Point Light
Menu: View – Render – Light > New point light
Toolbar: Lights –
Command line: POINTLIGHT
Creates the omni point light that simulates the light bulb.
The source is displayed in the work space as a small sphere contour.
Command prompts
Set the light source location: | Define the point of the light source location. |
Set the target location: | Define the point of the target location – the point to which the light flux will be directed. |
Enter the name of the modified mode or [Name/Intensity/Status/Photometry/Attenuation/Color/Exit]: | Define the command options, if necessary, otherwise just press Enter. |
Name | Name of the light source. |
Intensity | Brightness of the light: from 0 to the maximum value supported. By default, is equal to 1. |
Status | Status of the light source: turned on/off. The disabled light source stops lighting, and its icon in the work space changes color to bright green. |
Photometry | Photometry is the measurement of the luminous intensities of visible light sources. Intensity of light in photometry is the measurement of perceived power emitted by a light source in a particular direction.
Attenuation | Diminishing the light intensity (brightness) over distance from the light source. Attenuation type:
Color | Color of light given by this source.
Exit | Exits the command. |
Info: NanoCAD is a simple, affordable, and yet powerful, CAD app for PC, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software provides innovative, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
