For many editing commands, you can launch additional options for object selection in the command line.
1. Start the Select editing command from the command line
or
2. Start any editing command.
3. To the command prompt about object selection Select objects or [?]: enter? (question mark) or select from the context menu.
4. The following prompt is displayed in the command line: Select an option or [Window/Last/Crossing/Box/All/Fence/Wpolygon/Cpolygon/Group/Add/Remove/AUto]:
5. Select the required option.
Window | Selection of objects that are entirely inside the rectangular area, specified by two points from left to right. |
Last | Selection of the last created object. Objects cannot be on a frozen layer. |
Crossing | election of objects, crossed by the rectangular area or inside the rectangular area, specified by two points from right to left. |
Box | Selection option, with choice of Window or Crossing options. If points in the rectangular area are specified from right to left, the selection of objects is equal to the Crossing option. If points in the rectangular area are specified from left to right, the selection of objects is equal to the Window option. |
All | All objects are selected, excluding objects belonging to locked or frozen layers. |
Fence | Selection of objects crossed by the selection line. |
WPolygon | Selection of objects which are entirely inside the polygonal area. A polygon can have any shape, but there must not be any self-intersections. The segment of a polygon created last is the closing segment. |
CPolygon | Selection of objects which are entirely inside the polygonal area or are crossed by this area. A polygon can have any shape, but there must not be any self-intersections. The segment of a polygon created last is the closing segment. |
Group | Selection of objects in the specified group. |
Add | Adds objects to the current set using any selection method. Automatic mode and adding mode are used by default (Auto and Add modes). |
Remove | Deletes objects in the current set using any selection method. You can exclude objects by pressing the SHIFT button in the adding mode (Add mode) or automatic mode (Auto mode). |
AUto | Selection of objects with pickbox. When an empty area is selected by the pickbox, the Box option is switched on and the first point of the window or crossing window is specified. Automatic mode and adding mode are used by default (Auto and Add modes). |
Additional options of object selection are on a Selection toolbar:
Info: NanoCAD is a user friendly, inexpensive, and yet powerful, CAD program for Windows, that delivers a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software ensures innovative, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
