Ribbon: Layout – Layouts > Layout from Template
Menu: Insert – Layout > Layout from Template…
Layouts Manager dialog: Load layouts from template
Command line: LAYOUTFROMTEMPLATE
The command creates a new layout in the document.
The command allows you to create one or several layouts from an existing template file (.dwt) or drawing file (.dwg) or drawing exchange file (*.dxf).
Start the command to open the Open Document file dialog box:
To select a template in the Open Document File dialog box:
1. Select the *.dwt format from the Files of type list.
2. Select the folder where the template file or drawing file is stored.
3. Select the file.
4. Click Open.
5. Select one or several layouts in the Insert Layout(s) dialog box (use SHIFT and CTRL keys):
6. Click OK.
If the name of the inserted layout is the same as the name of a layout in the paper space, then the new layout will have a name consisting of the name of the existing layout, to which the name of the inserted layout is joined with an underscore character. For example, when you insert a layout called A4 into a document already having a layout with same name, a layout called A4_A4 will be created. When you next insert the layout called A4, it will be created with the name A4_A4_A4 and so on.
Info: NanoCAD is a user friendly, inexpensive, and yet professional, CAD freeware tool for PC, that provides a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our tool provides innovative, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
