Base dimensioning
Ribbon: Home, Annotate – Dimensions > Baseline Dimension
Menu: Dimensions – Base dimension
Toolbar: Utilities –
Command line: DBA, DIMBASELINE
Base dimensions are a sequence of dimensions measured from a reference point.
A base dimension creates a linear, angular or ordinate dimension from the baseline of the previous or selected dimension.
To draw the base dimensions:
- Start the Auto command.
- Select the Base option in the command line or context menu
- Select the extension line of the previous dimension as a base:
- Specify the endpoint of the first dimension:
- Specify the endpoints for all the other dimensions and press ENTER to finish the command:
The default spacing between the baseline dimensions can be set from the Modify dimension Style, Lines tab, Baseline Spacing.
Info: NanoCAD is an easy-to-use, low cost, and yet professional, CAD program for Windows, that provides an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software provides groundbreaking, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
