN 1211Unbreak dimension line.
CAD drafting DRAWING DESIGN 1212Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1213Unbreak dimension line.
CAD drawing DRAWING DESIGN 1214Toolbar: Dimensions – CAD drafting DRAWING DESIGN 1215Unbreak dimension line.
CAD software DRAWING DESIGN 1216Toolbar: Construction Breaks – CAD drawing DRAWING DESIGN 1217Unbreak dimension line.
CAD drafting DRAWING DESIGN 1218Command line: SPDIMUNBREAK, DIMUNBREAK.
To restore the dimension line, you must:
· Call the command; · Select the dimension. If the size was selected before calling the command, you do not need to select it again;; · The restoration will be done.Oblique dimension
CAD software DRAWING DESIGN 1219Main menu: .
CAD drawing DRAWING DESIGN 1220Ribbon: .
CAD drafting DRAWING DESIGN 1221Command line: SPDIMOBLIQUE, DIMOBLIQUE.
The command allows you to skew the dimension.
1. Call the command CAD software DRAWING DESIGN 1222“Oblique Dimension”.
2. Select the required dimensions. Press the “Enter” key to complete the selection.
3. Enter the angle of inclination and press the “Enter” key.
4. The selected dimensions will change the angle of inclination.
Arrange dimensions
CAD drawing DRAWING DESIGN 1223Command line: SPDIMARRANGE.
To arrange, you need:
CAD drafting DRAWING DESIGN 1224
2. Indicate the dimensions to be aligned;
CAD software DRAWING DESIGN 1225
3. Confirm the selection with the “Enter” key;
4. Pick a new location for the dimension group.
CAD drawing DRAWING DESIGN 1226
Elevation marks
Elevation mark
CAD drafting DRAWING DESIGN 1227Main menu: Construction – Level marks – CAD software DRAWING DESIGN 1228Elevation mark.
CAD drawing DRAWING DESIGN 1229Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1230Level mark.
CAD software DRAWING DESIGN 1231Toolbar: Level marks – CAD drawing DRAWING DESIGN 1232Elevation mark.
CAD drafting DRAWING DESIGN 1233Command line: SPLEVEL.
CAD software DRAWING DESIGN 1234
1. Call the command CAD drawing DRAWING DESIGN 1235“Elevation mark”.
2. Pick an insertion point for the base elevation mark.
CAD drafting DRAWING DESIGN 1236
3. Select the position of the elevation mark text. The “Elevation mark” dialog will open.
CAD software DRAWING DESIGN 1237
4. In the “Elevation mark” dialog box enter the required values.
CAD drawing DRAWING DESIGN 1238
5. Click the “OK” button.
6. Specify the insertion points and text position for subsequent elevation marks. Subsequent elevation marks are associated with the baseline and their value is calculated automatically.
CAD drafting DRAWING DESIGN 1239
7. Press the “Enter” key or RMB to complete the construction of elevation marks.
Dialog
CAD software DRAWING DESIGN 1240
The “Elevation” text box contains the numerical value of the level in meters. The default value that appears in the window is automatically calculated and is the Y-axis distance from the insertion point of the base elevation to the specified elevation point (for the base elevation, the default is 0). Marks above zero are displayed with a “+” prefix, and below zero with a “-” prefix. The 0.000 mark has no prefix.
In the “Comment” column, you can enter explanatory text for the mark.
The CAD drawing DRAWING DESIGN 1241“Associative” button controls the association of the elevation mark with the base elevation. When editing associative elevations in the dialog box, the height value field is grayed out and the CAD drafting DRAWING DESIGN 1242“Associative” button is shown when pressed.
CAD software DRAWING DESIGN 1243
To turn off the associativity of the editable mark, turn off the CAD drawing DRAWING DESIGN 1244“Associative” button. If necessary, set associativity with a different elevation, click the CAD drafting DRAWING DESIGN 1245“Associative” button and select the desired elevation in the drawing as the base.
If, after inserting, you call the base mark for editing, the CAD software DRAWING DESIGN 1246“Detach owned markers” (anchor) button will be highlighted in the dialog box. When you click on it, the base elevation mode is disabled and all associated elevations lose associativity. A level elevation automatically becomes base if one or more other elevations are associated with it.
Anchor
CAD drawing DRAWING DESIGN 1247
The “Anchor” object points to a base elevation mark to which other elevation marks are associated.
The number of associated level marks is indicated next to the anchor.
The display of associativity links is turned on / off by calling the “Edit” command: in the tooltip, in the context menu, RMB on the anchor.
Grips
Elevation mark grips
CAD drafting DRAWING DESIGN 1248
1. Grip for moving the base.
2. Grip for adding new level marks. Pressing the knob activates the command for adding new level marks. The new level marks will be associated with the edited level mark, which in turn will become the base mark.
3. Grip for moving the position of the arrow.
4. Grip for specifying the base mark. When you press the grip, you must select the level mark that is the base for the edited level mark.
5. Grip for moving the level mark shelf along the Y axis.
The base elevation in the drawing is highlighted with an “Anchor” icon. When you hover over the “Anchor”, a tooltip appears with a link to edit. When you select the “Edit” command for the “Anchor” icon, the elevation marks associated with the selected base elevation mark are highlighted in the drawing. To turn off the highlight, re-invoke the “Edit” command for the “Anchor” icon.
CAD software DRAWING DESIGN 1249
Note:
Hints are included in “Construction – Settings… – Tab “Main options” – Notifications – Enable Hints”
Elevation mark anchor grips
CAD drawing DRAWING DESIGN 1250
1. A grip for changing the calculated angle (by default, the coefficient of distance between marks is sin (90) = 1). The grip is used when calculations need to be performed not in the XY plane, but in some other custom coordinate system.
sin(90)
sin(30)
CAD drafting DRAWING DESIGN 1251
CAD software DRAWING DESIGN 1252
Linked elevation mark grips
CAD drawing DRAWING DESIGN 1253
1. Grip for aligning to baselines. X-aligns the insertion point of the level mark with the insertion point of the base level mark.
2. Grip for moving the base.
4. Arrow alignment grip. Aligns the X axis of the insertion point of the level mark arrow with the insertion point of the base level mark arrow.
CAD drafting DRAWING DESIGN 1254Main menu: Construction – Level marks – CAD software DRAWING DESIGN 1255Align level marks by baselines.
CAD drawing DRAWING DESIGN 1256Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1257Align level marks by baselines.
CAD software DRAWING DESIGN 1258Toolbar: Level marks – CAD drawing DRAWING DESIGN 1259Align level marks by baselines.
CAD drafting DRAWING DESIGN 1260Command line: SPLVBASE.
1. Call the command CAD software DRAWING DESIGN 1261“Align level marks by baselines”.
2. Specify the level mark in the drawing to which the alignment will be carried out.
CAD drawing DRAWING DESIGN 1262
3. Select the level marks you want to align (with a box or any other method).
CAD drafting DRAWING DESIGN 1263
4. Press the “Enter” key or RMB to complete the selection. The level marks will be aligned to the baselines.
CAD software DRAWING DESIGN 1264
Align level marks by arrows
CAD drawing DRAWING DESIGN 1265Main menu: Construction – Level marks – CAD drafting DRAWING DESIGN 1266Align level marks by arrows.
CAD software DRAWING DESIGN 1267Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1268Align level marks by arrows.
CAD drafting DRAWING DESIGN 1269Toolbar: Level marks – CAD software DRAWING DESIGN 1270Align level marks by arrows.
CAD drawing DRAWING DESIGN 1271Command line: SPLVARROW.
1. Call the command CAD drafting DRAWING DESIGN 1272“Align level marks by arrows”.
CAD software DRAWING DESIGN 1273
CAD drawing DRAWING DESIGN 1274
4. Press the “Enter” key or RMB to complete the selection. The level marks will be aligned with the arrows.
CAD drafting DRAWING DESIGN 1275
Level mark on plane
CAD software DRAWING DESIGN 1276Main menu: Construction – Level marks – CAD drawing DRAWING DESIGN 1277Level mark on plane.
CAD drafting DRAWING DESIGN 1278Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1279Level mark on plane.
CAD drawing DRAWING DESIGN 1280Toolbar: Level marks – CAD drafting DRAWING DESIGN 1281Level mark on plane.
CAD software DRAWING DESIGN 1282Command line: SPPLLEVEL.
CAD drawing DRAWING DESIGN 1283
1. Call the command CAD drafting DRAWING DESIGN 1284“Level mark on plane”.
2. Specify the insertion point for the first level mark in the drawing. The “Plane elevation marks” dialog will open.
CAD software DRAWING DESIGN 1285
3. In the “Plane elevation marks” dialog box, enter a level value. Determine the number of extension lines. Select the appearance of the level mark: framed, underlined, or text only.
CAD drawing DRAWING DESIGN 1286
4. Confirm your selection with the “OK” button.
5. Specify the extension lines (if you selected the value of the extension lines “single” or “multi”, to complete the selection of lines, press the “Esc” key).
CAD drafting DRAWING DESIGN 1287
6. The command works in cyclic insert mode. Insert the required number of level marks into the drawing. End the loop command with the “Esc” key.
Grips
CAD software DRAWING DESIGN 1288
1. Drop-down arrow type selection grip.
2. Leader line position grip.
3. Leader line grip.
4. Grip for changing the position of the shelf.
5. Drop-down grip for selecting the type of drawing.
Recalculate level marks
CAD drawing DRAWING DESIGN 1289Main menu: Construction – Level marks – CAD drafting DRAWING DESIGN 1290Recalculate level marks.
CAD software DRAWING DESIGN 1291Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1292Recalculate level marks.
CAD drafting DRAWING DESIGN 1293Toolbar: Level marks – CAD software DRAWING DESIGN 1294Recalculate level marks.
CAD drawing DRAWING DESIGN 1295Command line: SPLVRENUM.
1. Call the command CAD drafting DRAWING DESIGN 1296“Recalculate level marks”.
2. Select the level mark to be the reference point.
CAD software DRAWING DESIGN 1297
2. Select the non-associative level marks to be recalculated (with a box or any other method).
CAD drawing DRAWING DESIGN 1298
3. Press the “Enter” button. A recalculation will be performed.
CAD drafting DRAWING DESIGN 1299
Notes
Mechanical note
CAD software DRAWING DESIGN 1300Main menu: Draw – Notes – CAD drawing DRAWING DESIGN 1301Mechanical note.
CAD drafting DRAWING DESIGN 1302Ribbon: Annotate – Leaders – CAD software DRAWING DESIGN 1303Mechanical note.
CAD drawing DRAWING DESIGN 1304Command line: SPNOTE, NOTE.
CAD drafting DRAWING DESIGN 1305
1. Call the command. 2. If the option “Show dialog before inserting objects” is active, the “Mechanical note” dialog opens. In the “Mechanical note” dialog box, enter text and define the note options. Click “OK”. 3. Pick a point on the object (position of the leader arrow). 4. Place a note leader in the drawing. 5. If the “Show dialog before inserting objects” option is disabled, the “Mechanical note” dialog will open.In the “Mechanical note” dialog box, enter text and define the note options. Click “OK”. 6. Note will be biuld.Menu
· CAD software DRAWING DESIGN 1306Add string – command adds an extra input field; · CAD drawing DRAWING DESIGN 1307Remove string – command deletes the input field where the cursor is located; · CAD drafting DRAWING DESIGN 1308Simple note – command toggles the display of the note; · CAD software DRAWING DESIGN 1309Multiline note – command toggles the display of the note; · CAD drawing DRAWING DESIGN 1310Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD drafting DRAWING DESIGN 1311Frame – text under the shelf is framed; · Type arrows: · CAD software DRAWING DESIGN 1312None, · CAD drawing DRAWING DESIGN 1313Arrow, · CAD drafting DRAWING DESIGN 1314Point, · CAD software DRAWING DESIGN 1315Open arrow, · CAD drawing DRAWING DESIGN 1316Half-arrow, · CAD drafting DRAWING DESIGN 1317Oblique; · Align text horizontally; · CAD software DRAWING DESIGN 1318By left edge · CAD drawing DRAWING DESIGN 1319By center · CAD drafting DRAWING DESIGN 1320By right edge · CAD software DRAWING DESIGN 1321Insert special symbol – the command allows you to insert a special character into the input field; · CAD drawing DRAWING DESIGN 1322Notebook – the command allows you to insert data from a notebook into the field; · CAD drafting DRAWING DESIGN 1323Match properties – command copies appearance parameters from another object; · CAD software DRAWING DESIGN 1324Add extension line – the command allows you to add an additional note line; · CAD drawing DRAWING DESIGN 1325Global options – note settings;Context menu
The context menu opens in the input field. View Context menu entry fields.
Fields
By default, “Mechanical note” contains one text box for the label above the leader flange.
Using the CAD drafting DRAWING DESIGN 1326“Simple note” and CAD software DRAWING DESIGN 1327“Multiline note” menu commands, you edit the presence of additional shelves.
Use the CAD drawing DRAWING DESIGN 1328“Add string” and CAD drafting DRAWING DESIGN 1329“Remove string” menu commands to edit the number of leader ledges. When using a simple note, these commands control the presence of text under the shelf.
Note:
Hotkeys are available for the CAD software DRAWING DESIGN 1330“Add string” command. “Ctrl + Enter” – adds a shelf below the selected shelf. “Shift + Enter” – adds a shelf above the selected shelf.
The CAD drawing DRAWING DESIGN 1331“Multi-line text” option allows you to display multiline text on the shelf. When this parameter is enabled, the transition to another line is performed by the “Ctrl + Enter” key combination.
CAD drafting DRAWING DESIGN 1332
CAD software DRAWING DESIGN 1333
CAD drawing DRAWING DESIGN 1334
Construction note
CAD drafting DRAWING DESIGN 1335Main menu: Draw – Notes – CAD software DRAWING DESIGN 1336 Construction note.
CAD drawing DRAWING DESIGN 1337Main menu: Construction – Notes – CAD drafting DRAWING DESIGN 1338Construction note.
CAD software DRAWING DESIGN 1339Ribbon: Annotate – Leaders – CAD drawing DRAWING DESIGN 1340Construction note.
CAD drafting DRAWING DESIGN 1341Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1342Construction note.
CAD drawing DRAWING DESIGN 1343Toolbar: Notes – CAD drafting DRAWING DESIGN 1344Construction note.
CAD software DRAWING DESIGN 1345Command line: SPNOTEP, NOTEP.
CAD drawing DRAWING DESIGN 1346
1. Call the command CAD drafting DRAWING DESIGN 1347“Construction note”.
2. If “Show dialog before inserting the object” is active, the “Construction Note” dialog opens. In the “Construction Note” dialog box, enter text and define the leader options. Click the “OK” button.
3. Pick a point on the object (select the object) to which the leader arrow will point. To select an object, use the “Select” context menu command; to freely specify a point in the drawing, use the “Free” context menu command.
4. Place the leader shelf in the drawing.
Note:
If the parameter “Angle step of extension line” is arbitrary, it is possible to place the leader ledge orthogonally in the ORTO mode (F8). When you turn on the ORTO mode via the “SHIFT” key, Object Snap (F3) must be turned on.
5. If the “Show dialog before inserting the object” option is disabled, the “Construction Note” dialog will open. In the “Construction Note” dialog box, enter text and define the leader options. Click the “OK” button.
6. The note is built.
· CAD software DRAWING DESIGN 1348Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD drawing DRAWING DESIGN 1349Frame – text under the shelf is framed; · Type arrows: · CAD drafting DRAWING DESIGN 1350None, · CAD software DRAWING DESIGN 1351Arrow, · CAD drawing DRAWING DESIGN 1352Point, · CAD drafting DRAWING DESIGN 1353Open arrow, · CAD software DRAWING DESIGN 1354Half-arrow, · CAD drawing DRAWING DESIGN 1355Oblique; · Align text horizontally: · CAD drafting DRAWING DESIGN 1356By left edge, · CAD software DRAWING DESIGN 1357By center, · CAD drawing DRAWING DESIGN 1358By right edge; · CAD drafting DRAWING DESIGN 1359Insert special symbol – the command allows you to insert a special character into the input field; · CAD software DRAWING DESIGN 1360Notebook – the command allows you to insert data from a notebook into the field; · CAD drawing DRAWING DESIGN 1361Match properties – command copies appearance parameters from another object; · CAD drafting DRAWING DESIGN 1362Add extension line – the command allows you to add an additional note line; · CAD software DRAWING DESIGN 1363Global options – note settings.Context menu
Fields
The default positional leader contains two input lines and a list for specifying the pitch of the bevel angle.
The first line is for the label above the leader shelf, the second is under the leader shelf.
In the “Angle step of extension line” list box, the slope angle of the leader lines is selected:
· Custom – a leader line is placed arbitrarily (default); · step 15° – the leader line is put down with a step multiple 15°; · step 30° – the leader line is put down with a step multiple 30°; · step 45° – the leader line is put down with a step multiple 45°; · step 90° – the leader line is put down with a step multiple 90°.Arrow type selection context menu
CAD drawing DRAWING DESIGN 1364
Comb leader note
CAD drafting DRAWING DESIGN 1365Main menu: Draw – Notes – CAD software DRAWING DESIGN 1366 Comb leader note.
CAD drawing DRAWING DESIGN 1367Main menu: Construction – Notes – CAD drafting DRAWING DESIGN 1368Comb leader note.
CAD software DRAWING DESIGN 1369Ribbon: Annotate – Leaders – CAD drawing DRAWING DESIGN 1370Comb leader note.
CAD drafting DRAWING DESIGN 1371Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1372Comb leader note.
CAD drawing DRAWING DESIGN 1373Toolbar: Notes – CAD drafting DRAWING DESIGN 1374Comb leader note.
CAD software DRAWING DESIGN 1375Command line: SPNOTEC, NOTEC.
CAD drawing DRAWING DESIGN 1376
1. Call the command. 2. If the option “Show dialog before inserting objects” is active, the “Comb leader note” dialog opens. In the “Comb leader note” dialog box, enter text and define the note options. Click “OK”. 3. Insert the required number of leader lines. When you specify the location of the leader line, the specified line segment is highlighted. Press the “Enter” key to complete the paste. 4. Specify the slope of the leader lines. Commands for switching the ridge direction are available in the context menu: H – horizontal, V – vertical, P – parallel (parallel to the selected line). 5. Place a note leader in the drawing. 6. If the “Show dialog before inserting objects” option is disabled, the “Comb leader note” dialog will open.In the “Comb leader note” dialog box, enter text and define the note options. Click “OK”. 7. Note will be build.Menu
· CAD drafting DRAWING DESIGN 1377Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD software DRAWING DESIGN 1378Frame – text under the shelf is framed; · Type arrows: · CAD drawing DRAWING DESIGN 1379None, · CAD drafting DRAWING DESIGN 1380Arrow, · CAD software DRAWING DESIGN 1381Point, · CAD drawing DRAWING DESIGN 1382Open arrow, · CAD drafting DRAWING DESIGN 1383Half-arrow, · CAD software DRAWING DESIGN 1384Oblique; · Align text horizontally; · CAD drawing DRAWING DESIGN 1385By left edge · CAD drafting DRAWING DESIGN 1386By center · CAD software DRAWING DESIGN 1387By right edge · CAD drawing DRAWING DESIGN 1388Insert special symbol – the command allows you to insert a special character into the input field; · CAD drafting DRAWING DESIGN 1389Notebook – the command allows you to insert data from a notebook into the field; · CAD software DRAWING DESIGN 1390Match properties – command copies appearance parameters from another object; · CAD drawing DRAWING DESIGN 1391Add extension line – the command allows you to add an additional note line; · CAD drafting DRAWING DESIGN 1392Global options – note settings.Context menu
Fields
Comb leader note by default contains: two lines of input, a list for specifying the pitch of the angle of inclination and the orientation of the ridge.
· Custom – a leader line is placed arbitrarily (default); · step 15° – the leader line is put down with a step multiple 15°; · step 30° – the leader line is put down with a step multiple 30°; · step 45° – the leader line is put down with a step multiple 45°; · step 90° – the leader line is put down with a step multiple 90°.In the “Comb orientation of extension lines” list box, you can select the ridge orientation of the leader lines:
· Custom; · Horizontal; · Vertical.The list is equipped with an additional button CAD software DRAWING DESIGN 1393“Select line”, which allows you to select the direction of the ridge of the leader lines parallel to any line segment in the drawing.
The CAD drawing DRAWING DESIGN 1394“Multi-line text” option allows you to display multiline text on the shelf. When this parameter is enabled, the transition to another line is performed by the “Ctrl + Enter” key combination.
CAD drafting DRAWING DESIGN 1395
Grips
1. Text alignment toggle grip.
2. Leader lines grip.
3. Arrow type switch-grip.
4. Ridge line rotation grip.
5. Shelf rotation grip.
CAD software DRAWING DESIGN 1396
Chain note
CAD drawing DRAWING DESIGN 1397Main menu: Draw – Notes – CAD drafting DRAWING DESIGN 1398Chain note.
CAD software DRAWING DESIGN 1399Main menu: Construction – Notes – CAD drawing DRAWING DESIGN 1400 Chain note.
CAD drafting DRAWING DESIGN 1401Ribbon: Annotate – Leaders – CAD software DRAWING DESIGN 1402 Chain note.
CAD drawing DRAWING DESIGN 1403Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1404 Chain note.
CAD software DRAWING DESIGN 1405Toolbar: Notes – CAD drawing DRAWING DESIGN 1406Chain note.
CAD drafting DRAWING DESIGN 1407Command line: SPNOTEH, NOTEH.
CAD software DRAWING DESIGN 1408
A chain note has several coaxial (collinear) series-connected pointers.
If the first node of the note is placed on a line segment, then the note will be located perpendicular to this segment.
1. Call the command. 2. If the option “Show dialog before inserting objects” is active, the “Chain note” dialog opens. In the “Chain note” dialog box, enter text and define the note options. Click “OK”. 3. Specify note nodes, at least two. To complete the selection of nodes, press “Enter”. 4. Specify the position of the leader where the text will go. 5. If the “Show dialog before inserting objects” option is disabled, the “Chain note” dialog will open.In the “Chain note” dialog box, enter text and define the note options. Click “OK”. 6. Note will be build.Menu
· CAD drawing DRAWING DESIGN 1409Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD drafting DRAWING DESIGN 1410Frame – text under the shelf is framed; · Type arrows: · CAD software DRAWING DESIGN 1411None, · CAD drawing DRAWING DESIGN 1412Arrow, · CAD drafting DRAWING DESIGN 1413Point, · CAD software DRAWING DESIGN 1414Open arrow, · CAD drawing DRAWING DESIGN 1415Half-arrow, · CAD drafting DRAWING DESIGN 1416Oblique; · Align text horizontally; · CAD software DRAWING DESIGN 1417By left edge · CAD drawing DRAWING DESIGN 1418By center · CAD drafting DRAWING DESIGN 1419By right edge · CAD software DRAWING DESIGN 1420Insert special symbol – the command allows you to insert a special character into the input field; · CAD drawing DRAWING DESIGN 1421Notebook – the command allows you to insert data from a notebook into the field; · CAD drafting DRAWING DESIGN 1422Match properties – command copies appearance parameters from another object; · CAD software DRAWING DESIGN 1423Add extension line – the command allows you to add an additional note line; · CAD drawing DRAWING DESIGN 1424Global options – note settings;Context menu
Fields
Chain note contains two lines of input by default.
Input fields are expandable. Switching to another line of the input field is performed by the “Ctrl + Enter” key combination.
CAD drafting DRAWING DESIGN 1425
Section note
CAD software DRAWING DESIGN 1426Main menu: Draw – Notes – CAD drawing DRAWING DESIGN 1427 Section note.
CAD drafting DRAWING DESIGN 1428Main menu: Construction – Notes – CAD software DRAWING DESIGN 1429Section note.
CAD drawing DRAWING DESIGN 1430Ribbon: Annotate – Leaders – CAD drafting DRAWING DESIGN 1431Section note.
CAD software DRAWING DESIGN 1432Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1433Section note.
CAD drafting DRAWING DESIGN 1434Toolbar: Notes – CAD software DRAWING DESIGN 1435Section note.
CAD drawing DRAWING DESIGN 1436Command line: SPNOTES, NOTES.
CAD drafting DRAWING DESIGN 1437
2. If the option “Show dialog before inserting objects” is active, the “Section note” dialog opens. In the “Section note” dialog box, enter text and define the note options. Click “OK”.
3. Select the insert mode “Free” or “Selection”:
· “Selection” – you need to specify the first and second lines to place the note, the cursor is in the form of a square, · “Free” – no lines are required, can be placed anywhere by 2 points, the cursor is in the form of a cross.To switch from the “Selection” mode to the “Free” mode, press the RMB and select the “Enter” command in the context menu. To switch from the “Free” mode to the “Selection” mode, press the RMB. Also, switching modes is carried out with the “Space” key.
4. Pick the first point (select the first line) in the drawing.
5. Pick the second point (select the second line) in the drawing.
6. Specify the position of the leader.
7. If the “Show dialog before inserting objects” option is disabled, the “Section note” dialog will open.In the “Section note” dialog box, enter text and define the note options. Click “OK”.
8. Section note will be build.
· Align text horizontally; · CAD software DRAWING DESIGN 1438By left edge · CAD drawing DRAWING DESIGN 1439By center · CAD drafting DRAWING DESIGN 1440By right edge · Lines; · CAD software DRAWING DESIGN 1441Single-stroked line · CAD drawing DRAWING DESIGN 1442Double-stroked line · CAD drafting DRAWING DESIGN 1443Insert special symbol – the command allows you to insert a special character into the input field; · CAD software DRAWING DESIGN 1444Notebook – the command allows you to insert data from a notebook into the field; · CAD drawing DRAWING DESIGN 1445Match properties – command copies appearance parameters from another object; · CAD drafting DRAWING DESIGN 1446Select line – the command allows you to relocate the location of the leader line by specifying a line in the drawing; · CAD software DRAWING DESIGN 1447Global options – note settings.Context menu
Fields
Section note contains two lines of input by default.
The first line of input consists of two fields for specifying the “Node (sheet) number”.
Second line of input for specifying the “Node address”.
CAD drawing DRAWING DESIGN 1448
Node note
CAD drafting DRAWING DESIGN 1449Main menu: Draw – Notes – CAD software DRAWING DESIGN 1450 Node note.
CAD drawing DRAWING DESIGN 1451Main menu: Construction – Notes – CAD drafting DRAWING DESIGN 1452Node note.
CAD software DRAWING DESIGN 1453Ribbon: Annotate – Leaders – CAD drawing DRAWING DESIGN 1454Node note.
CAD drafting DRAWING DESIGN 1455Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1456Node note.
CAD drawing DRAWING DESIGN 1457Toolbar: Notes – CAD drafting DRAWING DESIGN 1458Node note.
CAD software DRAWING DESIGN 1459Command line: SPNOTEK, NOTEK.
CAD drawing DRAWING DESIGN 1460
2. If the option “Show dialog before inserting objects” is active, the “Node note” dialog opens. In the “Node note” dialog box, enter text and define the leader options. Click “OK”.
3. Pick the center of the leader oval (circle).
4. Specify the size of the leader oval (circle).
5. Show the position of the shelf or enter in advance in the command line the step of the angle of inclination of the leader line.
6. If the “Show dialog before inserting objects” option is disabled, the “Node note” dialog will open.In the “Node note” dialog box, enter text and define the leader options. Click “OK”.
7. Node note will be build.
· Align text horizontally; · CAD drafting DRAWING DESIGN 1461By left edge · CAD software DRAWING DESIGN 1462By center · CAD drawing DRAWING DESIGN 1463By right edge · CAD drafting DRAWING DESIGN 1464Insert special symbol – the command allows you to insert a special character into the input field; · CAD software DRAWING DESIGN 1465Notebook – the command allows you to insert data from a notebook into the field; · CAD drawing DRAWING DESIGN 1466Match properties – command copies appearance parameters from another object; · CAD drafting DRAWING DESIGN 1467Global options – note settings.Context menu
Fields
Node note by default contains: two input lines and a drop-down list for specifying the pitch of the slope.
In the drop-down list “Angle step of extension line”, the slope angle of the leader lines is selected:
CAD software DRAWING DESIGN 1468
CAD drawing DRAWING DESIGN 1469Main menu: Draw – Notes – CAD drafting DRAWING DESIGN 1470 Note for multilayered constructions.
CAD software DRAWING DESIGN 1471Main menu: Construction – Notes – CAD drawing DRAWING DESIGN 1472Note for multilayered constructions.
CAD drafting DRAWING DESIGN 1473Ribbon: Annotate – Leaders – CAD software DRAWING DESIGN 1474Note for multilayered constructions.
CAD drawing DRAWING DESIGN 1475Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1476Note for multilayered constructions.
CAD software DRAWING DESIGN 1477Toolbar: CAD drawing DRAWING DESIGN 1478Notes – CAD drafting DRAWING DESIGN 1479Note for multilayered constructions.
CAD software DRAWING DESIGN 1480Command line: SPNOTEM, NOTEM.
CAD drawing DRAWING DESIGN 1481
1. Call the command. 2. If the option “Show dialog before inserting objects” is active, the “Note for multilayered constructions” dialog opens. In the “Note for multilayered constructions” dialog box, enter text and define the leader options. Click “OK”. 3. Pick a point on an object (drawing). 4. Specify the position of the shelf. 5. If the “Show dialog before inserting objects” option is disabled, the “Note for multilayered constructions” dialog will open. In the “Note for multilayered constructions” dialog box, enter text and define the leader options. Click OK. 6. The note will be built.Menu
· CAD drafting DRAWING DESIGN 1482Add string – command adds an extra input field; · CAD software DRAWING DESIGN 1483Remove string – command deletes the input field where the cursor is located; · CAD drawing DRAWING DESIGN 1484First line – the command adds a border (vertical line before the line) for the first line; · CAD drafting DRAWING DESIGN 1485Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD software DRAWING DESIGN 1486Frame – text under the shelf is framed; · Type arrows: · CAD drawing DRAWING DESIGN 1487None, · CAD drafting DRAWING DESIGN 1488Arrow · CAD software DRAWING DESIGN 1489Point, · CAD drawing DRAWING DESIGN 1490Open arrow, · CAD drafting DRAWING DESIGN 1491Half-arrow, · CAD software DRAWING DESIGN 1492Oblique, · CAD drawing DRAWING DESIGN 1493Right angle; · Align text horizontally; · CAD drafting DRAWING DESIGN 1494By left edge · CAD software DRAWING DESIGN 1495By center · CAD drawing DRAWING DESIGN 1496By right edge · CAD drafting DRAWING DESIGN 1497Insert special symbol – the command allows you to insert a special character into the input field; · CAD software DRAWING DESIGN 1498Notebook – the command allows you to insert data from a notebook into the field; · CAD drawing DRAWING DESIGN 1499Match properties – command copies appearance parameters from another object; · CAD drafting DRAWING DESIGN 1500Select line – the command allows you to relocate the location of the leader line by specifying a line in the drawing; · CAD software DRAWING DESIGN 1501Global options – note settings.Context menu
Fields
By default, “Note for multilayered constructions” contains 5 input fields.
The number of fields is edited using the menu commands “Add string” and “Remove string”.
With the help of the “First line” menu command, the presence of a border on the first line is edited.
Using the “Multi-line text” menu command, you edit the presence of shelves in multiline notes.
CAD drawing DRAWING DESIGN 1502
Linear aligned note
CAD drafting DRAWING DESIGN 1503Main menu: Draw – Notes – CAD software DRAWING DESIGN 1504 Linear Aligned note.
CAD drawing DRAWING DESIGN 1505Main menu: Construction – Notes – CAD drafting DRAWING DESIGN 1506Linear Aligned note.
CAD software DRAWING DESIGN 1507Ribbon: Annotate – Leaders – CAD drawing DRAWING DESIGN 1508Linear Aligned note.
CAD drafting DRAWING DESIGN 1509Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1510Linear Aligned note.
CAD drawing DRAWING DESIGN 1511Toolbar: (Notes – CAD drafting DRAWING DESIGN 1512Linear Aligned note.
CAD software DRAWING DESIGN 1513Command line: SPLINM, LINM.
CAD drawing DRAWING DESIGN 1514
1. Call the command. A dialogue will open “Linear aligned note” 2. In the “Linear aligned note” dialog box, enter text and define the leader options. Click the “OK” button. 3. Specify the subassembly line on which the line subassembly will be located. 4. Specify text position. 5. “Linear aligned note” will be build.Menu
· CAD drafting DRAWING DESIGN 1515Multi-line text – the switch controls the display of multi-line text on the shelf; · Align text horizontally; · CAD software DRAWING DESIGN 1516By left edge · CAD drawing DRAWING DESIGN 1517By center · CAD drafting DRAWING DESIGN 1518By right edge · CAD software DRAWING DESIGN 1519Insert special symbol – the command allows you to insert a special character into the input field; · CAD drawing DRAWING DESIGN 1520Notebook – the command allows you to insert data from a notebook into the field; · CAD drafting DRAWING DESIGN 1521Match properties – command copies appearance parameters from another object; · CAD software DRAWING DESIGN 1522Select line – the command allows you to relocate the location of the leader line by specifying a line in the drawing; · CAD drawing DRAWING DESIGN 1523Auto repeat – when the switch is on, the “Linear aligned note” command, upon completion of the previous command, is restarted; · CAD drafting DRAWING DESIGN 1524Global options – note settings; · CAD software DRAWING DESIGN 1525Multiple insert – when the switch is on, the insert is looped. To exit the cycle, press the “Enter” key.Context menu
Fields
By default “Linear aligned note” contains 2 input fields.
The first field for the label is above the linear structure, the second – under the linear structure.
The CAD drawing DRAWING DESIGN 1526Multi-line text parameter allows you to display multi-line text on the shelf. When this parameter is enabled, the transition to another line is performed by the “Ctrl + Enter” key combination.
CAD drafting DRAWING DESIGN 1527
Distribution range
CAD software DRAWING DESIGN 1528Main menu: Construction – Notes – CAD drawing DRAWING DESIGN 1529Distribution range.
CAD drafting DRAWING DESIGN 1530Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1531Distribution range.
CAD drawing DRAWING DESIGN 1532Command line: SPRANGE.
1. Select the shared object. 2. Select the first point of the border. 3. Select the second point of the border.The command to create a symbol distribution range recurring structural elements in the specified bounds. Arrow pointer automatically aligned perpendicular to the shared object. Beginning marker band (contour point) automatically closes the line on which is situated.
CAD drafting DRAWING DESIGN 1533
Editing Notes
There are 3 commands for editing leaders:
Append leader
CAD software DRAWING DESIGN 1534Main menu: Construction – Notes – CAD drawing DRAWING DESIGN 1535 Append leader.
CAD drafting DRAWING DESIGN 1536Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1537 Append leader.
CAD drawing DRAWING DESIGN 1538Toolbar: CAD drafting DRAWING DESIGN 1539Append leader ( “Notes”).
CAD software DRAWING DESIGN 1540Command line: SPPLADD.
1. Call the team.
2. Pick a point on the object (point of arrow position).
3. Indicate the required number of intermediate points that form a break in the leader line.
4. Point to the desired leader inserted in the drawing to complete the command.
Detach leader
CAD drawing DRAWING DESIGN 1541Main menu: Construction – Notes – CAD drafting DRAWING DESIGN 1542 Detach leader.
CAD software DRAWING DESIGN 1543Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1544 Detach leader.
CAD drafting DRAWING DESIGN 1545Toolbar: CAD software DRAWING DESIGN 1546Detach leader ( “Notes”).
CAD drawing DRAWING DESIGN 1547Command line: SPPLDEL.
1. Call the team.
2. In the drawing, select the leader line you want to delete.
Edit leader
CAD drafting DRAWING DESIGN 1548Main menu: Construction – Notes – CAD software DRAWING DESIGN 1549Edit leader.
CAD drawing DRAWING DESIGN 1550Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1551 Edit leader.
CAD software DRAWING DESIGN 1552Toolbar: CAD drawing DRAWING DESIGN 1553Edit leader ( “Notes”).
CAD drafting DRAWING DESIGN 1554Command line: SPPLREC.
1. Call the team.
2. Highlight on the drawing a leader line that should be chained.
3. Pick a point on the desired leader in order to fix the new position of the leader line.
Adaptive note
nanoCAD Construction 23 allows you to use “Fields (Fields) drawing”.
1. In the context menu of the callout input field, select the “Insert field…” command. The “Field” dialog will open.
CAD software DRAWING DESIGN 1555
2. In the dialog box, link to the desired field and click the “OK” button.
3. The link will be created. When you click on a field link, the scope will move to the linked object.
CAD drawing DRAWING DESIGN 1556
Note:
To update data in adaptive callouts, use the command “Regenerate”.
Save template note
If necessary, save the callouts for later use, you need to create a balloon, defining it related parameters.
CAD drafting DRAWING DESIGN 1557
Further, by selecting it, specify the context menu – “Save object as template”.
In the “Template wizard” press button “Create template”.
In the dialog box “Create element” specify the storage folder in the base elements, Name and Note (if necessary). Press “OK”. Again we return to the dialog box “Template wizard”.
CAD software DRAWING DESIGN 1558
Press button “Update template” and close “Template wizard”.
Update the tree base elements, the template will be created by the note.
CAD drawing DRAWING DESIGN 1559
Subsequently, this note can be inserted into a drawing for new objects. Adaptive communication with new objects and their settings will be saved.
Drawing symbols
Gradient symbol
CAD drafting DRAWING DESIGN 1560Main menu: Construction – Symbols – CAD software DRAWING DESIGN 1561Gradient symbol.
CAD drawing DRAWING DESIGN 1562Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1563Gradient symbol.
CAD software DRAWING DESIGN 1564Toolbar: Symbols – CAD drawing DRAWING DESIGN 1565Gradient symbol.
CAD drafting DRAWING DESIGN 1566Command line: SPGRAD.
2. Using the “Properties” context menu command, open the “Gradient symbol” dialog box. Make the gradient symbol settings and confirm the changes with the “OK” button.
3. Select the line in the drawing for which you want to set the gradient symbol.
4. Place the gradient symbol on the selected line or leader flange.
5. The gradient symbol is drawn and associated associatively with the specified line.
Dialog
CAD software DRAWING DESIGN 1567
The editing dialog contains:
· Selection button type of designation: Gradient without designation, Left gradient and Left taper.CAD drawing DRAWING DESIGN 1568
· Input field for gradient symbol value. The input field is active if the associativity mode is disabled. If necessary, turn off the associative connection mode by turning off the CAD drafting DRAWING DESIGN 1569“Associative” switch (when setting, the associativity mode is turned on automatically). · CAD software DRAWING DESIGN 1570“Pick from driwing” button. When the associativity mode is off, the button is active and allows you to measure the gradient symbol value in the drawing. · Switch CAD drawing DRAWING DESIGN 1571“Associative”. Controls the display of the gradient symbol value. If the switch is on, the value is taken from the associated line, if it is off, it is entered manually. · Drop-down list “Representation”. Allows you to select how the slope units are represented: · As is · Ratio · Decimal · Percent · Permille · Degree · “Text on leader” checkbox. Toggles whether the gradient symbol is on a shelf or on a line. · “Gradient type” group. Allows you to select the type of gradient symbol: · On section · On planeGrips
CAD drafting DRAWING DESIGN 1572
1. Grip for selecting the slope symbol representation.
2. Shelf movement grip.
3. Base move grip. When you move, the associativity with the line is lost and an additional fourth grip appears.
4. Grip for changing the angle of inclination of the base.
Node
CAD software DRAWING DESIGN 1573Main menu: Construction – Symbols – CAD drawing DRAWING DESIGN 1574Node.
CAD drafting DRAWING DESIGN 1575Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1576Node.
CAD drawing DRAWING DESIGN 1577Toolbar: CAD drafting DRAWING DESIGN 1578Node ( “Symbols”).
CAD software DRAWING DESIGN 1579Command line: SPNODE.
1. Select location or type an index “properties”. 2. In the dialog box that describes the node type the text. Click OK.CAD drawing DRAWING DESIGN 1580
3. Insert the desired number of drawing markers. Subsequent node number is automatically incremented from the previous one.Fragment mark
CAD drafting DRAWING DESIGN 1581Main menu: Construction – Symbols – CAD software DRAWING DESIGN 1582Fragment.
CAD drawing DRAWING DESIGN 1583Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1584Fragment.
CAD software DRAWING DESIGN 1585Toolbar: CAD drawing DRAWING DESIGN 1586Fragment ( “Symbols”).
CAD drafting DRAWING DESIGN 1587Command line: SPFR.
1. Select first point (1). 2. Select second point (2).CAD software DRAWING DESIGN 1588
3. In the dialog box Fragment mark enter text. Click OK.CAD drawing DRAWING DESIGN 1589
4. Select location. 5. Complete the cyclic command.Correction Mark
CAD drafting DRAWING DESIGN 1590Main menu: Construction – Symbols – CAD software DRAWING DESIGN 1591Correction mark.
CAD drawing DRAWING DESIGN 1592Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1593Correction mark.
CAD software DRAWING DESIGN 1594Toolbar: CAD drawing DRAWING DESIGN 1595Correction mark ( “Construction”).
CAD drafting DRAWING DESIGN 1596Command line: SPCORRMRK.
1. Select leader position. 2. Select marker location or properties and call the context menu command “P-properties.” 3. In the dialog box change the marker type in the text. Click OK.CAD software DRAWING DESIGN 1597
Position marker
CAD drawing DRAWING DESIGN 1598Main menu: Construction – Symbols – CAD drafting DRAWING DESIGN 1599Marker.
CAD software DRAWING DESIGN 1600Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1601Marker.
CAD drafting DRAWING DESIGN 1602Toolbar: CAD software DRAWING DESIGN 1603Marker( “Symbols”).
CAD drawing DRAWING DESIGN 1604Command line: SPMRKU.
1. Select location or type an index for the first marker, or call the context menu command “P-properties”. 2. In the dialog box multi shape mark select the marker icon form, enter text. Click OK.CAD drafting DRAWING DESIGN 1605
3. Insert the desired number of drawing markers. Item numbers subsequent token is automatically incremented from the previous one.Position
CAD software DRAWING DESIGN 1606Main menu: Construction – Symbols – CAD drawing DRAWING DESIGN 1607Position.
CAD drafting DRAWING DESIGN 1608Toolbar: CAD software DRAWING DESIGN 1609Position (toolbar “Symbols”).
CAD drawing DRAWING DESIGN 1610Command line: SPPOS.
1. Specify the insertion point to the first marker position or call the context menu command “P-properties.” 2. In the dialog box Tagging enter text. 3. Select an arrow. Click OK. 4. Insert the desired number of drawing markers. Subsequent node number is automatically incremented from the previous.Fundamental rules
This command draws the drawing reference numerals used in the drawings.
Sequencing
Insert position by specifying the datum marker
CAD drafting DRAWING DESIGN 1611
Next, mark the position statement of the position:
CAD software DRAWING DESIGN 1612
Inserted into a single command cycle positions are automatically numbered
CAD drawing DRAWING DESIGN 1613
To specify additional options position must call dialog “Position”, where you can specify the text position display option arrows (switches below the text input field).
CAD drafting DRAWING DESIGN 1614
Stationing
CAD software DRAWING DESIGN 1615Main menu: Construction – Symbols – CAD drawing DRAWING DESIGN 1616Stationing.
CAD drafting DRAWING DESIGN 1617Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1618Stationing.
CAD drawing DRAWING DESIGN 1619Toolbar: Construction symbols – CAD drafting DRAWING DESIGN 1620Stationing.
CAD software DRAWING DESIGN 1621Command line: SPSTATIONING.
1. Call a command CAD drawing DRAWING DESIGN 1622“Stationing”. The “Stationing” dialog will open.
2. In the “Stationing” dialog box, set the parameters of the station and confirm the settings with the “OK” button.
3. Insert the first anchor leader or specify the polyline on which the stationing will be placed. When specifying a polyline, the first anchor leader will be set to the starting point of the polyline. The first designation of the station is the anchor, the report goes from it and the subsequent inserted station is connected with it.
4. Position the text of the first mark.
5. Insert the desired number of marks. If a polyline was specified, the leader arrow will be associated with the polyline. To finish inserting station symbols, press the “Enter” key.
Edit
CAD drafting DRAWING DESIGN 1623
The edit dialog contains:
1. Text input field above the shelf.
2. Drop-down list of picket designation (mileage): PK or KM.
3. The field for the number of the initial station.
4. The field of the value of the distance of the initial station.
5. Button CAD software DRAWING DESIGN 1624“Associative” – allows you to link a new mark to existing marks. After binding, all fields except the text above the shelf will not be editable.
6. Drop-down list “Stationing distance, m” – sets the distance between pickets. The value is selected from the list, entered manually or taken from the drawing. To specify a value from a drawing, use the CAD drawing DRAWING DESIGN 1625“Measure” command.
7. Switch for selecting the type of mark: CAD drafting DRAWING DESIGN 1626“Positional mark” or CAD software DRAWING DESIGN 1627“Linear mark”.
Grips
CAD drawing DRAWING DESIGN 1628
1. Text alignment knob above the shelf.
2. Handle for moving the shelf.
3. Text stretch/shrink handle.
4. Handle for changing the direction of the shelf location.
5. Handle for turning the shelf.
6. Handle for changing the view: PK or KM.
7. Moving the arrow.
8. Selecting the type of GCP naming.
9. Choice of base mark.
Double-clicking on the anchor on the first mark displays associative links.
CAD drafting DRAWING DESIGN 1629
Views and sections
Section
CAD software DRAWING DESIGN 1630Main menu: Construction – Views and Sections – CAD drawing DRAWING DESIGN 1631Sections.
CAD drafting DRAWING DESIGN 1632Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1633Sections.
CAD drawing DRAWING DESIGN 1634Toolbar: CAD drafting DRAWING DESIGN 1635Sections (on toolbar “Views and Sections”).
CAD software DRAWING DESIGN 1636Command line: SPSECT.
1. Call the team. A dialog box will open “Cut”;
2. In the dialog box, enter the required parameters. Press the button “OK”;
CAD drawing DRAWING DESIGN 1637
3. Select path type: Arc or Segment. For each type its own order of postorieniya;
· Segment. Allows you to create a cut in the form of a broken line; · Pick the first cut point; · Pick the subsequent cut points. To finish entering points, press the key “Enter”; · Arc. Creates an arc section; · Select the desired arc construction method:Arc (3 points), Arc (2 points and bend), ARc (2 points and center); · Build an arc according to your choice.4. Select the direction of the cut arrows.
View
CAD drafting DRAWING DESIGN 1638Main menu: Construction -Views and Sections – CAD software DRAWING DESIGN 1639View.
CAD drawing DRAWING DESIGN 1640Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1641View.
CAD software DRAWING DESIGN 1642Toolbar: CAD drawing DRAWING DESIGN 1643View (on toolbar “Views and Sections”).
CAD drafting DRAWING DESIGN 1644Command line: SPVIEW.
1. In the dialog box type the number and type of sheet. Click OK.CAD software DRAWING DESIGN 1645
2. Select view insert point of the arrow type. 3. Select view angle.View and Section Label
CAD drawing DRAWING DESIGN 1646Main menu: Construction – Views and Sections – CAD drafting DRAWING DESIGN 1647View and Sections label.
CAD software DRAWING DESIGN 1648Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1649View and Sections label.
CAD drafting DRAWING DESIGN 1650Toolbar: CAD software DRAWING DESIGN 1651View and Sections label (on toolbar “Views and Sections”).
CAD drawing DRAWING DESIGN 1652Command line: SPVSDESC.
1. In the dialog box “Designation of views, cuts…” enter the text notation. To denote the section or section select “Cut”.CAD drafting DRAWING DESIGN 1653
2. Click “OK”. 3. Specify the insertion point notation.Bound forms
Bound forms
Bounding hatch
CAD software DRAWING DESIGN 1654Main menu: Construction – Bound forms – CAD drawing DRAWING DESIGN 1655Bounding hatch.
CAD drafting DRAWING DESIGN 1656Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1657Bounding hatch.
CAD drawing DRAWING DESIGN 1658Toolbar: CAD drafting DRAWING DESIGN 1659Bounding hatch ( “Bound forms”).
CAD software DRAWING DESIGN 1660Command line: SPBHATCH.
Ground border
CAD drawing DRAWING DESIGN 1661Main menu: Construction – Bound forms – CAD drafting DRAWING DESIGN 1662Ground border.
CAD software DRAWING DESIGN 1663Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1664Ground border.
CAD drafting DRAWING DESIGN 1665Toolbar: CAD software DRAWING DESIGN 1666Ground border ( “Bound forms”).
CAD drawing DRAWING DESIGN 1667Command line: SPGBORDER.
Heat isolation
CAD drafting DRAWING DESIGN 1668Main menu: Construction – Bound forms – CAD software DRAWING DESIGN 1669Heat isolation.
CAD drawing DRAWING DESIGN 1670Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 1671Heat isolation.
CAD software DRAWING DESIGN 1672Toolbar: CAD drawing DRAWING DESIGN 1673Heat isolation ( “Bound forms”).
CAD drafting DRAWING DESIGN 1674Command line: SPHISOL.
Water isolation
CAD software DRAWING DESIGN 1675Main menu: Construction – Bound forms – CAD drawing DRAWING DESIGN 1676Water isolation.
CAD drafting DRAWING DESIGN 1677Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1678Water isolation.
CAD drawing DRAWING DESIGN 1679Toolbar: CAD drafting DRAWING DESIGN 1680Water isolation ( “Bound forms”).
CAD software DRAWING DESIGN 1681Command line: SPWISOL.
Bar strip
CAD drawing DRAWING DESIGN 1682Main menu: Construction – Bound forms – CAD drafting DRAWING DESIGN 1683Bar strip.
CAD software DRAWING DESIGN 1684Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1685Bar strip.
CAD drafting DRAWING DESIGN 1686Toolbar: CAD software DRAWING DESIGN 1687Bar strip ( “Bound forms”).
CAD drawing DRAWING DESIGN 1688Command line: SPDBAND.
The special lines include: bounding hatch barstrip, heat isolation, water isolation, ground border. Lines have a wide range of applications. For example, the line-border soil formation on geological section.
Drawing bound forms
· To draw a bound form, select the desired Dialog box bounding hatch. · You can immediately apply contour shading on the polyline using the command Simple Polyline context menu. · To build a complex contour on the basis of the drawing objects you can use the command M-magnet context menu. · If you want to create a new path, select the first point and then successively adding segments of the contour line, as is done when creating polylines. In the context menu commands are available for selecting the next segment (line segment or arc) and the method of construction. · To complete the construction of the circuit, press Enter. · In the next window boundary forms can change the type of boundary hatch. ButtonCAD drafting DRAWING DESIGN 1689Hatch side is used to change the part of the overlay relative to the boundary contour shading:CAD software DRAWING DESIGN 1690
To change the contour and side hatch overlay grips (Grips) can be used.
When drawing certain types of boundary forms (notation waterproofing, insulation and dashed lines) before building the circuit the values of hatching must be specified. The values given are based on the current scale nanoCAD Construction 23.
Editing the values of the parameters can be made through the Properties panel (Properties) nanoCAD. For example, the entered value corresponds to 4 400 mm on the standard scale M100.
Breaks
CAD drawing DRAWING DESIGN 1691Main menu: Construction – Breaks – CAD drafting DRAWING DESIGN 1692Break lines.
CAD software DRAWING DESIGN 1693Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1694Break lines.
CAD drafting DRAWING DESIGN 1695Toolbar: CAD software DRAWING DESIGN 1696Break lines ( “Breaks”).
CAD drawing DRAWING DESIGN 1697Command line: SPBREAK.
1. Select the first point to insert the break line.
2. In the context menu, select the type of break (break) (Linear, Two-lenear, Curved, tWo-curved, tuBular).
3. Pick the second break point.
4. In the context menu, select the type of cursor movement control (FreeOffset, OrthoOffset).
5. Specify the width of the cliff (break). A cliff (break) will be built.
Note:
The whole clipped geometry between the break lines is not actually deleted and can be restored either by removing the break line or editing its contour with the grips nodal points.
Note:
All objects nanoCAD Construction 23 have a so-called Z-Order. This value sets the level of the Z-coordinate in relation to other object-dependent details nanoCAD Construction 23. Editing the value of the order, you can control the mutual overlap of objects nanoCAD Construction 23.
Dialogue
The edit dialog is opened from the tooltip when you hover on a break (break) or when you double-click on a break (break).
CAD drafting DRAWING DESIGN 1698
Editing dialog includes:
· Graphic break type switch; · Field “Length”; · Field “Width”; · Field “Offset”. You can get the value using the offset command CAD software DRAWING DESIGN 1699“Parallel to specified line”.Grips
1. Grips length setting 2. Grips break width settings 3. Break displacement grip 4. Drop-down type grip · Linear · Two-linear · Curve · Two-curve · TubularCAD drawing DRAWING DESIGN 1700
Linear break
CAD drafting DRAWING DESIGN 1701Main menu: Construction – Breaks – CAD software DRAWING DESIGN 1702Linear break.
CAD drawing DRAWING DESIGN 1703Ribbon: Construction- Symbols – CAD drafting DRAWING DESIGN 1704Linear break.
CAD software DRAWING DESIGN 1705Toolbar: CAD drawing DRAWING DESIGN 1706Linear break ( “Breaks”).
CAD drafting DRAWING DESIGN 1707Command line: SPBREAK_LINEAR.
Two-linear break
CAD software DRAWING DESIGN 1708Main menu: Construction – Breaks – CAD drawing DRAWING DESIGN 1709Two-linear break.
CAD drafting DRAWING DESIGN 1710Ribbon: Construction- Symbols – CAD software DRAWING DESIGN 1711Two-linear break.
CAD drawing DRAWING DESIGN 1712Toolbar: CAD drafting DRAWING DESIGN 1713Two-linear break ( “Breaks”).
CAD software DRAWING DESIGN 1714Command line: SPBREAK_TWOLINEAR.
Curved break
CAD drawing DRAWING DESIGN 1715Main menu: Construction – Breaks – CAD drafting DRAWING DESIGN 1716Curved break.
CAD software DRAWING DESIGN 1717Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 1718Curved break.
CAD drafting DRAWING DESIGN 1719Toolbar: CAD software DRAWING DESIGN 1720Curved break ( “Breaks”).
CAD drawing DRAWING DESIGN 1721Command line: SPBREAK_CURVED.
Two-curved break
CAD drafting DRAWING DESIGN 1722Main menu: Construction – Breaks – CAD software DRAWING DESIGN 1723Two-curved break.
CAD drawing DRAWING DESIGN 1724Ribbon: Construction- Symbols – CAD drafting DRAWING DESIGN 1725Two-curved break.
CAD software DRAWING DESIGN 1726Toolbar: CAD drawing DRAWING DESIGN 1727Two-curved break ( “Breaks”).
CAD drafting DRAWING DESIGN 1728Command line: SPBREAK_TWOCURVED.
Shaft break
CAD software DRAWING DESIGN 1729Main menu: Construction – Breaks – CAD drawing DRAWING DESIGN 1730Shaft break.
CAD drafting DRAWING DESIGN 1731Ribbon: Construction- Symbols – CAD software DRAWING DESIGN 1732Shaft break.
CAD drawing DRAWING DESIGN 1733Toolbar: CAD drafting DRAWING DESIGN 1734Shaft break ( “Breaks”).
CAD software DRAWING DESIGN 1735Command line: SPBREAK_TUBULAR.
Welding
Welding…CAD drawing DRAWING DESIGN 1736Main menu: Construction – Weld – CAD drafting DRAWING DESIGN 1737Welding….
CAD software DRAWING DESIGN 1738Toolbar: “Weld” – CAD drawing DRAWING DESIGN 1739Welding….
CAD drafting DRAWING DESIGN 1740Command line: SPISOWELD.
Setting notes refer to welding.
CAD software DRAWING DESIGN 1741
The dialog box consists of three tabs:
General
On the tab, the graphical display and fill in the drawing note.
CAD drawing DRAWING DESIGN 1742
For convenient entry process, you can use Process list.
Process list poddrerzhivaet multiple selection processes.
CAD drafting DRAWING DESIGN 1743
Above side
Tab necessary to fill in the values above the side
The type of weld and its parameters.
CAD software DRAWING DESIGN 1744
Below side
Tab necessary to fill in the values below the side
CAD drawing DRAWING DESIGN 1745
Simple welding
CAD drafting DRAWING DESIGN 1746Main menu: Construction – Welding – CAD software DRAWING DESIGN 1747Simple welding.
CAD drawing DRAWING DESIGN 1748Toolbar: “Weld” – CAD drafting DRAWING DESIGN 1749Simple welding.
CAD software DRAWING DESIGN 1750Command line: SPWLEG.
This command is used to render the weld leg between two intersecting segments.
1. Enter the first rib. 2. Enter the second rib. 3. Press “Enter” or right mouse button to exit the cyclic command.Weld seam
CAD drawing DRAWING DESIGN 1751Main menu: Construction – Weld – CAD drafting DRAWING DESIGN 1752Weld seam.
CAD software DRAWING DESIGN 1753Toolbar: “Weld” – CAD drawing DRAWING DESIGN 1754Weld seam.
CAD drafting DRAWING DESIGN 1755Command line: SPWELD.
1. In the dialog box “Weld seam” press the button corresponding to the desired type of weld. Click OK.CAD software DRAWING DESIGN 1756
2. Specify the first point of the circuit (or P – polyline, C – circle M – magnet). 3. Specify the next point of the contour (or L – line A – arc, C – close, U – rollback, M – a method for constructing the arc). 4. Press Enter or right mouse button to exit the cyclic command.In the dialog box are available 16 types of welds. Each type of weld corresponds to the button with his picture. To select the desired type of seam, press the button and confirm with the OK button.
Construction of the circuit is made by the following methods:
L – via line: construction of straight segments of the weld points introduced;
A – by arc: construction of the weld arc segments in three points;
C – close: automatic generation of the last segment, closing the main line of the weld;
U – recoil: undo the last segment of the weld;
M – a method for constructing the arc: T – tangentially, S – by three points.
Button CAD drawing DRAWING DESIGN 1757Side hatch allows you to select the direction of the hatch.
Change the direction of the hatch, you can select the “handle” the reflection side hatch:
CAD drafting DRAWING DESIGN 1758
Fixed joint
CAD software DRAWING DESIGN 1759Main menu: Construction – Weld – CAD drawing DRAWING DESIGN 1760Fixed joint.
CAD drafting DRAWING DESIGN 1761Ribbon: Construction – Symbols – CAD software DRAWING DESIGN 1762Fixed joint.
CAD drawing DRAWING DESIGN 1763Toolbar: “Weld” – CAD drafting DRAWING DESIGN 1764Fixed joint .
CAD software DRAWING DESIGN 1765Command line: SPFIX.
1. Call the command CAD drawing DRAWING DESIGN 1766“Fixed joint”.
2. Indicate the place of the fixed joint.
CAD drafting DRAWING DESIGN 1767
3. Pick a break point.
CAD software DRAWING DESIGN 1768
4. Specify the end point of the leader or press the “Enter” key, then the end point of the leader will be the break point. The “Joints” editing dialog will open.
CAD drawing DRAWING DESIGN 1769
5. Set the type of joint in the “Joints” editing dialog and confirm the setting with the “OK” button.
6. The Fixed joint will be built.
CAD drafting DRAWING DESIGN 1770
Dialog
Important!
When you select the fixed joint “Soldired Joint Leg” or “Weld point”, you cannot call the dialog from the object for editing.
CAD software DRAWING DESIGN 1771
The editing dialog contains additional commands and two tabs: “Simple representation” and “Full representation”.
· CAD drawing DRAWING DESIGN 1772Place spot welds – the command is intended for insertion of weld point elevations in the drawing. · CAD drafting DRAWING DESIGN 1773Along closed contour – the command is intended to add the symbol “Joint along closed contour” to the connection designation. · The “Simple representation” tab allows you to select the type of fixed joint.CAD software DRAWING DESIGN 1774
The following designations for fixed joints are available:
Seam denotation
Soldering Pasting together Clamps, type 1CAD drawing DRAWING DESIGN 1775
CAD drafting DRAWING DESIGN 1776
CAD software DRAWING DESIGN 1777
CAD drawing DRAWING DESIGN 1778
Clamps, type 2 Lacing Soldired Joint Leg Weld pointCAD drafting DRAWING DESIGN 1779
CAD software DRAWING DESIGN 1780
CAD drawing DRAWING DESIGN 1781
CAD drafting DRAWING DESIGN 1782
Depending on the selected type, the “Full representation” tab will be available. · The “Full representation” tab allows you to customize the fixed joint symbol.CAD software DRAWING DESIGN 1783
Input fields and graphic elements are edited on the tab. To edit input fields and turn on / off graphic elements, click LMB on them. When editing input fields, dialogs for editing fields appear, containing an input field and additional commands.
1. Graphic element “Field joint”.
CAD drawing DRAWING DESIGN 1784
2. Graphic element “Joint along closed contour”.
CAD drafting DRAWING DESIGN 1785
3. Number designation input field.
CAD software DRAWING DESIGN 1786
· Value input field. · Command CAD drawing DRAWING DESIGN 1787“Sum” – the number of welded seams with the same number is counted. Deleting or changing a seam number designation is automatically displayed in the full designation for that joint number. · Command CAD drafting DRAWING DESIGN 1788“Copy properties” – allows you to copy properties from an existing dimension in the drawing. · Command CAD software DRAWING DESIGN 1789“OK” – closes the dialog, saving changes. · Command CAD drawing DRAWING DESIGN 1790“Cancel” – closes the dialog without saving changes.4. Input field for the designation of the control complex or the seam control category.
CAD drafting DRAWING DESIGN 1791
· Value input field. · Command CAD software DRAWING DESIGN 1792“Copy properties” – allows you to copy properties from an existing dimension in the drawing. · Command CAD drawing DRAWING DESIGN 1793“OK” – closes the dialog, saving changes. · Command CAD drafting DRAWING DESIGN 1794“Cancel” – closes the dialog without saving changes.5. Input fields for the symbol.
CAD software DRAWING DESIGN 1795
· Value input field. · Buttons for quick insertion of special symbols for fixed joint:CAD drawing DRAWING DESIGN 1796 – Soldered leg;
CAD drafting DRAWING DESIGN 1797 – Remove weld reinforcement;
CAD software DRAWING DESIGN 1798 – Treat seam overflows and unevenness with graded junction to parent metal;
CAD drawing DRAWING DESIGN 1799 – Discrete double unfaced seam;
CAD drafting DRAWING DESIGN 1800 – Discrete double faced seam;
CAD software DRAWING DESIGN 1801 – Opened contour seam.
· Command CAD drawing DRAWING DESIGN 1802“Copy properties” – allows you to copy properties from an existing dimension in the drawing. · Command CAD drafting DRAWING DESIGN 1803“OK” – closes the dialog, saving changes. · Command CAD software DRAWING DESIGN 1804“Cancel” – closes the dialog without saving changes.Properties
Seam denotation:
· Text above self of leader · Text under self of leader · Text above leader · Text under leader · Enable calculate joints · Count of joints · Field joint · Joint along closed contourSoldering, Lacing, Clamps type 1, Clamps type 1, Pasting together:
· Joint along closed contour · TR item numberGrips
Seam denotation:
1. Move grips – Move the endpoints of the parts of the weld symbol.
2. “Mirror arrow side” grip – changes the side of the arrow.
3. “Weld seam properties” grip – opens a list of available graphic elements. In the list, you can enable or disable the display.
CAD drawing DRAWING DESIGN 1805
2. Joint type selection grip – opens a drop-down list for selecting a joint type.
CAD drafting DRAWING DESIGN 1806
CAD software DRAWING DESIGN 1807
Soldered Joint Leg:1. Move grip – allows you to move the leg.
2. Grips “Change leg size” – allow you to change the size of the leg.
CAD drawing DRAWING DESIGN 1808
Weld point:
1. Move grip – Allows you to move the weld point in the drawing.
CAD drafting DRAWING DESIGN 1809
Simplified weld joint
CAD software DRAWING DESIGN 1810Main menu: Construction – Weld – CAD drawing DRAWING DESIGN 1811Simplified weld joint.
CAD drafting DRAWING DESIGN 1812Toolbar: “Weld” – CAD software DRAWING DESIGN 1813Simplified weld joint.
CAD drawing DRAWING DESIGN 1814Command line: SPWJ.
CAD drafting DRAWING DESIGN 1815
Important!
As the rods and plates can be used primitives nanoCAD: circle and polyline (a special case polylines: rectangles, and polygons).
To use the unit as a plate or an object from the database, you must use when choosing an instrument Magnet plate for constructing the circuit plate.
Primitives must be tangent to each other.
Type: two rods overlap joints.
To add an overlap joint:
1. Call the command. 2. Select the drawing first rod . 3. Select the second rod. 4. To select the direction of one-way seam weld placement.CAD software DRAWING DESIGN 1816Two-way joint.
CAD drawing DRAWING DESIGN 1817One-way joint.
CAD drafting DRAWING DESIGN 1818Two-way joint.
Type: T-connection between two rods..
To add a T-joints:
1. Call the command. 2. Select the drawing first plate . 3. Select the second plate. 4. To select the direction of one-way seam weld placement.CAD software DRAWING DESIGN 1819Two-way joint.
CAD drawing DRAWING DESIGN 1820One-way joint.
CAD drafting DRAWING DESIGN 1821Two-way joint.
CAD software DRAWING DESIGN 1822Two-way joint.
Type: two plates overlap joints.
1. Call the command. 2. Select the drawing first plate. 3. Select the second plate. 4. To select the direction of one-way seam weld placement.CAD drawing DRAWING DESIGN 1823Corner seam-sided.
CAD drafting DRAWING DESIGN 1824Corner sided seam.
Type: Butt joint of two plates.
To add a butt joint:
1. Call the command. 2. Select the drawing first plate . 3. Select the second plate. 4. To select the direction of one-way seam weld placement.CAD software DRAWING DESIGN 1825One-way butt weld.
CAD drawing DRAWING DESIGN 1826Sided butt weld.
CAD drafting DRAWING DESIGN 1827One-way butt weld.
CAD software DRAWING DESIGN 1828Sided butt weld.
Type: Angular connection of two plates.
1. Call the command. 2. Select the drawing first plate. 3. Select the second plate. 4. To select the direction of one-way seam weld placement.CAD drawing DRAWING DESIGN 1829Corner seam-sided.
CAD drafting DRAWING DESIGN 1830Corner seam-sided.
Edge preparation
CAD software DRAWING DESIGN 1831Main menu: Construction – Weld – CAD drawing DRAWING DESIGN 1832Edge preparation.
CAD drafting DRAWING DESIGN 1833Toolbar: “Weld” – CAD software DRAWING DESIGN 1834Edge preparation.
CAD drawing DRAWING DESIGN 1835Command line: SPEDGEPREPARATION.
Provides cutting edge parts in the drawing.
CAD drafting DRAWING DESIGN 1836
Elements of the dialogue:
1)The list of standard cutting edges for welding;
CAD software DRAWING DESIGN 1837
2) List of types of connection plates welded: Butt, T-bar, angle;
CAD drawing DRAWING DESIGN 1838
3) List of connection options;
CAD drafting DRAWING DESIGN 1839
4) Filter the list by the thickness of the plates;
CAD software DRAWING DESIGN 1840
When you enter a numeric value thickness dialogue filters only those types of cutting edges, matching the thickness of the part. The filter is made by pressing the CAD drawing DRAWING DESIGN 1841“Apply filter”, or by pressing Enter. The value of the thickness in the filter can be measured by the meter to be launched on the CAD drafting DRAWING DESIGN 1842“Measure”.
5) Zoom menu created design elements
CAD software DRAWING DESIGN 1843
Menu is disabled if Auto is enabled check box. In this case, the scale created by the size and design elements set to the current scale decoration.
If you turn off Auto box, it will be possible to create a drawing cutting edges in arbitrary scale is selected in this dialog.
Operation
For the cutting edges must be vyponit following:
1. Select the type of connection: butt, T-bar or angle; 2. If necessary, filter preparation method edges, depending on their thickness. This can be done directly by entering the minimum thickness of the edges, or by measuring the drawing; 3. Determine the scope of dimension lines; 4. Double-click method of preparing the edges; 5. Specify the edge of the weld joint. Depending on the method of preparation is required to select the left and right edges alternately.CAD drawing DRAWING DESIGN 1844
When you create a cutting edge bevel one team will cycle to offer select sites for the creation of such ramps.
When you create a cutting edge bevel two team provides consistently indicate bevel for one, and then to other parts of the joint.
Important!
The plates can be used as primitives nanoCAD, as well as objects nanoCAD Construction .
Turn inserted edge welded connection can hold down Shift. It is necessary to include the “Object Snap” mode and “nearest” or in the settings nanoCAD Construction against the item “Connections” Nearest “automatically when you insert objects” put “Yes”.
Tables
Tables
CAD drafting DRAWING DESIGN 1845Main menu: Construction – Tables and title blocks – CAD software DRAWING DESIGN 1846Tables.
CAD drawing DRAWING DESIGN 1847Ribbon: Construction – Tables and title blocks – CAD drafting DRAWING DESIGN 1848Tables.
CAD software DRAWING DESIGN 1849Toolbar: CAD drawing DRAWING DESIGN 1850Tables (on toolbar “Tables and title blocks”).
CAD drafting DRAWING DESIGN 1851Command line: SPTABLE.
Causes dialog box to insert a new table.
CAD software DRAWING DESIGN 1852
· To create a custom table, select Custom. In input fields specify the dimensions of the created table, or on the layout, drag the mouse to the right as many rows and cells as required. When subsequent editing the number of rows, columns, cell sizes can be changed. · To insert a standard table, select load from database. You can insert a standard table of the base elements Building site . In the dialog box, select the table you want. Database elements Building site is available for all major types of standard tables. · To insert a table from a file, select Load from file.Click Browse and select the file table. Supported formats:
· tbl – tables files · dat – data file or a text file · mdb – database Microsoft Access · xls – Spreadsheet Microsoft Office Excel · xlsx – spreadsheet Microsoft Office Excel 2007 · csv – table cell separated by commas · txt – standard text file · xml – XML document · odf – OpenDocument Format.When loading a table of xlsx, xls file, you must select the Excel document sheet.
CAD drawing DRAWING DESIGN 1853
Important!
Select the sheet can be made after a table is loaded from the file.
CAD drafting DRAWING DESIGN 1854
CAD software DRAWING DESIGN 1855
In the properties of a table row source file displays the path to the source file of the table.
Select line Request to enter the desired page of the document. Then in the Table Editor, click CAD drawing DRAWING DESIGN 1856Update Table from an external source.
When loading a table from a file mdb drop-down list displays a list of database query.
CAD drafting DRAWING DESIGN 1857
Note:
To import tables from files, you can drag a file from Explorer to the dialog table .
When you drag a file from Windows Explorer in the imported table is added to the existing table.
When you drag a file from Windows Explorer dialog box replaces the existing table to be imported.
· To generate a report based on a sample of objects, select the objects in the sample report. ·To make a selection of items, click Select.
CAD software DRAWING DESIGN 1858
The search conditions are set in the Quick selection dialog.
Further dialogue is given based on what the attributes are and creates a report on the selected objects.
CAD drawing DRAWING DESIGN 1859
Includ attributes for the report in the list by selecting flags
CAD drafting DRAWING DESIGN 1860
· All- selects all attributes · None – the choice is removed from all the attributes · Invert – inverted selection attributesThe table is created with a template report form
=Iff(Exist(Object.“Autoreport”);Object.“Autoreport”;”“)
This formula checks whether there is a line for the attribute named Autoreport, and displays its value in a cell. Otherwise, leave the cell blank.
CAD software DRAWING DESIGN 1861
The number of columns in the table determined by the number of selected attributes.
· To import a table from Excel, select Import from Excel. To activate this item, the document should be opened. · Select the insertion point of the table. · CAD drawing DRAWING DESIGN 1862 · Select the numbering of rows in the table. · CAD drafting DRAWING DESIGN 1863If the switch rows upside down is enabled, the line numbered in reverse order.
· When the checkbox CAD software DRAWING DESIGN 1864 after you insert the table will start a dialogue format. · Click OK and the insertion point on the drawing table.Note:
If the drawing pre-select a group of objects, and then run the CAD drawing DRAWING DESIGN 1865tables, you will be prompted to create a report based on a sample of objects.
Import, export from Excel
Import
CAD drafting DRAWING DESIGN 1866Main menu: Construction – Tables and title blocks – CAD software DRAWING DESIGN 1867Import table from Excel.
CAD drawing DRAWING DESIGN 1868Ribbon: Construction – Tables and title blocks – CAD drafting DRAWING DESIGN 1869Import table from Excel.
CAD software DRAWING DESIGN 1870Toolbar: CAD drawing DRAWING DESIGN 1871Import table from Excel (on toolbar “Tables and title blocks”).
CAD drafting DRAWING DESIGN 1872Command line: SPTABLEEXCELIMPORT.
Transmits data from an open book MS Excel.
· In an open Excel worksheet, select the cells whose data you want to import into a table nanoCAD Construction 23. · Go to the nanoCAD, editor of the table, and then click Import tables from Excel. · Data will be transmitted to the table.Export
CAD software DRAWING DESIGN 1873Main menu: Construction – Tables and title blocks – CAD drawing DRAWING DESIGN 1874 Export table to Excel.
CAD drafting DRAWING DESIGN 1875Ribbon: Construction – Tables and title blocks – CAD software DRAWING DESIGN 1876 Export table to Excel.
CAD drawing DRAWING DESIGN 1877Toolbar: CAD drafting DRAWING DESIGN 1878Export table to Excel (on toolbar “Tables and title blocks”).
CAD software DRAWING DESIGN 1879Command line: SPTABLEEXCELEXPORT.
Designed to transmit tabular data in MS Excel. After clicking on the button opens a new Excel workbook and it migrates all the tabular data with formatting cells established in the table.
Important!
The tables nanoCAD Construction 23 not to Excel the following data:
· Blocks nanoCAD · Formatted text · Formulas that do not match the format of ExcelTable recognition
CAD drawing DRAWING DESIGN 1880Main menu: Construction – Tables and title blocks – CAD drafting DRAWING DESIGN 1881Table recognition.
CAD software DRAWING DESIGN 1882Ribbon: Construction – Tables and title blocks – CAD drawing DRAWING DESIGN 1883Table recognition.
CAD drafting DRAWING DESIGN 1884Toolbar: CAD software DRAWING DESIGN 1885Table recognition (on toolbar “Tables and title blocks”).
CAD drawing DRAWING DESIGN 1886Command line: SPRECTABLE.
Table recognition enables automatic search and replace tables created from individual primitives nanoCAD object “Table” nanoCAD Construction 23. Sources are primitives for drawing.
1. Use the command table recognition. 2. Specify the drawing point at the table.The table is created in the current layer. Dimensions of the recognized table are rounded to integer values.
Text belongs to the workpiece table is recognized as the values of the respective cells of the table.
Real dimensions of the original graphics are multiplied by the scale design, so if it turns out the table with zero height lines, you need to change the scale clearance in accordance with the size of the original graphics.
CAD drafting DRAWING DESIGN 1887Main menu: Construction – Table and title blocks – Table edit – CAD software DRAWING DESIGN 1888Edit table in-place.
CAD drawing DRAWING DESIGN 1889Ribbon: Construction – Edit table in-place – CAD drafting DRAWING DESIGN 1890Edit table in-place.
CAD software DRAWING DESIGN 1891Toolbar: Tables – CAD drawing DRAWING DESIGN 1892Edit table in-place.
CAD drafting DRAWING DESIGN 1893Command line: SPIPEDITTBLIPEDITTBL.
CAD software DRAWING DESIGN 1894Shortcut: CTRL+RBM on table frame.
When editing a table on-screen, the “Edit Table” toolbar appears.
CAD drawing DRAWING DESIGN 1895
The active cell is highlighted with a green frame. The text entered into the cell is automatically pre-pressed.
CAD drafting DRAWING DESIGN 1896Group cells.
Serves to combine adjacent cells into one.
Procedure:
· Call command. · Pick the first corner point of the selection. · Pick second corner point of selection. · Selected cells will merge.CAD software DRAWING DESIGN 1897Ungroup cells.
Undoes the grouping of a previously merged cell from multiple cells.
Procedure:
· Call command. · Pick the first corner point of the selection. · Pick second corner point of selection. · Selected grouped cells that fall within the selected area will ungroup.CAD drawing DRAWING DESIGN 1898Split cells.
Serves to divide cells into several smaller cells.
Procedure:
· Call command. · Pick the first corner point of the selection.CAD drafting DRAWING DESIGN 1899
· Pick second corner point of selection.CAD software DRAWING DESIGN 1900
· In the “Split” dialog box that appears, enter the required numerical values for repartitioning.CAD drawing DRAWING DESIGN 1901
· This will result in a new breakdown.CAD drafting DRAWING DESIGN 1902
Note:
When using the “Split” command, the height and width of adjacent cells may be lost.
CAD software DRAWING DESIGN 1903Pencil.
Serves for splitting cells into several by creating additional borders.
Procedure:
· Call command. · Pick the first point of the dividing line on the table border.CAD drawing DRAWING DESIGN 1904
· Pick the second point of the dividing line on the table border.CAD drafting DRAWING DESIGN 1905
· The cells that the dividing line will pass through will be split into new cells. Each cell is independent.CAD software DRAWING DESIGN 1906
CAD drawing DRAWING DESIGN 1907Add row. Adds one row at the bottom of the table.
CAD drafting DRAWING DESIGN 1908Add column. Adds one column to the end of the table.
CAD software DRAWING DESIGN 1909Insert row. Adds one row to the current position of the table cursor.
CAD drawing DRAWING DESIGN 1910Insert column. Adds one column to the current position of the table cursor.
CAD drafting DRAWING DESIGN 1911Delete row. Deletes the row containing the selected cell.
CAD software DRAWING DESIGN 1912Delete column. Deletes the column that contains the selected cell.
CAD drawing DRAWING DESIGN 1913Row properties. Changes the height of the row containing the selected cell. A dialog box is called up in which to specify the line height in millimeters.
CAD drafting DRAWING DESIGN 1914
The “Start new page” parameter splits the table in an arbitrary place, i.e. where the cell is selected. Other pagination methods are available in the full editor interface.
CAD software DRAWING DESIGN 1915Column properties. Changes the width of the column that contains the selected cell. Enter the column width in millimeters in the dialog box.
CAD drawing DRAWING DESIGN 1916
The “Hidden” option hides the selected column. You can return visibility to a column from the full editor interface.
The “Substitute zeros with symbol” parameter replaces the null values of the column cells with the row data. In this case, the format of the cells must be numeric.
CAD drafting DRAWING DESIGN 1917Cell properties. Calls up the “Cell Properties” dialog box, which configures the properties of the selected table cell.
CAD software DRAWING DESIGN 1918Cells properties. Setting properties of a group of table cells. Select the required cells and in the appearing “Cell Properties” dialog box set the parameters of the selected table cells.
CAD drawing DRAWING DESIGN 1919Sum
Calculates the sum of the selected area.
Procedure:
· Select the result cell. · Call the command. · Pick the first point of the marquee. · Pick the second point of the marquee. · The formula will be entered into the result cell.CAD drafting DRAWING DESIGN 1920Selective sum
Calculates the sum of the selected cells.
Procedure:
· Select the result cell. · Call the command. · Specify cells. Press “Enter” to finish. · The formula will be entered into the result cell.CAD software DRAWING DESIGN 1921Notebook
CAD drawing DRAWING DESIGN 1922Calculator
CAD drafting DRAWING DESIGN 1923Special symbols
CAD software DRAWING DESIGN 1924Quit. Exits the table screen editor. You can also exit the on-screen table editor by right-clicking on an empty space in the drawing.
Table editor
The interface is opened by double-clicking on the table, or by selecting the “Edit” command from the context menu of the selected table.
CAD drawing DRAWING DESIGN 1925
The dialog box contains:
· main menu; · toolbar; · parted cells with names (addresses) of rows and columns; · status bar with transparency and scale caret;General Provisions
The names (addresses) of rows and columns are adopted similarly to the MS Excel spreadsheet editor. Vertical columns from left to right are named in alphabetical order in English letters (A, B, C, D,…, Z, AA, AB, etc.), horizontal rows are named in numbers in order.
When you click LMB on a row or column name, it is selected.
CAD drafting DRAWING DESIGN 1926
CAD software DRAWING DESIGN 1927
To select the entire table, select a rectangle at the intersection of the row and column names.
CAD drawing DRAWING DESIGN 1928
The shortcut “Ctrl + scrolling mouse wheel” allows you to change the scaling of the table.
The shortcut “Ctrl + click mouse wheel” sets the default table scaling.
CAD drafting DRAWING DESIGN 1929
CAD software DRAWING DESIGN 1930
When “View sorting” is enabled, sort buttons appear on the right side of the column headings. This sorting is intended to improve the convenience of entering data in the spreadsheet editor and does not affect the state of the table in the drawing.
The button has three states: “Not”, “Ascending”, “Descending”.
Not
CAD drawing DRAWING DESIGN 1931
Ascending
CAD drafting DRAWING DESIGN 1932
Descending
CAD software DRAWING DESIGN 1933
Sorting features:
· Enabling sorting on one column disables sorting on other columns. · Rows are sorted whole, not just the column. · Strings are sorted within a section. · The merging of cells is not broken. · After enabling view sorting, the vast majority of commands are blocked. Allowed: exit, edit single cells and change sort mode.Cell color
CAD drawing DRAWING DESIGN 1934
– cell containing expression;CAD drafting DRAWING DESIGN 1935
– non-editable cell, for example, in a report;CAD software DRAWING DESIGN 1936
– cell with an error in the expression;CAD drawing DRAWING DESIGN 1937
– cell containing report section data;Filling adjacent cells with data
To speed up data entry into the table, automatic data filling functions are used. The spreadsheet editor can automatically continue a series of numbers, combinations of numbers and text according to a given pattern. You can quickly fill in different types of data series by selecting multiple cells and dragging the fill handle.
CAD drafting DRAWING DESIGN 1938
Filling cells with a sequence of numbers or combinations of numbers and text according to a given pattern:
1. Select the first of the filled cells.CAD software DRAWING DESIGN 1939
2. Enter an initial value for a range of values.CAD drawing DRAWING DESIGN 1940
3. Enter a value in the next cell to set the fill pattern.CAD drafting DRAWING DESIGN 1941
For example, if you want the sequence 1, 2, 3, 4, 5 …, enter the values 1 and 2 in the first two cells. If you want the sequence 2, 4, 6, 8 …, enter 2 and 4. If you need sequence 2, 2, 2, 2 …, the second cell can be left blank.
As the sequence is completed, it continues as shown in the table below.
Initial value
Continuation of the series
1, 2, 3…
4, 5, 6 …
1st period, 2nd period
3rd period …
Product 1, Product 2
Product 3 …
4. Highlight cell or cells containing seed values.CAD software DRAWING DESIGN 1942
5. Drag the fill handle over the range you want to fill.CAD drawing DRAWING DESIGN 1943
The cells will be filled with the specified sequence of numbers.
CAD drafting DRAWING DESIGN 1944
To fill in ascending order, drag the handle down or to the right. To fill in descending order, drag the handle up or left.
Basic tools
Main menu commands
File
· Open file… – loads table data from a file. Files available for download: * .tbl, * .dat, * .mdb (only for 32-bit Windows), * .txt, * .csv, * .xml, * .xls, * .xlsx. When you select an Excel file, only the first sheet of the workbook is inserted. · Open database… – opens a dialog of library to select a table saved in the database. · Save as file… – writing a table to an external file *.dat, *.txt, *.cvs, *.xml, *.xls. · Save to database… – writing the table to the base of elements. · Edit Form… – opens the form editor. Using the form, you can filter data, control the composition and style of the table. · Show Form… – opens the table filter form. · Imtort from Excel – the command transfers the results of calculating tabular data from an open MS Excel workbook. The content of the active sheet or a selected range of cells is transferred. · Export to Excel – the command is designed to transfer tabular data to MS Excel. After clicking the button, the “Conversion options” dialog opens. After specifying the options, a new Excel workbook is opened and all tabular data is transferred into it, while maintaining the cell formatting set in the table. · Close – saves changes and closes the editor. · Close without saving – closes the editor without saving changes.Edit
· Undo – undo the last action. · Redo – redo the last undone action. · Cut – cuts data from selected cells to the clipboard. · Copy – copies data from the selected cells to the clipboard. · Paste – pastes data from the clipboard.Pencil – serves for splitting cells into several by building additional borders.
CAD software DRAWING DESIGN 1945CAD drawing DRAWING DESIGN 1946CAD drafting DRAWING DESIGN 1947
· Select material… – This tool is designed to insert into a table, technical requirements and technical characteristics of a formatted line-record for material and assortment. Clicking on the button brings up the “Material” dialog box. · Auto calculate expressions – controls the mode of automatic recalculation of values of table cells. By default, the auto-recalculation mode is on. · Recalculate – serves to recalculate data in a table after editing cell values or correcting formulas. · Auto update reports – controls the mode of automatic recalculation of the report. The mode is on by default. · Reports – update of the report. · Synchronize – updates the table with data from a linked file. Available if the table was loaded from a file. For correct synchronization, the data changed in the file must be previously saved.View
· Show rulers – switch, controls the display of the ruler.CAD software DRAWING DESIGN 1948
· Show expressions -switch manages the formula bar display.CAD drawing DRAWING DESIGN 1949
· Formula visualization – switch, controls the display of the formulas in cells.CAD drafting DRAWING DESIGN 1950
· Zoom to objects – centers the original report objects in the drawing. · View sorting – controls the display of the sort buttons of the view.Turned on
Turned off
CAD software DRAWING DESIGN 1951
CAD drawing DRAWING DESIGN 1952
· Calculator… – the command calls calculator. · Notebook… – the command calls notebook.Column
· Add column – adds a new empty column after the selected column. · Insert column – adds a new empty column before the selected column. · Delete column – deletes the selected column. · Hidden – switch, hides the column. The column appears in the editor but does not appear in the drawing. · Properties… – open properties of column.Row
· Add row – adds a line below the selected one. · Delete row – deletes the selected row. · Hide row – hides the line. The line is not visible in both the editor and the drawing. · Show hidden rows – shows hidden lines. To use the command, you must select several lines between which hidden lines are located. · Sort ascending – sorts the table in ascending order relative to the selected column. · Sort descending – sorts the table in descending order relative to the selected column. · Custom sort… – opens a dialogue “Collections editor”. · Merging and Grouping… – opens a dialogue “Row grouping and merging”. · Start new page – switch, controls the page break before the selected line. · Limit rows per page… – opens the “Rows per page” dialog, which indicates the maximum number of lines per page. If there are more lines, a page break is inserted.CAD drafting DRAWING DESIGN 1953
· Limit page height… – opens the “Page height” dialog in which the maximum page height is indicated. If the page height is greater than the specified height, a page break is inserted.CAD software DRAWING DESIGN 1954
· Single page – the command removes all created page breaks. · Up to down – switch, controls the data display sequence. · Properties… – opens string properties.Cell
· Edit – puts the cell into edit mode. · Expression… – opens a dialogue “Expression builder”. · Properties… – opens a dialogue “Cell properties”. · Group – merges the selected cells. · Ungroup – corrodes the selected cells. · Split… – splits a cell into multiple rows and columns. When the command is called, the “Split” dialog appears.CAD drawing DRAWING DESIGN 1955
CAD drafting DRAWING DESIGN 1956
· Cut – cuts data from the selected cells to the clipboard. · Copy – copies data from the selected cells to the clipboard. · Paste – pastes data from the clipboard. · Clear – clears the selected cells. · Insert table – pastes a range of cells copied from Excel.Section
· Header of first page – adds a header for the first page. · Header of following pages – adds a header for pages. · Header of last page – add a header for the last page. · Insert Data section – inserts a data section. If the selected cell is in the data section, then an empty row is added. · Insert Report section – adds a report section. Used when building reports. · Footer of first page – adds a footer for the first page. · Footer of following pages – adds a footer for pages. · Footer of last page – add footer for the last page.Toolbar commands
· Open – allows you to choose one of two commands:CAD software DRAWING DESIGN 1957Open file- loads table data from a file. Files available for download: * .tbl, * .dat, * .mdb (only for 32-bit Windows) * .txt, * .csv, * .xml, * .xls, * .xlsx. When you select an Excel file, only the first sheet of the workbook is inserted.
CAD drawing DRAWING DESIGN 1958Load from base- opens a dialog of standard elements to select a table saved in the database.
· Save – allows you to choose one of two commands:CAD drafting DRAWING DESIGN 1959 Save to base- writing the table to the base of elements.
CAD software DRAWING DESIGN 1960 Save to file- writing a table to an external file * .dat, * .txt, * .cvs, * .xml, * .xls.
· CAD drawing DRAWING DESIGN 1961Import table from Excel – the command transfers the results of calculating tabular data from an open MS Excel workbook. The content of the active sheet or a selected range of cells is transferred. · CAD drafting DRAWING DESIGN 1962Export table to Excel -the command is designed to transfer tabular data to MS Excel. After clicking the button, the “Conversion options” dialog opens. After specifying the options, a new Excel workbook is opened and all tabular data is transferred into it, while maintaining the cell formatting set in the table. · CAD software DRAWING DESIGN 1963Update table from external source – updates the table with data from a linked file. Available if the table was loaded from a file. For correct synchronization, the data changed in the file must be previously saved. · CAD drawing DRAWING DESIGN 1964Pan and zoom view to show objects – centers the original report objects in the drawing. · CAD drafting DRAWING DESIGN 1965Cut selection – cuts data from the selected cells. · CAD software DRAWING DESIGN 1966Copy selection – copies data from the selected cells. · CAD drawing DRAWING DESIGN 1967Paste from clipboard – pastes data from the clipboard. · CAD drafting DRAWING DESIGN 1968Undo last change – undo the last action. · CAD software DRAWING DESIGN 1969Redo last change – redo the previously undone action. · CAD drawing DRAWING DESIGN 1970Move row down – moves the selected line down. · CAD drafting DRAWING DESIGN 1971Move row up – moves the selected line up. · CAD software DRAWING DESIGN 1972Move column left – moves the selected column to the left. · CAD drawing DRAWING DESIGN 1973Move column right – moves the selected column to the right. · CAD drafting DRAWING DESIGN 1974Page division -the tool is designed to split the table into separate parts, without losing integrity. With this function it is possible to split a large table in order to fit on the format, and still retain the ability to edit the table as a single object. · CAD software DRAWING DESIGN 1975Open form – opens the table filter form. · CAD drawing DRAWING DESIGN 1976Sort ascend – sorts the table in ascending order. · CAD drafting DRAWING DESIGN 1977Sort descend – sorts the table in descending order. · CAD software DRAWING DESIGN 1978Create summary function – sums the contents of the selected cells.CAD drawing DRAWING DESIGN 1979CAD drafting DRAWING DESIGN 1980
Procedure:
1. Select the cell in which you want to calculate the amount, press CAD software DRAWING DESIGN 1981“Create summary function”.
2. Select the cells whose contents you want to summarize, press “Enter”.
· CAD drawing DRAWING DESIGN 1982Open calculator – the command calls calculator. · CAD drafting DRAWING DESIGN 1983Open notebook – the command calls notebook. · CAD software DRAWING DESIGN 1984Insert material – This tool is designed to insert into a table, technical requirements and technical characteristics of a formatted line-record for material and assortment. When you click on the button, a dialog box is called “Material”. · CAD drawing DRAWING DESIGN 1985Special symbols – inserting a special character from the list. · CAD drafting DRAWING DESIGN 1986Recalculate table – serves to recalculate data in a table after editing cell values or correcting formulas. · CAD software DRAWING DESIGN 1987Automatic calculation – controls the mode of automatic recalculation of values of table cells. By default, the auto-recalculation mode is on. · CAD drawing DRAWING DESIGN 1988Update reports – update of the report. · CAD drafting DRAWING DESIGN 1989Automatic report update – controls the mode of automatic recalculation of the report. The mode is on by default. · CAD software DRAWING DESIGN 1990Group selection – serves to combine the selected table cells into one. · CAD drawing DRAWING DESIGN 1991Ungroup selected cells – cancels the merge for the selected cells. · CAD drafting DRAWING DESIGN 1992Change number of rows and columns – serves to change the number of rows and (or) columns in the selected range of cells.Procedure:
1. Select one or more cells and call the command.
2. In the “Split” dialog box that appears, enter the desired numeric values to stake.
CAD software DRAWING DESIGN 1993
· CAD drawing DRAWING DESIGN 1994Split table cell with pencil tool – serves for splitting cells into several by building additional borders.CAD drafting DRAWING DESIGN 1995CAD software DRAWING DESIGN 1996CAD drawing DRAWING DESIGN 1997
To split a cell with the mouse cursor, specify the start and end points of the segment that will divide each cell it crosses into two.
Right-clicking on a cell border removes that border.
· CAD drafting DRAWING DESIGN 1998Select cell style – calls the window for applying the style to the selected cells. · Text alignment – serves to control the placement of text in selected cells. Additional buttons are available by pressing the black triangle. The purpose of the buttons is clear from the figure on each of them.CAD software DRAWING DESIGN 1999
· Fitting text horizontally – controls the horizontal alignment of text in the cell. The following options are available in the drop-down list:CAD drawing DRAWING DESIGN 2000No horizontal tolerance
CAD drafting DRAWING DESIGN 2001Shrink horizontally
CAD software DRAWING DESIGN 2002Word wrap
· Fitting text vertically – controls the vertical alignment of text in the cell. The following options are available in the drop-down list:CAD drawing DRAWING DESIGN 2003No vertical tolerance
CAD drafting DRAWING DESIGN 2004Shrink text height
CAD software DRAWING DESIGN 2005Expand row height
CAD drawing DRAWING DESIGN 2006Add virtual rows
· Borders – is designed to control the display of the borders of the selected cells. When you click on the black triangle, additional buttons for displaying borders become available. The purpose of the buttons is clear from the figure on each of them.CAD drafting DRAWING DESIGN 2007
· Color of borders – drop-down list for choosing border colors. To set the border color, you must first select a color and then select the border (using the CAD software DRAWING DESIGN 2008“Borders” command) to which you want to apply the specified parameters.CAD drawing DRAWING DESIGN 2009
· Lineweight of borders -drop-down list of border thickness selection. To set the border thickness, you must first select the thickness and then select the border (using the CAD drafting DRAWING DESIGN 2010“Borders“command) to which you want to apply the specified parameters.CAD software DRAWING DESIGN 2011
· Text style – drop-down list for choosing the text style of the cell. · Text height – drop-down list for selecting the height of the cell text.CAD drawing DRAWING DESIGN 2012
· Text color – drop-down list for choosing the color of the cell text. · Text weight – drop-down list for choosing the thickness of the lines of the cell text.CAD drafting DRAWING DESIGN 2013
· Selected cell coordinate field – displays the coordinates of the selected cell (s) and allows you to enter them.CAD software DRAWING DESIGN 2014
· Row expressions – formula input field. The line is displayed if the “Main menu – View – Show expressions” switch is active.CAD drawing DRAWING DESIGN 2015
Using gestures for shortcuts
Gestures are designed for quick access to commands from the main menu of the table editor. Gestures made with pressed RMB in the table editor.
Note:
If when the prompt appears gesture command being executed, you can omit the RMB.
Right – Calculator
CAD drafting DRAWING DESIGN 2016
Left – Notebook
CAD software DRAWING DESIGN 2017
Up – Expression
CAD drawing DRAWING DESIGN 2018
Down – Cell properties
CAD drafting DRAWING DESIGN 2019
Right hook – Return
CAD software DRAWING DESIGN 2020
Left hook – Cancel
CAD drawing DRAWING DESIGN 2021
The closed area of the selected cells in a clockwise direction – Connection (merged cells pre-allocated)
CAD drafting DRAWING DESIGN 2022
Result:
CAD software DRAWING DESIGN 2023
The closed area of the selected cells counterclockwise – Disconnection
CAD drawing DRAWING DESIGN 2024
Result:
CAD drafting DRAWING DESIGN 2025
Symbol “z” on select cells – Clear (pre-clean cell is released)
CAD software DRAWING DESIGN 2026
Result:
CAD drawing DRAWING DESIGN 2027
Editing the size of rows and columns
To modify the row height or column width, move your mouse to the border of the row or column. Click the left mouse button and holding the button down drag the border. The move will be highlighted by the current value of the row height or column width, as well as its new size.
Resize a row or column can also be done in the properties dialog box, selected by pressing the right mouse button on the header row or column.
1. In the properties dialog box, specify the height (width) in millimeters.CAD drafting DRAWING DESIGN 2028
2. In the Properties dialog box of the column switch is available Hidden. With it, you can disable the display of the selected column in the drawing, however, the Editor will be displayed.CAD software DRAWING DESIGN 2029
You can also hide a column from the context menu for the column.
CAD drawing DRAWING DESIGN 2030
Command string Replace null values (for numeric cells with the value zero, the cell must be a numeric format), replaces the contents of the cells specified text.
Important!
Format text in a cell value is set in the properties of the cell on the tab Content .
Close the dialog by clicking OK.
Cell Properties
In the dialog box Properties parameters are set for table cells.
To edit the properties of a single cell in a table full editor, select the desired cell and issue Properties from the context menu or by pressing Ctrl + Enter, double click on the cell, as a gesture to “down” on the cell. The effect of this command is similar Cell Properties screen table editor.
To edit multiple table cells in the full editor, select the desired cells and issue the Properties from the context menu. The effect of this command is the same action as Properties screen editor table.
CAD drafting DRAWING DESIGN 2031CAD software DRAWING DESIGN 2032
There are six tabs:
· Flag Content. This tab specifies the type of data in a cell the user, set the formula for calculating values. In the properties of the cell can format values and enter the contents of a table cell. Checking unmodifiable disables the ability to edit the cell. Such a cell is highlighted in color.CAD drawing DRAWING DESIGN 2033
- Opens the Expression Builder.
CAD drafting DRAWING DESIGN 2034
CAD software DRAWING DESIGN 2035
- The tool is used to insert the nanoCAD block the cell.
Select the list that appears in the desired unit from the current drawing file. If necessary, select another file using the menu View.
CAD drawing DRAWING DESIGN 2036
After selecting a unit, it is displayed in the properties window of the cell, as well as in a table cell.
CAD drafting DRAWING DESIGN 2037CAD software DRAWING DESIGN 2038
To disconnect the unit, press the Remove block in the block selection.
CAD drawing DRAWING DESIGN 2039
· Bookmark Font. This specifies the text font, color symbols, line thickness, font height, offset from the cell boundaries, the angle that defines the direction of the text, as well as the aspect ratio of the text.CAD drafting DRAWING DESIGN 2040
Switch Vertical change text direction to vertical.
Empty fields oblique Angle and horizontal scaling means that the values are taken from the text style and horizontal indent – that the value is taken from the table settings.
· Bookmark fitCAD software DRAWING DESIGN 2041
This specifies the cell, cell as well as parameters of inscribing text into the cell.
If the text width exceeds cell bounds
CAD drawing DRAWING DESIGN 2042
If the text height exceed cell bounds:
CAD drafting DRAWING DESIGN 2043
Mode Occupy extra row does not change the number of rows in the table, the desired row is made higher by the required number of times and line.
· Bookmark borders. Here you specify the type, color, thickness of the boundary line of the selected cell, you can manage the display of individual cell borders. Enable or disable the display of individual boundaries, you can use buttonsCAD software DRAWING DESIGN 2044
CAD drawing DRAWING DESIGN 2045
or in the preview by clicking the left mouse button near one of the cell borders. Alignment of text within a cell preview is set by clicking the left mouse button.
CAD drafting DRAWING DESIGN 2046
To set the color of individual borders, click the left mouse button on the icon
CAD software DRAWING DESIGN 2047
and select a color from the drop down list
CAD drawing DRAWING DESIGN 2048
To determine the weight of the individual borders, click the left mouse button on the line (By layer) and choose the thickness of the drop-down list.
CAD drafting DRAWING DESIGN 2049
Color, line thickness for the cell borders, and cell shading can be set from the menu.
CAD software DRAWING DESIGN 2050
To apply the changes in color and thickness, click on the desired boundary. Can also be selected by using the display boundaries.
CAD drawing DRAWING DESIGN 2051
· Flag Comment. A field for entering a comment.CAD drafting DRAWING DESIGN 2052
Cell with the comment is displayed in the editor by a green label, which displays a hint when you hover the mouse on it.which is displayed a hint.
CAD software DRAWING DESIGN 2053
· Bookmark Styles. Here you can set the style for the cell.CAD drawing DRAWING DESIGN 2054
To create a style, right-click in the blank area of the Style tab, then on the shortcut menu, select Create.
CAD drafting DRAWING DESIGN 2055
To work with a style template, open the context menu style.
CAD software DRAWING DESIGN 2056
Using styles
Style assignment to table cells is performed by the command CAD drawing DRAWING DESIGN 2057“Select cell style” in the toolbar of the table editor or tab “Fit” in dialogue “Cell properties”. he choice of style is carried out in the graphics window. Also, styles can be created and edited using the context menu.
Context menu
· Apply – the command applies the selected style on the cell (group of cells). · Update – the command replaces the selected style with the style of the selected cell. · Rename – command allows you to rename the name of the style. The name of the style is generated automatically during creation. · Delete – command removes the selected style from the list. · Import – command imports style in * .mcd format. · Export – command exports the style in * .mcd format. · Create – command allows you to create a new style.Creation order:
1. Set the cell style.
2. Open the style window
3. Select the “Create” context menu command.
4. A new style will be created. The name of the style is generated automatically during creation.
Division by page
CAD drafting DRAWING DESIGN 2058Division by page. tool is designed to separate the table into separate parts, without losing its integrity. With this feature, you can split a large table in order to place a format, while preserving the ability to edit the table as a single object.
· When the command a dialog box appears page division.CAD software DRAWING DESIGN 2059
· Switch single page disables table division. · Select the method of dividing the table: 1. Custom- The table can divided into any parts.CAD drawing DRAWING DESIGN 2060
Page break before a row is set by start new command from the context menu.
CAD drafting DRAWING DESIGN 2061CAD software DRAWING DESIGN 2062
Close the dialog. The editor of the table indicate the boundaries of the gap, with the help of it, you can change the row height.
CAD drawing DRAWING DESIGN 2063
On the drawing table with a gap will be as follows:
CAD drafting DRAWING DESIGN 2064CAD software DRAWING DESIGN 2065
Side of the split table can be moved in the drawing independently, double-clicking on any part of the full table editor opens.
CAD drawing DRAWING DESIGN 2066
2. By row count enter the desired number of rows in a fragment. Headers do not count.CAD drafting DRAWING DESIGN 2067
By table height enter the total height of a fragment, in millimeters, using the current scal.CAD software DRAWING DESIGN 2068
Dividing the table into parts allows each part tobe moved independently:
Conversion options
The “Conversion options” dialog is a filter that influences the set of transmitted data. Appears when converting a report to data and when exporting a table to Excel.
CAD drawing DRAWING DESIGN 2069
Converting a report to data
Delete hidden rows and columns – affects the conversion of hidden strings. If enabled, hidden rows are not passed to the data.
Table
Turned on
Turned off
line 4 is hidden
no hidden lines
line 3 is hidden
CAD drafting DRAWING DESIGN 2070
CAD software DRAWING DESIGN 2071
CAD drawing DRAWING DESIGN 2072
Note:
The converted hidden lines remain hidden.
Save report template – affects the conversion of report template strings to data. If enabled, strings are transferred.
Table
Turned on
Turned off
CAD drafting DRAWING DESIGN 2073
CAD software DRAWING DESIGN 2074
CAD drawing DRAWING DESIGN 2075
Export to Excel
Delete hidden rows and columns – the option does not affect the result, since hidden rows are not exported.
Save report template – affects the export of report template strings. If enabled, strings are transferred.
Table
Turned on
Turned off
CAD drafting DRAWING DESIGN 2076
CAD software DRAWING DESIGN 2077
CAD drawing DRAWING DESIGN 2078
Using Variables
Important!
This function is available only in vertical applications based nanoCAD
Tables BuildIndustry support the use of additional variables defined in a special dialog (form).
Procedure for creating a set of user-defined variables and their use in the table below:
1. In full table editor from the menu Edit invoke the command Form Editor. 2. Create a form with controls and bind each control to a field (variable). More information about the forms, see Form Editor .CAD drafting DRAWING DESIGN 2079
3. Close the form editor and save the form.CAD software DRAWING DESIGN 2080
4. To set the variable, call the command form.CAD drawing DRAWING DESIGN 2081
5. Open your form. Enter the desired values. Click OK.CAD drafting DRAWING DESIGN 2082
6. Linking table cells with custom variables by using formulas.CAD software DRAWING DESIGN 2083
Cell value will be associated with the variable.
CAD drawing DRAWING DESIGN 2084
Variables can also be used in complex formulations.
Create reports
Reports are necessary in order to organize the data of objects in the drawing.
Recommended report structure:
· Header of first page; · Header of following page; · Header of last page; · Report title; · Report template; · Report; · Report summary; · Footer of first page; · Footer of following page; · Footer of last page;Generating a report
To create a report in the table editor, call the command from “Main menu – Section – Insert Report section”. The command will create a subsection “Report template”.
Additional subsections are added using the “Report template” menu: “Report title”, “Report Summary”.
Header and footer sections are added from “Main menu – Section”.
CAD drafting DRAWING DESIGN 2085
Report template
The report template defines the content and appearance of the report; it can consist of one or several lines. A separate copy of the report lines is created for each object. Formulas in the report are calculated using the properties of the selection objects.
The following commands are available in the “Report template” menu (click on the subsection name):
· “Object filter…” – opens the “Quick Selection” dialog for forming a selection of drawing objects. The command is duplicated by the CAD software DRAWING DESIGN 2086“Select source objects” button on the right in the “Report template” section. · “Merging and Grouping…” – opens the “Row grouping and merging” dialog in which the parameters of grouping and merging table cells are configured. The command is duplicated by the CAD drawing DRAWING DESIGN 2087“Group and merge” button on the right in the “Report template” section. · “Freeze report” – the switch controls the report refresh mode. If the checkbox is selected, the update is performed manually, and the “Update report” command becomes available. · “Update report” – refreshes the values of report objects, the command is available in manual refresh mode. · “Report header” – adds a “Report Title” subsection to the beginning of the report, displayed at the beginning of each part of the table. · “Append Data section” – adds a data section below the report. If the section already exists, an additional line is appended. · “Append Report section” – adds a new report below the current one. · “Remove Report” – deletes the report with all associated subsections. · “Rebuild” – completely rebuilds the report based on the report template. Data entered manually in the “Report” section will be overwritten. · “Convert to Data section” – the command converts sections of the report to data. Blank lines are not converted. Calling the command opens the “Conversion options” dialog. · “Report footer” – Adds the “Report Summary” subsection to the end of the report, displayed after each part of the table.All related subsections of the report are visually combined with brackets.
CAD drafting DRAWING DESIGN 2088
Important!
The report template has absolute priority over custom changes. After the refresh, the report colored by the user will become the same as the specified report template. Automatic report lines corresponding to the collected objects will be automatically formatted strictly according to the report template.
Report
The “Report” displays the values of the template variables.
CAD software DRAWING DESIGN 2089
The report contains cells (with a lilac background) containing object data, marked with a special color. Selecting cells highlights the corresponding objects in the drawing.
When editing such cells, the changes will be applied to the very object to which they refer. For instance:
1. Take a Bolt GOST 7795-70 with a length of 50 mm and place a leader on it.
CAD drawing DRAWING DESIGN 2090
2. Create table, report template and tie to bolt (parametric object).
CAD drafting DRAWING DESIGN 2091
3. Add parameters: Object.Name and Object.L.
CAD software DRAWING DESIGN 2092
4. Enter the new length, for example 120. Close the table editor.
5. The length of the bolt in the drawing has changed.
CAD drawing DRAWING DESIGN 2093
Report title
The following commands are available in the “Report Title” menu (click on the subsection name):
· “Remove section” – deletes the “Report Title” section.Report summary
The following commands are available in the “Report Summary” menu (click on the subsection name):
· “Remove section” – deletes the “Report Summary” section.In the context menu of the “Report Summary” cells, there are the following additional commands: “Sum”, “Average”, “Minimum”, “Maximum”, “Count”.
The commands insert into the selected cell corresponding to the name of the expression. The action is applied to a fragment of a column within one section.
CAD drafting DRAWING DESIGN 2094
Report Template
1. Call up the “Quick Selection” dialog box. Use the “Filter Objects…” command of the “Report Template” menu or the CAD software DRAWING DESIGN 2095“Select Source Objects” button on the right in the “Report Template” section.
2. Use the “Quick Selection” dialog to filter the objects and click the “OK” button. The selected objects will be associated with the report.
CAD drawing DRAWING DESIGN 2096
3. Select a cell in the “Report Template” section. In the context menu of the cell, the parameters of the related objects will be available for insertion.
CAD drafting DRAWING DESIGN 2097
5. Select an option from the context menu. The “Report” subsection will be automatically created. The number of lines in the “Report” subsection corresponds to the product of the number of related objects and the number of template lines.
The report template can consist of several lines. To add rows in the context menu of the “Report Template” row, use the “Add Row” or “Insert Row” commands.
CAD software DRAWING DESIGN 2098
Rows in a report template can be combined. Changes will be displayed in the “Report” section. Let’s consider a join using the example table below:
CAD drawing DRAWING DESIGN 2099
· Select cell A1:A2 and select the “Group” command from the context menu. The selected cells will be grouped.CAD drafting DRAWING DESIGN 2100
· In the “Report template” menu (click on the subsection name), select the “Rebuild” command. The table will look like this:CAD software DRAWING DESIGN 2101
6. Fill in all the required cells of the “Report Template”.
7. The sample is formed. Close the table editor. Changing the parameters of objects in the drawing will change the values in the report.
Grouping and merging cells
Button CAD drawing DRAWING DESIGN 2102Grouping and merging. Report template.
In the Grouping and merging dialog you can specify settings for grouping and merging table cells. Grouping and merging are only applied to cells in the report template.
CAD drafting DRAWING DESIGN 2103
Study the example for how to merge cells.
CAD software DRAWING DESIGN 2104 CAD drawing DRAWING DESIGN 2105
Merging
1. In the Grouping and merging dialog box select Append rule and select Merge.CAD drafting DRAWING DESIGN 2106
2. Select the column name for the cells you want to merge. Selection is made by double clicking on the column name or by dragging it into the Select field.CAD software DRAWING DESIGN 2107
Note:
To select another column, you must drag it into the column list and then select it.You can select several columns then place them in the required order.
The columns are processed according to the rules of the grouping remplate.
3. If you want to sort, select and don’t sortand sorting, and select sort type.CAD drawing DRAWING DESIGN 2108
4. Click OK to check the result in the table editor. Cells having identical values in the D column will be merged.CAD drafting DRAWING DESIGN 2109
CAD software DRAWING DESIGN 2110
CAD drawing DRAWING DESIGN 2111
Grouping
1. In the dialog box groupings and click Add Rule select Group.CAD drafting DRAWING DESIGN 2112
2. Select the name of the column whose cells you want to group. Choice is either by double-clicking on the column name, or by dragging it into the Select .CAD software DRAWING DESIGN 2113
3. If you want to sort, click on the link and sorting, and select the type of sort. 4. Click OK to view the results in the table editor. Table rows that contain the same values ??in column C, will be grouped.CAD drawing DRAWING DESIGN 2114
Interface Expression Editor
The Formula Editor (Expression Builder) allows you to set parameters, arithmetic expressions, and object property references for a selected table cell.
The formula editor is invoked:
· By clicking on the “fx” button in the formula bar; · By pressing Shift + F2; · Right-click upward; · From the context menu command “Expression ..”.Dialog
The dialog box consists of the “Expression Input Field”, “Formula Templates”, “List of Registered Functions”, “Quick View Fields” and the “Attach object” button.
CAD drafting DRAWING DESIGN 2115
The “Attach Object” button allows you to attach to objects.
At the top of the dialog there is an expression input field, with which you can manually enter any arithmetic expressions, as well as use reserved variables and object properties.
When entering manually, a list of functions and variables containing the word being entered appears in the list of reserved functions; syntax is also checked. If the formula is incorrect, an error warning or hint will appear in the Quick View.
CAD software DRAWING DESIGN 2116
In the quick view field, by clicking the mouse on an expression, the text in the input field related to this expression is selected.
CAD drawing DRAWING DESIGN 2117
When you click on the CAD drafting DRAWING DESIGN 2118 button in the “Expression input field”, the entered expression is saved on the formula templates panel for quick recall. Pressing the button again removes the expression from the formula template.
CAD software DRAWING DESIGN 2119
The “Reserved Functions List” contains recently used expressions that are highlighted in yellow. When you click on the CAD drawing DRAWING DESIGN 2120 button, expressions are saved in the Formula Templates panel for quick recall. Expressions that are in the Formula Template Bar in the Reserved Functions list will be marked with an asterisk. Pressing the CAD drafting DRAWING DESIGN 2121 button again removes the expression from the formula template.
When you hover the cursor over the button of the saved template, a tooltip will appear with the contents of this template.
CAD software DRAWING DESIGN 2122
In order to insert an expression from the “Formula template”, place the cursor in the required position, press the button with the template.
To delete an expression template, click the triangle button and uncheck the required template in the list that appears.
Binding to a table cell
In the formula, you can use any cell values of the properties of another object. If using automatic recalculation of the table, the formula object is automatically recalculated. Each cell can attach one or more objects. Objects are named Object1, Object2, and Object3, … sequentially numbered in the table. If the object is not used in a formula, it will detach from the table at the next calculation, and the object references are renumbered.
Binding properties for drawing objects to a single cell then use the expression or the keys Shift+F2. Available in the context menu of the selected cell.
CAD drawing DRAWING DESIGN 2123
After selecting the command window opens the Expression Builder.
CAD drafting DRAWING DESIGN 2124
Click Attach it.
Select the object whose data you want to send to the table (eg, Bolt M52). Now the list of expressions appears in the properties of the selected object. Double-clicking on the property (select Object.Name), adds it to the text in a cell. Click OK.
CAD software DRAWING DESIGN 2125
After connection of the facility to the cell the cell color changes (it says that the formula in the cell) and it will display the calculated result, in this case the name of the object:
CAD drawing DRAWING DESIGN 2126
Mathematical operations:
Addition
Subtraction
Multiplication
Division
Involution
sqrt()
Rootsquaring
Logical comparison and selection:
equally
more
less
not
or
not equal
not less
no more
or
and
Functions:
math:
Cos, Sin, Tg – trigonometric functions, the argument given in degrees.
Acos, Asin, Atg – inverse trigonometric functions, the result is given in degrees.
Abs – absolute value of (module).
Int – rounding to whole number.
Summ – returns the sum of the values of the variables in a grouped cells.
Note:
When you type a function should pay attention to the opening and closing brackets.
For example:
Summ(Row) – returns the sum of the numbers of grouped rows..
Summ(Standartnaya_detal.L) – returns the sum of the values ??of the L parameter object “standard part” in the grouped rows.
data conversion:
Str – Data conversion to a string type.
Num – conversion of data into a numeric type.
Frm – convert a numeric value to a string formatted according to the settings of a table column.
For example:
Frm(0.001230) returns a string 0,0012, if the column containing the cell is set to zero suppression and accuracy of 0,0000
selection and comparison:
FmtText – Addition formatted strings.
FmtSub – the creation of a subscript.
FmtSuper – create superscript.
FmtDigit – transfer number in hard copy.
FmtRaw – text without formatting.
DmtDiv – creation of fractions.
If/Iff – The logical choice. Recording Format:
if (Logich_Uslovie; Esli_Istina; Esli_Lozh)
where:
Logich_Uslovie – logical condition using logical comparisons (see above);
Esli_istina – the return value when the logical condition;
Esli_Lozh – return value at default logical condition.
For example:
if(object == Marker_universalny; Marker_universalny.position; “Undefined”) . If an object type, which is connected with the cell column has Marker_universalny value, the function returns the position value of the referenced object. Another type of object it returns a string Undefined .
Exist – Checks whether there is a constant: =IF(EXIST;Object.Name;0)
Min/Max – returns the minimum / maximum value listed in parentheses
For example:
Min(maskimalnoe_znachenie; MinValue ) – nourishes MinValue;
Max(maskimalnoe_znachenie; MinValue) – returns maskimalnoe_znachenie.
Count – returns the number of objects (for grouped rows in the table).
For example:
Count() – returns the number of objects associated with cells grouped rows.
Avg – Calculates the arithmetic mean of the arguments. Takes an arbitrary number of arguments understand ranges. Empty arguments are ignored.
Off – returns the value of the cell, given the relative index. The index is written in the format:
Off(string; column)
For example:
Off(-1;2) – returns the value of cell in the table on one line above (-1) and two columns to the right (2) of the current
Cell – the cell returns the value specified absolute index.
Merge (Cells,Expression) – brings together a range of Cells, if Expression is not equal to 0. Returns the value of Expression.
For example:
=merge(A5:C5; “Title”) – integrates cell A5 to C5, in the summary displays the text “Title”.
SetHeight() – reference line height. In brackets the height value.
Val() – computes the value of the argument.
For example:
=val(“A”+“1”) – calculates the “A1”, and then uses it as another expression (obtained by the value in cell A1). If the argument – not a string, then he comes back, ie =val(10+2) – the same thing =10+2.
=val(“summ(AStr(off(0;-1))“Str(off(0;-1))”)”) – the amount of cells from rows A to D, the number which is introduced into the cell to the left of the current one. In most cases you can do without val. The classic example, when without it – no way: in a custom form, enter the cell address, then to take the value out of it. Create a variable Addr, associate it with an input field on a form and in the table do so: = val (Addr) function allows recursion: = val (val (“A” + “1”)) – to take the value of the cell whose address is recorded in cell A1. Nesting depth is limited to 64.
Geometry(Object) – works as Implement object. Height embedded object shrinks to the line height. Object is taken from the report, or attached to the cell.
SUMM) – Sum of cells in the current column of the section next to the current.
COUNT) – The number of rows in the section containing the cell A3.
Reserved variables:
Pi – pi.
Row – for each cell in the column it returns the number of rows (rows are numbered starting with 1, excluding the header lines).
Col – for all cells in a column returns the column number of the table (column “A” is number 1).
Object – returns the type of the object, which is associated with the cell line.
Object1, Object2, … – objects attached to the cell.
Title – the name of the table.
RowCount – total number of rows.
ColCount – the total number of columns.
Split the table by pages
The “Split the table by pages” tool is similar to the CAD drafting DRAWING DESIGN 2127“Division by page” editor tool, but the result is not a split single table, but several separate tables.
1. Open the table for editing.
CAD software DRAWING DESIGN 2128
2. In the places where the break will be, set the break with the command “Start new page”.
CAD drawing DRAWING DESIGN 2129CAD drafting DRAWING DESIGN 2130
3. Close the editor.
4. Select a table.
5. From the context menu, select the “Split table by pages” command.
CAD software DRAWING DESIGN 2131
6. The table will be split into separate tables. The separation will occur at the places of the established breaks.
CAD drawing DRAWING DESIGN 2132CAD drafting DRAWING DESIGN 2133
Note:
If the command is applied to a report, the following destructive actions are performed:
1. The report is converted into static tables.
2. All connections with objects are broken.
3. All formulas are removed, and the cells begin to display the previously formed text.
4. Rows with report titles are hidden so that the display of the table in the drawing is not changed.
Drawing borders
Working with standard formats
CAD software DRAWING DESIGN 2134Main menu: Construction – Tables and title block – CAD drawing DRAWING DESIGN 2135Drawing title/borders.
CAD drafting DRAWING DESIGN 2136Toolbar: CAD software DRAWING DESIGN 2137Drawing title/borders ( “Tables and title block”).
CAD drawing DRAWING DESIGN 2138Command line: SPFORMAT, FORMAT.
· Filling in the fields of the title block · Drawing title/borders recognitionFundamental rules
Each format type is an element of the database nanoCAD Construction 23, which is located in the folder “Drawing border templates” library nanoCAD Construction 23.
emplates major labels and additional fields are located in the subfolder formats “Title block templates”. Renaming or deleting existing items in the folder “Drawing border templates” would make it impossible to insert existing formats.
Insert the format by clicking on the icon CAD drafting DRAWING DESIGN 2139Drawing title/borders. This dialog box appears Format:
CAD software DRAWING DESIGN 2140
This window is defined by:
· Format. · Sheet. · Autonumerate from. · Use zones from. · Center marks.After selecting the type of document, as well as the size and orientation of the sheet is inserted into the selected format.
· To edit the frame size, double-click the left mouse button on the contour of the frame. · To edit the text in the title block, double-click on the text of the left mouse button. · To edit entries in the title block, double-click the left mouse button on any line of the title block.If you remove the first sheet of the scope of its information from the title block is automatically transferred to the second sheet.
To save the settings template attached stamps and their parameters in the database, click on the button CAD drawing DRAWING DESIGN 2141, then enter the path stored in the database and the template name.
General Principles
To change the line frames the template files, edit the frames and other fields.
“Document Type” – Select the document type from the list format template in section database. Depending on the document type is changed appearance and availability of individual dialog items “Format”.
“Format” – the choice of the size of the sheet on the basis of standard size and multiplicity (not available for the types of documents based on the standard ISO, because the multiplicity inherent in the choice of format).
“Leaf” – the choice of template title block for the first or subsequent sheets.
“Orientation” – select page orientation (vertical or horizontal).
“Autonumerate from” – Automatic Numbering sheets. It lets you specify the number of the first sheet.
“Use zones from” – avtoprostanovka zones. It lets you specify the number of the first zone.
CAD drafting DRAWING DESIGN 2142Edit main stamp
After you select the document type and size under the proposed set the insertion point of the frame. If you press Enter or right mouse button, the lower left corner of the frame is aligned with the coordinate 0,0.
CAD software DRAWING DESIGN 2143Set default stamps – restores the template format those stamps which were overwritten while maintaining format template database.
CAD drawing DRAWING DESIGN 2144
To fill the title block fields and additional graph, double-click on any line of the title block.
The main inscription is filled directly into the dialog box, “Stamp”
While filling in the title block previously entered information stored in the section “History” menu. To open the context menu, place the cursor in an editable field and click the right mouse button.
Recent values can be saved in the section “Recent” menu.
Automatically fill fields of the title block
CAD drafting DRAWING DESIGN 2145Save as default
The command saves the current filling of the stamp in the memory. In the following fields will be filled automatically stamp
CAD software DRAWING DESIGN 2146Load defaults
The command loads the stored filling.
CAD drawing DRAWING DESIGN 2147Clear
The team clears stamp field
CAD drafting DRAWING DESIGN 2148Change template
The command opens a drop-down menu to change the pattern of the stamp.
CAD software DRAWING DESIGN 2149Main menu: Construction – Tables and title blocks – CAD drawing DRAWING DESIGN 2150Drawing title/borders recognition.
CAD drafting DRAWING DESIGN 2151Toolbar: CAD software DRAWING DESIGN 2152Drawing title/borders recognition ( “Recognition”).
CAD drawing DRAWING DESIGN 2153Command line: SPRECF.
Master recognition format enables automatic search and replace formats created from individual primitives nanoCAD, transforming them into an object of the “Format” nanoCAD Construction 23. Initial primitives are in the drawing.
Recognition takes place in two phases: the first searches for the formats in their dimensions, the second selected title block. Selection is made by comparing the serial patterns of stamps from the library with the existing geometric objects in the drawing. The remaining seals are installed by default. After the successful recognition format graphs stamps are automatically filled with values from the drawing, and the format is placed on the current layer.
Before you create a custom size or stamp is necessary to draw a pattern nanoCAD means in accordance with the required desired view object being created. When drawing templates should adhere to the following rules:
· The template can contain lines, arcs, and circles, text (single-line and multi-line), the objects of the library of standard parts nanoCAD Construction 23, blocks nanoCAD; · the thickness of the lines that are assigned to the template thickness is not equal to zero, and not “layer” to be adopted in accordance with the thickness of the closest standard value; · the color lines and text included in the template will be saved according to the selected values; · multiline text (mtext) is inscribed in the boundaries of the rectangular area of text is selected when you create it.You can use overhead lines and graphic objects, which are not drawn when inserting format or stamp in the drawing.
To install a drawing object as a service, use the button CAD drafting DRAWING DESIGN 2154“Set parameter” toolbar MechWizard, select the object, and in the dialog “Object properties” check the box “Is a working object”:
CAD software DRAWING DESIGN 2155
· Use the links in the templates · New border wizard · New title wizardUse the links in the templates
Stamps in the format template
Custom format may contain links to templates stamps available in the library. To add a stamp in the format used by the relevant rules.
Stamp Position and orientation when you insert a drawing format will be determined by the insertion point and orientation of text links:
CAD drawing DRAWING DESIGN 2156
the figure shows the format template added referring to stamp basic inscription. When you insert a drawing format drawn stamp recorded in the library under the specified name.
the format can be added to any number of references to the stamps from the library.
Using text fields
In the pattern of the stamp may be used special signage text fields.
Text added to the template and starting with the single character “$”, is recognized as a reference pointer on the field (the Count) input. In the input field of the dialog box, you can edit the stamp to record the text (for example, the name of the developer or check). Name field can contain characters of the Latin alphabet and the national or spaces. Dimensions of the input fields are defined primitives surrounding the insertion point, the reference index. If you found another symbol “$”, the text after it considered the description field:
$Field_name [$field definitions].
the contents of the text box will be displayed in the list of object properties.
To limit the size of the input field or eliminate overlapping fields in the dialog, you can use the service line.
To create a stamp based on an existing base in the sample, the sample to be inserted into the drawing by setting in the dialog box “Stamp” mode “Display field names” CAD drafting DRAWING DESIGN 2157. After insertion into the drawing die can be used as the layout of the new stamp.
Standard fields stamps have a description in Russian (GOST), English (ISO) or German (DIN) language, the values of the fields available in the list of object properties.
Name Description Contact with the properties of the document Inventor Note: $Designation Description + $DrawingName Name + $Drawing type Drawing View $Material Material + $Litera 1 Letter 1 $Litera 2 Letter 2 $Litera 3 Letter 3 $Mass Weight $DimScale Scale + Sets the size of generated within the format $Sheet Sheet + Changes in the automatic numbering $SheetCount Sheets + Changes in the automatic numbering $Add.text Position the additional inspection $Author Developed + $Control checked + $TechControl Technical control + $Add.subject Last additionally checked + $NormControl the Regulatory Control + $Approve Approved + $Author (sign) Developer Signature $Control (sign) the signature checking $TechControl (sign) Signature of the technical control $Add.subject (sign) Signature additional inspection $NormControl (sign) Text regulatory control $Approve (sign) the signature approving $Author (date) the date of + $Control (date) Date of Inspection + $TechControl (date) Date engineering controls + $Add.subject (date) Date further verification + $NormControl (date) Date of regulatory control + $Approve (date) Approval Date + $Original # Part Number script $Sign & date 1 Signed and dated 1 $Instead # Instead, inventory number $Duplicate # Inventory number duplicate $Sign $date 2 Signed and dated 2 $Reference # the reference number + $First use the primary use + $Format Format + $Enterprise Enterprise +In the pattern of the stamp can be used table nanoCAD Construction 23. Included in the stamp table when you insert a drawing can be edited as regular tables nanoCAD Construction 23 (except that the die table can not be modified in the editing mode screen).
Additional features
Converting from previous versions – In file defined fields for name mapping formats of old and new versions. If an entity applies the custom stamps of previous versions, the names of the fields, you can add them into the appropriate section of this file.
Integration with other objects nanoCAD Construction 23
Tables – Format allows you to use tables as stamps. This preserves virtually all the functionality built-in table.
Universal marker – The values of any fields format can be used in a universal marker.
Dimensions – When you create within the format size, the size takes out set in the title block of the format.
Legend roughness – The format may be associated with the designation of a roughness surfaces unspecified. Icon roughness is automatically transferred to the upper right corner of the format.
Property document – The value of the standard field format is synchronized with the attributes of the file in which it was created.
Technical conditions – Format calculates the coordinates of the columns to accommodate the technical requirements.
Attribute documents TechnologiCS – Exchange values between the fields and the format of the document attributes. You can set the matching fields automatically (by the same name), and then specify manually. Establishing appropriate stored for later use.
Zone format – The format can be calculated, is there any point in it. If so, you can receive the designation area containing the point.
New border wizard
CAD software DRAWING DESIGN 2158Main menu: Construction – Tables and title block – CAD drawing DRAWING DESIGN 2159New border wizard.
CAD drafting DRAWING DESIGN 2160Toolbar: CAD software DRAWING DESIGN 2161New border wizard ( “ Tables and title block”).
CAD drawing DRAWING DESIGN 2162Command line: SPFORMATWIZ.
CAD drafting DRAWING DESIGN 2163
To change the existing format, select it from the drop-down list of templates. The field, located in the center of the panel will be a general view of the selected format.
To add a new format, select the drop down list “Template name” paragraph (new).
Click the left mouse button on the center field, select the drawing created by pre-layout format template, and confirm the selection click OK.
In the dialog box “Format creation” will be recognized image format.
If you create a new format after closing the dialog box by pressing OK, a dialog “Create element”, which follows the format and select the name of the folder in the library of standard parts, which will save the created format:
CAD software DRAWING DESIGN 2164
By default the path “DB \ Drawing borders template”. If you want to keep the format in another folder, press CAD drawing DRAWING DESIGN 2165 and select the folder that appears in your browser.
Creating a template format is similar to creating templates stamps. Embedded tables are not supported. The texts, starting with the single “#” character, determine the type and position of the stamp format. When you insert the size of the database will be loaded stamped with the name specified in the text (the symbol ‘#’ is ignored and the text “main message” will be replaced with the box on a stamp with the name of “Title Block”), if it is in base. If the name starts with “$” and contains only hexadecimal digits, it is interpreted as UID template stamp in the database. Coordinates, direction and alignment of the text will be applied to the stamp.
Note:
See stamp UID by inserting the drawing title block of the database manager nanoCAD Construction 23.At the command prompt displays the hexadecimal object UIDPredefined templates are stored in the formats “DB \ Drawing borders template”. It is recommended that the new template is stored in the same folder, but when loading the template can be seen the whole base.
Frame custom format has a fixed size – the one set in the template. There is a special recognition mode that allows the use of standard scalable framework with their stamps. To enable this mode, select from the list in the dialog master the standard by which the frame will be built. In this mode, all of the graphics in the template are ignored, except for text and bounding box. The frame can be of any size – in the final format it replaced with standard frame. All texts are considered names stamps. There are two variants of binding stamps:
· If the text begins with the “#” symbol, it is stored offset from the insertion point to the nearest corner of the bounding box. · If the symbol “#” no stored offset from the text insertion point to the bottom left corner of the bounding box.Note:
Standard sizes have patterns in the database – their patterns are embedded in the program code.
New title wizard
CAD drafting DRAWING DESIGN 2166Main menu: Construction – Tables and title block – CAD software DRAWING DESIGN 2167New title wizard.
CAD drawing DRAWING DESIGN 2168Toolbar: CAD drafting DRAWING DESIGN 2169New title wizard ( “ Drawing Title/Borders”).
CAD software DRAWING DESIGN 2170Command line: SPSTAMPWIZ.
CAD drawing DRAWING DESIGN 2171
To change an existing stamp, select it from the drop-down list of templates.
To add a new format, select the drop down list “Template name (new)”.
A template stamp can have up to four different graphical representations: simple and full (advanced) type, including the form of the first sheet and the view for subsequent sheets.
Select one of the tabs: “Simple view” or “Extended view”. Click the left mouse button on one of the fields marked with a stamp type, and select the drawing template you created earlier mock punch. Confirm the selection click OK.
In the dialog box “Create stamp” will be recognized image of the stamp.
If you create a new stamp, after closing the dialog box by pressing OK, a dialog “Create element”, where you must enter the name of the stamp, and choose a library of standard parts folder in which to save the template created by the stamp:
CAD drafting DRAWING DESIGN 2172
New templates stamps recommend that you save to the folder “DB \ Drawing borders template \ Title block templates”.
If the layout for the die table to use, it will retain its editing capabilities even being introduced to the format. For these tables are only supported editing in place.
The pattern die may be up to four types:
· the main type of the first sheet, · he main type of follow-up sheets, · an expanded view of the first sheet, · an expanded view of the next sheet.The texts, starting with the single character “$” are recognized as the names of the fields. The editing dialog stamp they will be displayed in the form input fields. Name field can contain spaces and extended characters. Dimensions of the field defined primitives surrounding the point of its insertion. If you found another symbol “$”, the text after it considered the description field. This text will be displayed in the list of properties:
To limit the size of the field or eliminate overlapping fields in the dialog, you can use the service line. This is a primitive with zero thickness or line marked as the utility from mcWizParam. Set the parameter.
If you set daw “Work object”, then stamped on tobrazhatsya these primitives will not.
To create a stamp based on an existing base in the sample, the sample to be inserted into the drawing, and in his dialogue press CAD software DRAWING DESIGN 2173 “Show Field Names”. View selected stamp button “View”.
After that, the object can be divided (explode), edited and used as the layout.
The dialogue is a choice of the standard, which is taken from a stamp. This standard is used for the selection of the frame formats in recognition of the primitives.
Text
CAD drawing DRAWING DESIGN 2174Main menu: Construction – Text – CAD drafting DRAWING DESIGN 2175Technical conditions.
CAD software DRAWING DESIGN 2176Ribbon: Construction – Symbols – CAD drawing DRAWING DESIGN 2177Technical conditions.
CAD drafting DRAWING DESIGN 2178Toolbar: CAD software DRAWING DESIGN 2179Technical conditions (on toolbar “Text”).
CAD drawing DRAWING DESIGN 2180Command line: SPTT.
A distinctive feature of nanoCAD Construction 23 is the possibility of linking the designation of textual information on the drawing with the text in the technical requirements.
When writing paragraphs of technical requirements (hereinafter TC), you can make reference within the proposal of the paragraph of technical requirements to any position or affixed view.
The textual information is the tolerances and dimensions, drawing zones, designations of types, cuts, sections, marking signs, marking of welded joints, position.
A change in the value of the textual information (for example, a part position number) will result in an automatic change in the TC text. If this position has been deleted, a warning will appear about the need to check a particular item of requirements.
The relationship between the TC and the designation works in the opposite direction. Changing the order of the points of the requirements (their numbering) is automatically reflected in the designation on the drawing (for example, a marking mark, the designation of which contains the item number from the technical requirements).
Editor
CAD drafting DRAWING DESIGN 2181
Main menu
· File · Clear – clear TC. · Open file – the command opens the TC from a previously saved file. · Save file – command saves TC to * .rtf file. · Close without save – the command closes the TC editing dialog box without saving. · Edit · Undo – command cancels last action. · Redo – the command repeats the previously canceled action. · Insert title – command inserts a title in front of TC items. · Delete title – command removes TC title.Toolbar
· CAD software DRAWING DESIGN 2182Open file – the command opens the TC from a previously saved file. · CAD drawing DRAWING DESIGN 2183Save file – command saves TC to * .rtf file.Important!
The special characters used in the editor are lost when they are transferred to an external file.
· CAD drafting DRAWING DESIGN 2184Fill in MSWord – the command opens a new document in MSWord and inserts the text TC.Important!
· CAD software DRAWING DESIGN 2185Notebook – command opens interface notebook.CAD drawing DRAWING DESIGN 2186
· CAD drafting DRAWING DESIGN 2187Undo – command cancels last action. · CAD software DRAWING DESIGN 2188Redo – the command repeats the previously canceled action. · CAD drawing DRAWING DESIGN 2189Add paragraph (CTRL+ENTER) – command adds a new TC item. · CAD drafting DRAWING DESIGN 2190Delete paragraph (CTRL+DEL) – command deletes TC item. · CAD software DRAWING DESIGN 2191Replace paragraph up – the command moves the TC item at which the cursor is located, higher up in the list. · CAD drawing DRAWING DESIGN 2192Replace paragraph down – the command moves the TC item at which the cursor is located, down the list. · CAD drafting DRAWING DESIGN 2193Decrease Indent – the command reduces the indent of selected items.CAD software DRAWING DESIGN 2194CAD drawing DRAWING DESIGN 2195
· CAD drafting DRAWING DESIGN 2196Increase indent – command increases the indent of selected items.CAD software DRAWING DESIGN 2197CAD drawing DRAWING DESIGN 2198
· CAD drafting DRAWING DESIGN 2199Line Spacing – the command opens the list for setting the line spacing. Adjust line spacing of selected items.CAD software DRAWING DESIGN 2200
· 1 – set 1 leading (unit for measuring line spacing). Line spacing is added after the TC item. · 1.5 – set 1.5 leading. Line spacing is added after the TC item. · 2 – set 2 leading. Line spacing is added after the TC item. · Set line spacing… – the command allows you to specify your own line spacing. Line spacing is added after the TC item. · CAD drawing DRAWING DESIGN 2201Superscript – translates the selected text into superscript.CAD drafting DRAWING DESIGN 2202
· CAD software DRAWING DESIGN 2203Subscript – translates the selected portion of the text into a subscript. · CAD drawing DRAWING DESIGN 2204Insert fraction – the command calls the “Fraction” dialog box in which the numerator and denominator are specified. The fraction is inserted into the text TC.CAD drafting DRAWING DESIGN 2205
· CAD software DRAWING DESIGN 2206Insert tolerance – provides the ability to insert a tolerance. When called, the “Tolerances” dialog box opens.CAD drawing DRAWING DESIGN 2207CAD drafting DRAWING DESIGN 2208CAD software DRAWING DESIGN 2209
· CAD drawing DRAWING DESIGN 2210Insert material – provides the ability to insert material. When called, opens the “Material” dialog.CAD drafting DRAWING DESIGN 2211
· CAD software DRAWING DESIGN 2212Insert spec symbol – allows you to insert special characters in the text TC. · CAD drawing DRAWING DESIGN 2213Numeration – the command allows you to select the design option for TC items.CAD drafting DRAWING DESIGN 2214
Note:
To create a hierarchical list it is necessary to press the “Tab” key on an empty item. A new child level has been created. To return to the previous level, press the “Enter” key on an empty item.
· CAD software DRAWING DESIGN 2215Insert view/cuts – the command associates text fragments in TC with a graphical representation of views, sections and sections in the drawing.To insert a link in the TC editor, place the cursor on the insertion point of the associated symbol and click on the “Insert view / cuts” button, select the view, section or section.
Related information is displayed in blue in the TC editor. When you click on a link, the application will display the associated graphical representation.
· Ruler. The ruler is used to position the lines relative to the entire TC document. Sliders are used to position the lines.CAD drawing DRAWING DESIGN 2216
1. The bottom slider adjusts the indentation of all paragraph lines except the first line.
2. The top slider adjusts the indent of the first paragraph line.
3. The angle slider adjusts the text indent from the numbered list marker.
Context menu
The context menu uses standard commands for text fields.
Setting text options
To set the TC text parameters (font height and slope, indent from the title block, etc.) open the dialog box “Settings”.
Technical parameters
CAD drafting DRAWING DESIGN 2217Main menu: Construction – Text – CAD software DRAWING DESIGN 2218Technical parameters.
CAD drawing DRAWING DESIGN 2219Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 2220Technical parameters.
CAD software DRAWING DESIGN 2221Toolbar: CAD drawing DRAWING DESIGN 2222Technical parameters (on toolbar “Text”).
CAD drafting DRAWING DESIGN 2223Command line: SPTD.
Working with the technical description editor is similar to working with the TC editor. The main difference is that the typed text can be placed anywhere in the drawing.
Editor
CAD software DRAWING DESIGN 2224
Main menu
· File · Clear – clear TP. · Open file – the command opens the TP from a previously saved file. · Save file – command saves TP to * .rtf file. · Close without save – the command closes the TP editing dialog box without saving. · Edit · Undo – command cancels last action. · Redo – the command repeats the previously canceled action. · Insert title – command inserts a title in front of TP items. · Delete title – command removes TP title.Toolbar
· CAD drawing DRAWING DESIGN 2225Open file – the command opens the TP from a previously saved file. · CAD drafting DRAWING DESIGN 2226Save file – command saves TP to * .rtf file.Important!
· CAD software DRAWING DESIGN 2227Fill in MSWord – the command opens a new document in MSWord and inserts the text TP.Important!
· CAD drawing DRAWING DESIGN 2228Notebook – command opens interface notebook.CAD drafting DRAWING DESIGN 2229
· CAD software DRAWING DESIGN 2230Undo – command cancels last action. · CAD drawing DRAWING DESIGN 2231Redo – the command repeats the previously canceled action. · CAD drafting DRAWING DESIGN 2232Add paragraph (CTRL+ENTER) – command adds a new TP item. · CAD software DRAWING DESIGN 2233Delete paragraph (CTRL+DEL) – command deletes TP item. · CAD drawing DRAWING DESIGN 2234Replace paragraph up – the command moves the TP item at which the cursor is located, higher up in the list. · CAD drafting DRAWING DESIGN 2235Replace paragraph down – the command moves the TP item at which the cursor is located, down the list. · CAD software DRAWING DESIGN 2236Decrease Indent – the command reduces the indent of selected items.CAD drawing DRAWING DESIGN 2237CAD drafting DRAWING DESIGN 2238
· CAD software DRAWING DESIGN 2239Increase indent – command increases the indent of selected items.CAD drawing DRAWING DESIGN 2240CAD drafting DRAWING DESIGN 2241
· CAD software DRAWING DESIGN 2242Line Spacing – the command opens the list for setting the line spacing. Adjust line spacing of selected items.CAD drawing DRAWING DESIGN 2243
· 1 – set 1 leading (unit for measuring line spacing). Line spacing is added after the TP item. · 1.5 – set 1.5 leading. Line spacing is added after the TP item. · 2 – set 2 leading. Line spacing is added after the TP item. · Set line spacing… – the command allows you to specify your own line spacing. Line spacing is added after the TP item. · CAD drafting DRAWING DESIGN 2244Superscript – translates the selected text into superscript.CAD software DRAWING DESIGN 2245
· CAD drawing DRAWING DESIGN 2246Subscript – translates the selected portion of the text into a subscript. · CAD drafting DRAWING DESIGN 2247Insert fraction – the command calls the “Fraction” dialog box in which the numerator and denominator are specified. The fraction is inserted into the text TP.CAD software DRAWING DESIGN 2248
· CAD drawing DRAWING DESIGN 2249Insert tolerance – provides the ability to insert a tolerance. When called, the “Tolerances” dialog box opens.CAD drafting DRAWING DESIGN 2250CAD software DRAWING DESIGN 2251CAD drawing DRAWING DESIGN 2252
· CAD drafting DRAWING DESIGN 2253Insert material – provides the ability to insert material. When called, opens the “Material” dialog.CAD software DRAWING DESIGN 2254
· CAD drawing DRAWING DESIGN 2255Insert spec symbol – allows you to insert special characters in the text TP. · CAD drafting DRAWING DESIGN 2256Numeration – the command allows you to select the design option for TP items.CAD software DRAWING DESIGN 2257
Note:
· Ruler. The ruler is used to position the lines relative to the entire TP document. Sliders are used to position the lines.CAD drawing DRAWING DESIGN 2258
1. The bottom slider adjusts the indentation of all lines of the paragraph except the first line.
2. The top slider adjusts the indentation of the first line of the paragraph.
Context menu
To set the TP text parameters (font height and slope, indent from the title block, eTP.) open the dialog box “Settings”.
Construction text
CAD drafting DRAWING DESIGN 2259Main menu: Construction – Text – CAD software DRAWING DESIGN 2260Construction text.
CAD drawing DRAWING DESIGN 2261Ribbon: Construction – Symbols – CAD drafting DRAWING DESIGN 2262Construction text.
CAD software DRAWING DESIGN 2263Toolbar: Text – CAD drawing DRAWING DESIGN 2264Construction text.
CAD drafting DRAWING DESIGN 2265Command line: SPDTEXT.
Dialog
CAD software DRAWING DESIGN 2266
An expanded view of the dialog box with text adjustment tools is enabled by clicking the button CAD drawing DRAWING DESIGN 2267.
CAD drafting DRAWING DESIGN 2268
1. Enter the required text in the input field.
2. To insert special characters, use the CAD software DRAWING DESIGN 2269“Insert special symbol” button.
3. To insert text from a notebook, use the CAD drawing DRAWING DESIGN 2270“Notebook” button.
4. To insert the calculation result, use the CAD drafting DRAWING DESIGN 2271“Calculator” button.
5. In the “Properties” toolset, choose a text style and options.
· Text style – text style. · Height – text height. · Colour – text color · Oblique – gradient of text in degrees. · Spacing – serves to control the intercharacter spacing during automatic text compression, if the “Fit” switch is set. · At least – compresses the text, respecting the exact value of the spacing between the characters set for the selected text style. · Exactly – shrinks the text, automatically decreasing or increasing the character spacing to fit the line exactly within the specified input area. · Interval – determines the spacing between adjacent lines of text, inserted one by one using the “Add” button.6. In the “Display” toolset, set the text alignment and position options.
· Fit – the text is placed inside the selected area in the drawing. If the line length exceeds the size of the input area, the text is automatically compressed. · Align to point – the text is aligned to the point specified by the user. Click on the appropriate radio button in the graphics area:CAD software DRAWING DESIGN 2272
· Button CAD drawing DRAWING DESIGN 2273 – is intended to indicate in the drawing the insertion point of the text line and the angle of rotation. If the “Fit” radio button is selected, then after specifying the insertion point, you must also select the width of the text input area. · Angle – the value of the angle of rotation of the text in degrees.7. Click the “Add” button to insert a text string. Click “OK” or “Cancel” to exit the looping command.
Text editing
CAD drafting DRAWING DESIGN 2274
If it’s set multiline text editing with tools nanoCAD Construction 23, then clicks on the test will be called dialogue editing.
CAD software DRAWING DESIGN 2275
In this dialog may ask, besides the text, its color, and the Height, and add special symbols.
